[SCM] PostGIS branch master updated. 3.6.0rc2-340-g8d6df5b8e
git at osgeo.org
git at osgeo.org
Fri Feb 20 02:58:22 PST 2026
the project "PostGIS".
via 8d6df5b8ef368723a125c62494a31b820b245413 (commit)
from 6d729904766367e513963cbb330b58400d12025c (commit)
revisions in full, below.
commit 8d6df5b8ef368723a125c62494a31b820b245413
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Feb 20 11:55:43 2026 +0100
Make GEOS-3.10 the minimum required
As per passed motion:
https://lists.osgeo.org/pipermail/postgis-devel/2026-January/030713.html
diff --git a/NEWS b/NEWS
index 702d22393..eac939a70 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,8 @@
PostGIS 3.7.0dev
xxxx/xx/xx
+This version requires GEOS 3.10 or higher
* Breaking Changes *
- #5688, [topology] topology building functions now interpret tolerance 0
diff --git a/README.postgis b/README.postgis
index 65494b7a9..21faf6dbf 100644
--- a/README.postgis
+++ b/README.postgis
@@ -64,15 +64,11 @@ For apt-based systems you can run this command to install the below dependencies
https://proj.org
-* GEOS (Required, Version 3.8 or higher)
+* GEOS (Required, Version 3.10 or higher)
- 3.14+ for ST_CoverageClean, raster ST_IntersectionFractions
- 3.12+ for ST_CoverageSimplify and ST_CoverageInvalidEdges
- 3.11+ for improved ST_ConcaveHull, ST_lineMerge,
and new functions ST_SimplifyPolygonHull, ST_TriangulatePolygon
- - 3.10+ for ST_MakeValid enhancements
- - 3.9+ is needed to take advantage of
- fixed precision enhancements in overlay functions
- - 3.7+ is needed just for the ST_FrechetDistance function
The GEOS library provides support for exact topological tests such as
ST_Touches(), ST_Contains(), ST_Disjoint() and spatial operations such as
diff --git a/configure.ac b/configure.ac
index 203740046..6a01d656f 100644
--- a/configure.ac
+++ b/configure.ac
@@ -777,7 +777,7 @@ dnl ===========================================================================
dnl
dnl Set the min version number here
dnl
-GEOS_MIN_VERSION=3.8.0
+GEOS_MIN_VERSION=3.10.0
GEOS_MIN_VERSION_NUMERIC=`echo $GEOS_MIN_VERSION | $PERL -nle 'printf "%d%02d%02d\n",$1,$2,$3 if /(\d+)\.(\d+)\.(\d+)/'`
AC_ARG_WITH([geosconfig],
Summary of changes:
NEWS | 2 ++
README.postgis | 6 +-----
configure.ac | 2 +-
3 files changed, 4 insertions(+), 6 deletions(-)
hooks/post-receive
