[SCM] PostGIS branch master updated. 3.6.0rc2-341-gab5c625fb
git at osgeo.org
git at osgeo.org
Fri Feb 20 03:17:52 PST 2026
the project "PostGIS".
via ab5c625fb6cd2d1b275d78f26a28b2f910eb6774 (commit)
from 8d6df5b8ef368723a125c62494a31b820b245413 (commit)
revisions in full, below.
commit ab5c625fb6cd2d1b275d78f26a28b2f910eb6774
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Feb 20 12:16:03 2026 +0100
Drop conditionals for GEOS < 3.10
diff --git a/doc/developer.md b/doc/developer.md
index 1a1fcf33a..6b56c610b 100644
--- a/doc/developer.md
+++ b/doc/developer.md
@@ -289,8 +289,8 @@ We have guards in place in the code to handle these for dependency libraries
* GEOS
- c:
```c
- #if POSTGIS_GEOS_VERSION < 31000
- /* GEOS < 3.1 code goes here */
+ #if POSTGIS_GEOS_VERSION < 31300
+ /* GEOS < 3.13 code goes here */
#endif
- test files:
@@ -298,9 +298,9 @@ We have guards in place in the code to handle these for dependency libraries
* raster/rt_pg/tests/tests.mi.in
```makefile
- ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31000),1)
+ ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31300),1)
TESTS += \
- # add tests that require GEOS 3.1 or higher to run
+ # add tests that require GEOS 3.13 or higher to run
endif
diff --git a/liblwgeom/cunit/cu_geos.c b/liblwgeom/cunit/cu_geos.c
index ed648dd0c..cbb9d0ba1 100644
--- a/liblwgeom/cunit/cu_geos.c
+++ b/liblwgeom/cunit/cu_geos.c
@@ -150,15 +150,9 @@ test_geos_makevalid(void)
geom3 = lwgeom_normalize(geom2); //so GEOS 3.9 and 3.10 agree
out_ewkt = lwgeom_to_ewkt((LWGEOM*)geom3);
-#if POSTGIS_GEOS_VERSION < 30900
- ASSERT_STRING_EQUAL(
- out_ewkt,
- "GEOMETRYCOLLECTION(POLYGON((92092.377 463437.77,92114.014 463463.469,92115.51207431706 463462.206937429,92115.512 463462.207,92127.546 463452.075,92117.173 463439.755,92133.675 463425.942,92122.136 463412.82600000006,92092.377 463437.77)),MULTIPOINT(92122.136 463412.826,92115.51207431706 463462.2069374289))");
-#else
out_ewkt,
"POLYGON((92092.377 463437.77,92114.014 463463.469,92115.512 463462.207,92115.51207431706 463462.2069374289,92127.546 463452.075,92117.173 463439.755,92133.675 463425.942,92122.136 463412.826,92092.377 463437.77))");
-#endif
lwfree(out_ewkt);
lwgeom_free(geom1);
lwgeom_free(geom2);
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index 102ed604d..e3fb18625 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -146,10 +146,6 @@ ptarray_from_GEOSCoordSeq(const GEOSCoordSequence* cs, uint8_t want3d)
uint32_t dims = 2;
POINTARRAY* pa;
uint32_t size = 0;
-#if POSTGIS_GEOS_VERSION < 31000
- uint32_t i;
- POINT4D point = { 0.0, 0.0, 0.0, 0.0 };
-#endif
LWDEBUG(2, "ptarray_fromGEOSCoordSeq called");
@@ -170,22 +166,8 @@ ptarray_from_GEOSCoordSeq(const GEOSCoordSequence* cs, uint8_t want3d)
LWDEBUGF(4, " output dimensions: %d", dims);
pa = ptarray_construct((dims == 3), 0, size);
-#if POSTGIS_GEOS_VERSION >= 31000
GEOSCoordSeq_copyToBuffer(cs, (double*) pa->serialized_pointlist, (dims == 3), 0);
return pa;
-#else
- for (i = 0; i < size; i++)
- if (dims >= 3)
- GEOSCoordSeq_getXYZ(cs, i, &(point.x), &(point.y), &(point.z));
- else
- GEOSCoordSeq_getXY(cs, i, &(point.x), &(point.y));
- ptarray_set_point4d(pa, i, &point);
- return pa;
-#endif
/* Return an LWGEOM from a Geometry */
