[PostGIS] #6032: postgis_tiger_geocoder upgrade script for PostgreSQL < 16 not stripping extension placeholder
PostGIS trac at osgeo.org
Mon Feb 9 16:11:23 PST 2026
  Reporter:  robe            |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  blocker         |  Milestone:  PostGIS 3.6.2
 Component:  tiger geocoder  |    Version:  3.5.x
Resolution:  fixed           |   Keywords:
Changes (by Regina Obe <lr@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"8fef3f68db6337af6b95b990ddd373444fe295ff/git" 8fef3f6/git]:
 {{{#!CommitTicketReference repository="git"
 revision="8fef3f68db6337af6b95b990ddd373444fe295ff"
 Remove postgis_extension_remove_objects
 Closes #5853 for PostGIS 3.6.2
 Fix postgis_tiger_geocoder upgrade for PostgreSQL < 16
 Closes #6032 for PostGIS 3.6.2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6032#comment:4>
