[SCM] PostGIS branch stable-3.3 updated. 3.3.7-65-g29d977fa4
git at osgeo.org
git at osgeo.org
Tue Jan 13 07:34:32 PST 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
via 29d977fa49f899bfe6533bd2fe8b14a13b1313d3 (commit)
from 38c2ccb5ea604ac456e3297be39663d0cbbce58e (commit)
revisions in full, below.
commit 29d977fa49f899bfe6533bd2fe8b14a13b1313d3
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Jan 13 12:05:57 2026 +0100
Fix robustness issue in ptarray_contains_point
References #6023 in 3.3 branch (3.3.9dev)
Includes unit test
diff --git a/NEWS b/NEWS
index cd969c30f..a2005d6a9 100644
--- a/NEWS
+++ b/NEWS
@@ -26,6 +26,7 @@ Proj 4.9+ required.
- #5991, CircularString distance error (Paul Ramsey)
- #5962, Consistent clipping of MULTI/POINT (Paul Ramsey)
- #5989, CurvePolygon distance error (Paul Ramsey)
+ - #6023, Fix robustness issue in ptarray_contains_point (Sandro Santilli)
- #6027, Fix RemoveUnusedPrimitives without topology in search_path (Sandro Santilli)
- #6028, crash indexing malformed empty polygon (Paul Ramsey)
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index 48d6a3b24..82c50301d 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -426,6 +426,17 @@ static void test_ptarray_contains_point()
rv = ptarray_contains_point(pa, &pt);
CU_ASSERT_EQUAL(rv, LW_INSIDE);
+ lwline_free(lwline);
+ /* Test for https://trac.osgeo.org/postgis/ticket/6023 */
+ lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(11.230120879533454 62.84897119848748,11.230120879533905 62.8489711984873,11.23020501303477 62.84900750109812,11.230170431987244 62.84904481447776,11.230117909393426 62.8489943480894,11.230120879533454 62.84897119848748)"));
+ pa = lwline->points;
+ pt = getPoint2d(lwline->points, 0);
+ rv = ptarray_contains_point(pa, &pt);
+ ASSERT_INT_EQUAL(rv, LW_BOUNDARY);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index e106d2372..4d822fb98 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -759,6 +759,12 @@ ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt)
seg2 = getPoint2d_cp(pa, i);
+ /* This is required for robustness, see #6023 */
+ if (p2d_same(seg1, pt))
+ return LW_BOUNDARY;
/* Zero length segments are ignored. */
if (p2d_same(seg1, seg2))
Summary of changes:
NEWS | 1 +
liblwgeom/cunit/cu_ptarray.c | 11 +++++++++++
liblwgeom/ptarray.c | 6 ++++++
3 files changed, 18 insertions(+)
hooks/post-receive