@@ -297,7 +279,6 @@ ptarray_to_GEOSCoordSeq(const POINTARRAY* pa, uint8_t fix_ring)
if (append_points == 0) {
sq = GEOSCoordSeq_copyFromBuffer((const double*) pa->serialized_pointlist, pa->npoints, FLAGS_GET_Z(pa->flags), FLAGS_GET_M(pa->flags));
if (!sq)
@@ -306,7 +287,6 @@ ptarray_to_GEOSCoordSeq(const POINTARRAY* pa, uint8_t fix_ring)
return sq;
-#endif
if (!(sq = GEOSCoordSeq_create(pa->npoints + append_points, dims)))
GEOS_FAIL();
@@ -710,13 +690,7 @@ lwgeom_intersection_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
if (!(g2 = LWGEOM2GEOS(geom2, AUTOFIX))) GEOS_FREE_AND_FAIL(g1);
if ( prec >= 0) {
- lwgeom_geos_error_minversion("Fixed-precision intersection", "3.9");
- GEOS_FREE_AND_FAIL(g1, g2);
- return NULL;
-#else
g3 = GEOSIntersectionPrec(g1, g2, prec);
-#endif
else
@@ -807,13 +781,7 @@ lwgeom_unaryunion_prec(const LWGEOM* geom, double prec)
if (!(g1 = LWGEOM2GEOS(geom, AUTOFIX))) GEOS_FAIL();
if ( prec >= 0) {
- lwgeom_geos_error_minversion("Fixed-precision unary union", "3.9");
- GEOS_FREE_AND_FAIL(g1);
- return NULL;
-#else
g3 = GEOSUnaryUnionPrec(g1, prec);
-#endif
else
@@ -859,13 +827,7 @@ lwgeom_difference_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
if ( prec >= 0) {
- lwgeom_geos_error_minversion("Fixed-precision difference", "3.9");
- return NULL;
-#else
g3 = GEOSDifferencePrec(g1, g2, prec);
-#endif
else
@@ -910,13 +872,7 @@ lwgeom_symdifference_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
if ( prec >= 0) {
- lwgeom_geos_error_minversion("Fixed-precision symdifference", "3.9");
- return NULL;
-#else
g3 = GEOSSymDifferencePrec(g1, g2, prec);
-#endif
else
@@ -969,11 +925,6 @@ lwgeom_centroid(const LWGEOM* geom)
LWGEOM*
lwgeom_reduceprecision(const LWGEOM* geom, double gridSize)
- lwgeom_geos_error_minversion("Precision reduction", "3.9");
- return NULL;
-#else
LWGEOM* result;
int32_t srid = RESULT_SRID(geom);
uint8_t is3d = FLAGS_GET_Z(geom->flags);
@@ -999,7 +950,6 @@ lwgeom_reduceprecision(const LWGEOM* geom, double gridSize)
GEOS_FREE(g1, g3);
return result;
-#endif
LWGEOM *
@@ -1063,13 +1013,7 @@ lwgeom_union_prec(const LWGEOM* geom1, const LWGEOM* geom2, double gridSize)
if ( gridSize >= 0) {
- lwgeom_geos_error_minversion("Fixed-precision union", "3.9");
- return NULL;
-#else
g3 = GEOSUnionPrec(g1, g2, gridSize);
-#endif
else
@@ -1814,11 +1758,7 @@ lwgeom_get_geos_coordseq_2d(const LWGEOM* g, uint32_t num_points)
return NULL;
-#if POSTGIS_GEOS_VERSION < 30800
- if (!GEOSCoordSeq_setX(coords, i, tmp.x) || !GEOSCoordSeq_setY(coords, i, tmp.y))
-#else
if (!GEOSCoordSeq_setXY(coords, i, tmp.x, tmp.y))
-#endif
GEOSCoordSeq_destroy(coords);
lwpointiterator_destroy(it);
diff --git a/liblwgeom/lwgeom_geos_clean.c b/liblwgeom/lwgeom_geos_clean.c
index 75e2200a4..580859621 100644
--- a/liblwgeom/lwgeom_geos_clean.c
+++ b/liblwgeom/lwgeom_geos_clean.c
@@ -327,9 +327,6 @@ lwgeom_make_valid_params(LWGEOM* lwgeom_in, char* make_valid_params)
LWDEBUG(4, "geom converted to GEOS");
- geosout = GEOSMakeValid(geosgeom);
-#else
if (!make_valid_params) {
@@ -378,7 +375,6 @@ lwgeom_make_valid_params(LWGEOM* lwgeom_in, char* make_valid_params)
geosout = GEOSMakeValidWithParams(geosgeom, params);
GEOSMakeValidParams_destroy(params);
-#endif
GEOSGeom_destroy(geosgeom);
if (!geosout) return NULL;
