[SCM] PostGIS branch master updated. 3.6.0rc2-286-g8c656a9bc
git at osgeo.org
git at osgeo.org
Thu Jan 15 02:53:08 PST 2026
the project "PostGIS".
via 8c656a9bcefc6c41d61fa7bc9d2cea239ead8ccf (commit)
from c7e5cf9a28d1c722da516b87cd033b846212721e (commit)
revisions in full, below.
commit 8c656a9bcefc6c41d61fa7bc9d2cea239ead8ccf
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 15 11:52:36 2026 +0100
Portable debug-printing of uint64_t types
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 359ba1615..ae60d2132 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -688,7 +688,7 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
/* loop over each node within the edge's gbox */
nodes = lwt_be_getNodeWithinBox2D( topo, edgebox, &num_nodes,
LWT_COL_NODE_ALL, 0 );
- LWDEBUGF(1, "lwt_be_getNodeWithinBox2D returned %llu nodes", num_nodes);
+ LWDEBUGF(1, "lwt_be_getNodeWithinBox2D returned %" PRIu64 " nodes", num_nodes);
if (num_nodes == UINT64_MAX)
PGTOPO_BE_ERROR();
@@ -733,7 +733,7 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
/* loop over each edge within the edge's gbox */
edges = lwt_be_getEdgeWithinBox2D( topo, edgebox, &num_edges, LWT_COL_EDGE_ALL, 0 );
- LWDEBUGF(1, "lwt_be_getEdgeWithinBox2D returned %llu edges", num_edges);
+ LWDEBUGF(1, "lwt_be_getEdgeWithinBox2D returned %" PRIu64 " edges", num_edges);
if (num_edges == UINT64_MAX)
GEOSGeom_destroy(edgegg);
@@ -908,7 +908,7 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
GEOSFree(relate);
GEOSGeom_destroy(eegg);
- LWDEBUGF(1, "No edge crossing detected among the %llu candidate edges", num_edges);
+ LWDEBUGF(1, "No edge crossing detected among the %" PRIu64 " candidate edges", num_edges);
if ( edges ) _lwt_release_edges(edges, num_edges);
/* would be NULL if num_edges was 0 */
@@ -1098,7 +1098,7 @@ _lwt_EdgeSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge, LWPOINT* pt, int skipISOChe
LWDEBUGG(2, lwline_as_lwgeom(oldedge[0]->geom), "Edge to be split");
if ( ! *oldedge )
- LWDEBUGF(1, "lwt_be_getEdgeById returned NULL and set i=%llu", i);
+ LWDEBUGF(1, "lwt_be_getEdgeById returned NULL and set i=%" PRIu64 "", i);
if (i == UINT64_MAX)
PGTOPO_BE_ERROR();
@@ -1677,7 +1677,7 @@ _lwt_FindAdjacentEdges( LWT_TOPOLOGY* topo, LWT_ELEMID node, edgeend *data,
return 0;
- LWDEBUGF(1, "getEdgeByNode returned %llu edges, minaz=%g, maxaz=%g",
+ LWDEBUGF(1, "getEdgeByNode returned %" PRIu64 " edges, minaz=%g, maxaz=%g",
numedges, minaz, maxaz);
/* For each incident edge-end (1 or 2): */
@@ -1943,7 +1943,7 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
for ( i=0; i<num_signed_edge_ids; ++i )
LWT_ELEMID eid = signed_edge_ids[i];
- LWDEBUGF(2, "Edge %llu in ring is edge %" LWTFMT_ELEMID, i, eid);
+ LWDEBUGF(2, "Edge %" PRIu64 " in ring is edge %" LWTFMT_ELEMID, i, eid);
LWT_ISO_EDGE *edge = NULL;
POINTARRAY *epa;
for ( j=0; j<numedges; ++j )
@@ -2032,7 +2032,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
PGTOPO_BE_ERROR();
return -2;
- LWDEBUGF(1, "getRingEdges returned %llu edges", num_signed_edge_ids);
+ LWDEBUGF(1, "getRingEdges returned %" PRIu64 " edges", num_signed_edge_ids);
/* You can't get to the other side of an edge forming a ring */
for (i=0; i<num_signed_edge_ids; ++i) {
@@ -2199,7 +2199,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
PGTOPO_BE_ERROR();
return -2;
- LWDEBUGF(1, "_lwt_AddFaceSplit: lwt_be_getEdgeByFace(%" LWTFMT_ELEMID ") returned %llu edges", face, numfaceedges);
+ LWDEBUGF(1, "_lwt_AddFaceSplit: lwt_be_getEdgeByFace(%" LWTFMT_ELEMID ") returned %" PRIu64 " edges", face, numfaceedges);
if ( numfaceedges )
@@ -2988,7 +2988,7 @@ lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
PGTOPO_BE_ERROR();
return NULL;
