[SCM] PostGIS branch master updated. 3.6.0rc2-285-gc7e5cf9a2
git at osgeo.org
git at osgeo.org
Wed Jan 14 23:54:04 PST 2026
the project "PostGIS".
via c7e5cf9a28d1c722da516b87cd033b846212721e (commit)
from 013e9b0fd9c37f5d03e32231f81b8e8ba2c9f9dd (commit)
revisions in full, below.
commit c7e5cf9a28d1c722da516b87cd033b846212721e
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 15 08:53:36 2026 +0100
Make ptarray_contains_point wrap ptarray_contains_point_partial
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index cce30d5b2..54cfe875e 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -754,73 +754,8 @@ ptarray_is_closed_z(const POINTARRAY *in)
int
ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt)
- const POINT2D *seg1, *seg2;
int wn = 0;
- seg1 = getPoint2d_cp(pa, 0);
- seg2 = getPoint2d_cp(pa, pa->npoints-1);
- if (!p2d_same(seg1, seg2))
- lwerror("ptarray_contains_point called on unclosed ring");
- for (uint32_t i = 1; i < pa->npoints; i++)
- double side, ymin, ymax;
- seg2 = getPoint2d_cp(pa, i);
- /* Zero length segments are ignored. */
- if (p2d_same(seg1, seg2))
- seg1 = seg2;
- continue;
- ymin = FP_MIN(seg1->y, seg2->y);
- ymax = FP_MAX(seg1->y, seg2->y);
- /* Only test segments in our vertical range */
- if (pt->y > ymax || pt->y < ymin)
- seg1 = seg2;
- continue;
- side = lw_segment_side(seg1, seg2, pt);
- * A point on the boundary of a ring is not contained.
- * WAS: if (fabs(side) < 1e-12), see #852
- if ((side == 0) && lw_pt_in_seg(pt, seg1, seg2))
- return LW_BOUNDARY;
- * If the point is to the left of the line, and it's rising,
- * then the line is to the right of the point and
- * circling counter-clockwise, so increment.
- if ((side < 0) && (seg1->y <= pt->y) && (pt->y < seg2->y))
- wn++;
- * If the point is to the right of the line, and it's falling,
- * then the line is to the right of the point and circling
- * clockwise, so decrement.
- else if ( (side > 0) && (seg2->y <= pt->y) && (pt->y < seg1->y) )
- wn--;
- seg1 = seg2;
- /* wn == 0 => Outside, wn != 0 => Inside */
- return wn == 0 ? LW_OUTSIDE : LW_INSIDE;
+ return ptarray_contains_point_partial(pa, pt, LW_TRUE, &wn);
int
Summary of changes:
liblwgeom/ptarray.c | 67 +----------------------------------------------------
1 file changed, 1 insertion(+), 66 deletions(-)
hooks/post-receive