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index e4aacfcfe..989faabf7 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -265,15 +265,6 @@ Datum ST_FrechetDistance(PG_FUNCTION_ARGS)
PG_FUNCTION_INFO_V1(ST_MaximumInscribedCircle);
Datum ST_MaximumInscribedCircle(PG_FUNCTION_ARGS)
- lwpgerror("The GEOS version this PostGIS binary "
- "was compiled against (%d) doesn't support "
- "'GEOSMaximumInscribedCircle' function (3.9.0+ required)",
- POSTGIS_GEOS_VERSION);
- PG_RETURN_NULL();
-#else /* POSTGIS_GEOS_VERSION >= 30900 */
GSERIALIZED* geom;
GSERIALIZED* center;
GSERIALIZED* nearest;
@@ -381,8 +372,6 @@ Datum ST_MaximumInscribedCircle(PG_FUNCTION_ARGS)
result = HeapTupleGetDatum(resultTuple);
PG_RETURN_DATUM(result);
-#endif /* POSTGIS_GEOS_VERSION >= 30900 */
@@ -390,15 +379,6 @@ Datum ST_MaximumInscribedCircle(PG_FUNCTION_ARGS)
PG_FUNCTION_INFO_V1(ST_LargestEmptyCircle);
Datum ST_LargestEmptyCircle(PG_FUNCTION_ARGS)
- PG_RETURN_NULL();
GSERIALIZED* geom;
GSERIALIZED* boundary;
@@ -510,8 +490,6 @@ Datum ST_LargestEmptyCircle(PG_FUNCTION_ARGS)
diff --git a/postgis/lwgeom_geos_predicates.c b/postgis/lwgeom_geos_predicates.c
index fb8989f05..1219117f8 100644
--- a/postgis/lwgeom_geos_predicates.c
+++ b/postgis/lwgeom_geos_predicates.c
@@ -1039,15 +1039,6 @@ Datum LWGEOM_dwithin(PG_FUNCTION_ARGS)
double tolerance = PG_GETARG_FLOAT8(2);
double mindist;
- const GSERIALIZED *geom1 = PG_GETARG_GSERIALIZED_P(0);
- const GSERIALIZED *geom2 = PG_GETARG_GSERIALIZED_P(1);
- LWGEOM *lwgeom1 = lwgeom_from_gserialized(geom1);
- LWGEOM *lwgeom2 = lwgeom_from_gserialized(geom2);
- mindist = lwgeom_mindistance2d_tolerance(lwgeom1, lwgeom2, tolerance);
- PG_RETURN_BOOL(tolerance >= mindist);
-#else
SHARED_GSERIALIZED *shared_geom1 = ToastCacheGetGeometry(fcinfo, 0);
SHARED_GSERIALIZED *shared_geom2 = ToastCacheGetGeometry(fcinfo, 1);
const GSERIALIZED *geom1 = shared_gserialized_get(shared_geom1);
@@ -1111,8 +1102,6 @@ Datum LWGEOM_dwithin(PG_FUNCTION_ARGS)
PG_RETURN_BOOL(is_dwithin);
-#endif
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index a89b77bfc..a2f66dad1 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -33,137 +33,129 @@ TESTS += \
$(top_srcdir)/regress/core/binary \
$(top_srcdir)/regress/core/boundary \
$(top_srcdir)/regress/core/chaikin \
- $(top_srcdir)/regress/core/filterm \
+ $(top_srcdir)/regress/core/clean \
+ $(top_srcdir)/regress/core/clipbybox2d \
$(top_srcdir)/regress/core/cluster \
+ $(top_srcdir)/regress/core/computed_columns \
$(top_srcdir)/regress/core/ctors \
$(top_srcdir)/regress/core/curvetoline \
+ $(top_srcdir)/regress/core/delaunaytriangles \
$(top_srcdir)/regress/core/dump \
$(top_srcdir)/regress/core/dumppoints \
$(top_srcdir)/regress/core/dumpsegments \
$(top_srcdir)/regress/core/empty \
$(top_srcdir)/regress/core/estimatedextent \
- $(top_srcdir)/regress/core/forcecurve \
+ $(top_srcdir)/regress/core/filterm \
+ $(top_srcdir)/regress/core/fixedoverlay \
$(top_srcdir)/regress/core/flatgeobuf \
+ $(top_srcdir)/regress/core/forcecurve \
$(top_srcdir)/regress/core/frechet \
$(top_srcdir)/regress/core/generate_points \
$(top_srcdir)/regress/core/geography \
$(top_srcdir)/regress/core/geography_centroid \
$(top_srcdir)/regress/core/geography_covers \
$(top_srcdir)/regress/core/geometric_median \
- $(top_srcdir)/regress/core/geos_noop \
