[SCM] PostGIS branch stable-3.2 updated. 3.2.7-58-g79c591a8a
Tue Jan 13 07:35:17 PST 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  79c591a8af5a19bb3b81c7f5ddbc540529c4086e (commit)
      from  87f9a82dbf195c0f3d57e12b32be4d4b5b5eb4ac (commit)
revisions in full, below.
commit 79c591a8af5a19bb3b81c7f5ddbc540529c4086e
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jan 13 12:05:57 2026 +0100
    Fix robustness issue in ptarray_contains_point
    Closes #6023 in 3.2 branch (3.2.9dev)
    Includes unit test
diff --git a/NEWS b/NEWS
index fcbb2210c..8e80e68f4 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ Proj 4.9+ required.
 * Bug Fixes  *
+ - #6023, Fix robustness issue in ptarray_contains_point (Sandro Santilli)
  - #5951, [topology] Fix crash in ST_GetFaceEdges with corrupted topology (Sandro Santilli)
  - #5947, [topology] Fix crash in ST_ModEdgeHeal (Sandro Santilli)
  - #5925, #5946, [topology] Have GetFaceContainingPoint survive EMPTY edges (Sandro Santilli)
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index 0ae4a43fd..e22844603 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -426,6 +426,17 @@ static void test_ptarray_contains_point()
 	rv = ptarray_contains_point(pa, &pt);
 	CU_ASSERT_EQUAL(rv, LW_INSIDE);
+	lwline_free(lwline);
+	/* Test for https://trac.osgeo.org/postgis/ticket/6023 */
+	lwline = lwgeom_as_lwline(lwgeom_from_text("LINESTRING(11.230120879533454 62.84897119848748,11.230120879533905 62.8489711984873,11.23020501303477 62.84900750109812,11.230170431987244 62.84904481447776,11.230117909393426 62.8489943480894,11.230120879533454 62.84897119848748)"));
+	pa = lwline->points;
+	pt = getPoint2d(lwline->points, 0);
+	rv = ptarray_contains_point(pa, &pt);
+	ASSERT_INT_EQUAL(rv, LW_BOUNDARY);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index e106d2372..4d822fb98 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -759,6 +759,12 @@ ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt)
 		seg2 = getPoint2d_cp(pa, i);
+		/* This is required for robustness, see #6023 */
+		if (p2d_same(seg1, pt))
+			return LW_BOUNDARY;
 		/* Zero length segments are ignored. */
 		if (p2d_same(seg1, seg2))
Summary of changes:
 NEWS                         |  1 +
 liblwgeom/cunit/cu_ptarray.c | 11 +++++++++++
 liblwgeom/ptarray.c          |  6 ++++++
 3 files changed, 18 insertions(+)
hooks/post-receive
