[PostGIS] #6052: Spin off postgis_tiger_geocoder as separate project
PostGIS trac at osgeo.org
Fri Feb 20 09:23:41 PST 2026
 Reporter:  robe            |      Owner:  robe
     Type:  defect          |     Status:  assigned
 Priority:  medium          |  Milestone:  PostGIS 3.7.0
Component:  tiger geocoder  |    Version:  master
 Keywords:                  |
 As discussed and so far agreed on, we are spinning off
 postgis_tiger_geocoder as separate project.
 https://lists.osgeo.org/pipermail/postgis-devel/2026-February/030735.html
 and with that move, I'm also going to use gitea as issue tracker instead
 of trac.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6052>