+ $(top_srcdir)/regress/core/geos310 \
$(top_srcdir)/regress/core/geos38 \
+ $(top_srcdir)/regress/core/geos39 \
+ $(top_srcdir)/regress/core/geos_noop \
$(top_srcdir)/regress/core/hausdorff \
+ $(top_srcdir)/regress/core/in_encodedpolyline \
$(top_srcdir)/regress/core/in_flatgeobuf \
$(top_srcdir)/regress/core/in_geohash \
$(top_srcdir)/regress/core/in_gml \
$(top_srcdir)/regress/core/in_kml \
$(top_srcdir)/regress/core/in_marc21 \
- $(top_srcdir)/regress/core/out_marc21 \
- $(top_srcdir)/regress/core/in_encodedpolyline \
$(top_srcdir)/regress/core/iscollection \
+ $(top_srcdir)/regress/core/isvaliddetail \
$(top_srcdir)/regress/core/legacy \
$(top_srcdir)/regress/core/letters \
$(top_srcdir)/regress/core/lwgeom_regress \
$(top_srcdir)/regress/core/measures \
$(top_srcdir)/regress/core/minimum_bounding_circle \
+ $(top_srcdir)/regress/core/minimum_clearance \
+ $(top_srcdir)/regress/core/node \
$(top_srcdir)/regress/core/normalize \
+ $(top_srcdir)/regress/core/offsetcurve \
$(top_srcdir)/regress/core/operators \
$(top_srcdir)/regress/core/orientation \
+ $(top_srcdir)/regress/core/oriented_envelope \
$(top_srcdir)/regress/core/out_flatgeobuf \
- $(top_srcdir)/regress/core/out_geometry \
$(top_srcdir)/regress/core/out_geography \
+ $(top_srcdir)/regress/core/out_geojson \
+ $(top_srcdir)/regress/core/out_geometry \
$(top_srcdir)/regress/core/out_gml \
+ $(top_srcdir)/regress/core/out_marc21 \
+ $(top_srcdir)/regress/core/point_coordinates \
$(top_srcdir)/regress/core/polygonize \
$(top_srcdir)/regress/core/polyhedralsurface \
$(top_srcdir)/regress/core/postgis_type_name \
$(top_srcdir)/regress/core/quantize_coordinates \
$(top_srcdir)/regress/core/regress \
$(top_srcdir)/regress/core/regress_bdpoly \
+ $(top_srcdir)/regress/core/regress_brin_index \
+ $(top_srcdir)/regress/core/regress_brin_index_3d \
+ $(top_srcdir)/regress/core/regress_brin_index_geography \
$(top_srcdir)/regress/core/regress_buffer_params \
$(top_srcdir)/regress/core/regress_gist_index_nd \
$(top_srcdir)/regress/core/regress_index \
$(top_srcdir)/regress/core/regress_index_nulls \
- $(top_srcdir)/regress/core/regress_management \
- $(top_srcdir)/regress/core/regress_selectivity \
$(top_srcdir)/regress/core/regress_lrs \
+ $(top_srcdir)/regress/core/regress_management \
$(top_srcdir)/regress/core/regress_ogc \
$(top_srcdir)/regress/core/regress_ogc_cover \
$(top_srcdir)/regress/core/regress_ogc_prep \
- $(top_srcdir)/regress/core/regress_proj_basic \
- $(top_srcdir)/regress/core/regress_proj_adhoc \
- $(top_srcdir)/regress/core/regress_proj_cache_overflow \
$(top_srcdir)/regress/core/regress_proj_4890 \
+ $(top_srcdir)/regress/core/regress_proj_adhoc \
+ $(top_srcdir)/regress/core/regress_proj_basic \
+ $(top_srcdir)/regress/core/regress_proj_cache_overflow \
$(top_srcdir)/regress/core/regress_proj_pipeline \
+ $(top_srcdir)/regress/core/regress_selectivity \
$(top_srcdir)/regress/core/relate \
+ $(top_srcdir)/regress/core/relatematch \
$(top_srcdir)/regress/core/remove_irrelevant_points_for_view \
+ $(top_srcdir)/regress/core/removepoint \
$(top_srcdir)/regress/core/remove_repeated_points \
$(top_srcdir)/regress/core/remove_small_parts \
- $(top_srcdir)/regress/core/removepoint \
$(top_srcdir)/regress/core/reverse \
