[PostGIS] #5689: Set PostGIS windows bundle environment for service rather than machine.
trac at osgeo.org
Thu Jan 15 01:27:12 PST 2026
Reporter: slefranc | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Packaging
Component: install | Version: 3.4.x
Resolution: | Keywords: windows
Comment (by groenebijgeo):
Hi, this week I stumbeld upon this issue (or a similar issue). I have both
QGIS and PostgreSQL (15.15) with PostGIS (3.6.1) installed on a Windows
machine. I use the recommended EDB installer for PostgreSQl and PostGIS.
I started experimenting with GDAL ogr2ogr in a terminal. The latest QGIS
LTR (currently 3.40.14) comes with GDAL 3.12.1 and with PROJ 9.7.1
I noticed ogr2or had troubles with CRS, e.g. certain WFS conversions
resulted in layers with CRS:99999. Running ogr2ogr from I got these
errors:
ERROR 1: PROJ: proj_create_from_database: C:\Program
Files\PostgreSQL\15\share\contrib\postgis-3.6\proj\proj.db contains
DATABASE.LAYOUT.VERSION.MINOR = 2 whereas a number >= 6 is expected. It
comes from another PROJ installation.
ERROR 1: PROJ: proj_create: no database context specified
ERROR 1: Cannot parse CRS http://www.opengis.net/def/crs/EPSG/0/5482
I got multiple of these errors, al referring to different CRS numbers.
Looking into this I noticed that windows has a system environment variable
PROJ_LIB which points to a proj folder in the PostGIS installation. And
PostGIS comes with PROJ 8.2.1
Then, running a Terminal from within QGIS it adds another variable
PROJ_DATA pointing to the proj folder in QGIS.
Running ogr2ogr in this terminal instance I don't get the CRS errors.
This makes me assume the PROJ_LIB is causing errors (or PROJ 8.2.1 is?),
but I also found somewhere that PROJ_LIB actually is no longer relevant
for PROJ?
I also saw ticket #5188 which mentions something similar.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5689#comment:10>