$(top_srcdir)/regress/core/scroll \
$(top_srcdir)/regress/core/setpoint \
+ $(top_srcdir)/regress/core/sharedpaths \
$(top_srcdir)/regress/core/simplify \
$(top_srcdir)/regress/core/simplifyvw \
$(top_srcdir)/regress/core/size \
+ $(top_srcdir)/regress/core/snap \
$(top_srcdir)/regress/core/snaptogrid \
$(top_srcdir)/regress/core/split \
- $(top_srcdir)/regress/core/sql-mm-serialize \
$(top_srcdir)/regress/core/sql-mm-circularstring \
$(top_srcdir)/regress/core/sql-mm-compoundcurve \
$(top_srcdir)/regress/core/sql-mm-curvepoly \
$(top_srcdir)/regress/core/sql-mm-general \
$(top_srcdir)/regress/core/sql-mm-multicurve \
$(top_srcdir)/regress/core/sql-mm-multisurface \
- $(top_srcdir)/regress/core/swapordinates \
+ $(top_srcdir)/regress/core/sql-mm-serialize \
+ $(top_srcdir)/regress/core/subdivide \
$(top_srcdir)/regress/core/summary \
+ $(top_srcdir)/regress/core/swapordinates \
$(top_srcdir)/regress/core/temporal \
$(top_srcdir)/regress/core/temporal_knn \
$(top_srcdir)/regress/core/tickets \
$(top_srcdir)/regress/core/triangulatedsurface \
$(top_srcdir)/regress/core/twkb \
$(top_srcdir)/regress/core/typmod \
+ $(top_srcdir)/regress/core/unaryunion \
+ $(top_srcdir)/regress/core/union \
+ $(top_srcdir)/regress/core/voronoi \
$(top_srcdir)/regress/core/wkb \
$(top_srcdir)/regress/core/wkt \
$(top_srcdir)/regress/core/wmsservers \
- $(top_srcdir)/regress/core/offsetcurve \
- $(top_srcdir)/regress/core/relatematch \
- $(top_srcdir)/regress/core/isvaliddetail \
- $(top_srcdir)/regress/core/sharedpaths \
- $(top_srcdir)/regress/core/snap \
- $(top_srcdir)/regress/core/node \
- $(top_srcdir)/regress/core/unaryunion \
- $(top_srcdir)/regress/core/union \
- $(top_srcdir)/regress/core/clean \
- $(top_srcdir)/regress/core/delaunaytriangles \
- $(top_srcdir)/regress/core/clipbybox2d \
- $(top_srcdir)/regress/core/subdivide \
- $(top_srcdir)/regress/core/voronoi \
- $(top_srcdir)/regress/core/regress_brin_index \
- $(top_srcdir)/regress/core/regress_brin_index_3d \
- $(top_srcdir)/regress/core/regress_brin_index_geography \
- $(top_srcdir)/regress/core/minimum_clearance \
- $(top_srcdir)/regress/core/oriented_envelope \
- $(top_srcdir)/regress/core/point_coordinates \
- $(top_srcdir)/regress/core/out_geojson \
- $(top_srcdir)/regress/core/wrapx \
- $(top_srcdir)/regress/core/computed_columns
+ $(top_srcdir)/regress/core/wrapx
# Slow slow tests
TESTS_SLOW = \
$(top_srcdir)/regress/core/concave_hull_hard \
$(top_srcdir)/regress/core/knn_recheck
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30900),1)
- # GEOS-3.9 adds stable maximuminscribedcircle implementation
- TESTS += \
- $(top_srcdir)/regress/core/geos39 \
- $(top_srcdir)/regress/core/fixedoverlay
-endif
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31000),1)
- TESTS += \
- $(top_srcdir)/regress/core/geos310
-endif
ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31100),1)
TESTS += \
Summary of changes:
doc/developer.md | 8 ++--
liblwgeom/cunit/cu_geos.c | 6 ---
liblwgeom/lwgeom_geos.c | 60 ----------------------------
liblwgeom/lwgeom_geos_clean.c | 4 --
postgis/lwgeom_geos.c | 22 -----------
postgis/lwgeom_geos_predicates.c | 11 ------
regress/core/tests.mk.in | 84 ++++++++++++++++++----------------------
7 files changed, 42 insertions(+), 153 deletions(-)
hooks/post-receive