- LWDEBUGF(1, "lwt_GetFaceGeometry: lwt_be_getEdgeByFace returned %llu edges", numfaceedges);
+ LWDEBUGF(1, "lwt_GetFaceGeometry: lwt_be_getEdgeByFace returned %" PRIu64 " edges", numfaceedges);
if ( numfaceedges == 0 )
@@ -3236,7 +3236,7 @@ lwt_GetFaceEdges(LWT_TOPOLOGY* topo, LWT_ELEMID face_id, LWT_ELEMID **out )
return -1;
if ( ! numfaceedges ) return 0; /* no edges in output */
- LWDEBUGF(1, "lwt_GetFaceEdges: lwt_be_getEdgeByFace returned %llu edges", numfaceedges);
+ LWDEBUGF(1, "lwt_GetFaceEdges: lwt_be_getEdgeByFace returned %" PRIu64 " edges", numfaceedges);
/* order edges by occurrence in face */
@@ -3399,7 +3399,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
if ( ! oldedge )
LWDEBUGF(1, "lwt_ChangeEdgeGeom: "
- "lwt_be_getEdgeById returned NULL and set i=%llu", i);
+ "lwt_be_getEdgeById returned NULL and set i=%" PRIu64 "", i);
PGTOPO_BE_ERROR();
@@ -3516,7 +3516,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
uint64_t numnodes;
nodes = lwt_be_getNodeWithinBox2D(topo, &mbox, &numnodes,
LWT_COL_NODE_ALL, 0);
- LWDEBUGF(1, "lwt_be_getNodeWithinBox2D returned %llu nodes", numnodes);
+ LWDEBUGF(1, "lwt_be_getNodeWithinBox2D returned %" PRIu64 " nodes", numnodes);
if (numnodes == UINT64_MAX)
_lwt_release_edges(oldedge, 1);
@@ -3599,7 +3599,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
PGTOPO_BE_ERROR();
return -1;
shell = _lwt_MakeRingShell(topo, signed_edge_ids, num_signed_edge_ids);
if ( ! shell ) {
@@ -3703,7 +3703,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
PGTOPO_BE_ERROR();
return -1;
if ( ! shell ) {
@@ -3784,7 +3784,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
/* ownership transferred to faces[] */
faces[facestoupdate++].mbr = updatedBox;
- LWDEBUGF(1, "%llu faces to update", facestoupdate);
+ LWDEBUGF(1, "%" PRIu64 " faces to update", facestoupdate);
if ( facestoupdate )
uint64_t updatedFaces = lwt_be_updateFacesById(topo, &(faces[0]), facestoupdate);
@@ -4121,7 +4121,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
edge = lwt_be_getEdgeById(topo, &edge_id, &i, LWT_COL_EDGE_ALL);
if (!edge)
PGTOPO_BE_ERROR();
@@ -4235,7 +4235,7 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
return -1;
- LWDEBUGF(1, "releasing %llu updateable edges in %p", nedges, upd_edge);
+ LWDEBUGF(1, "releasing %" PRIu64 " updateable edges in %p", nedges, upd_edge);
lwfree(upd_edge);
/* Id of face that will take up all the space previously
@@ -5496,7 +5496,7 @@ _lwt_SnapEdgeToExistingNode(
existingEdges[n] = NULL;
if ( existingEdgeId == 0 )
- LWDEBUGF(1, "Split component %llu is a new edge, computing edgeEndInfo", n);
+ LWDEBUGF(1, "Split component %" PRIu64 " is a new edge, computing edgeEndInfo", n);
// Compute nextCW and nextCCW of the split edge now
// incident to the split point
@@ -5537,7 +5537,7 @@ _lwt_SnapEdgeToExistingNode(
return -1;
- LWDEBUGF(1, "Azimuth of split component %llu edgeend [%.15g %.15g,%.15g %.15g] is %.15g",
+ LWDEBUGF(1, "Azimuth of split component %" PRIu64 " edgeend [%.15g %.15g,%.15g %.15g] is %.15g",
n, op.x, op.y, pt->x, pt->y, splitNodeEdgeEnds[n].myaz);
ret = _lwt_FindAdjacentEdges( topo, node->node_id, &(splitNodeEdgeEnds[n]), NULL, -1 );
if ( ! ret ) {
@@ -5547,14 +5547,14 @@ _lwt_SnapEdgeToExistingNode(
node->node_id, edge->edge_id);
return -1;
- LWDEBUGF(1, "Component %llu of split edge %" LWTFMT_ELEMID
+ LWDEBUGF(1, "Component %" PRIu64 " of split edge %" LWTFMT_ELEMID
" next CW is %" LWTFMT_ELEMID ", next CCW is %" LWTFMT_ELEMID,
n, edge->edge_id, splitNodeEdgeEnds[n].nextCW, splitNodeEdgeEnds[n].nextCCW);
else
- LWDEBUGF(1, "Split component %llu matches existing edge %" LWTFMT_ELEMID
+ LWDEBUGF(1, "Split component %" PRIu64 " matches existing edge %" LWTFMT_ELEMID
" (%s)", n, existingEdgeId, forward ? "forward" : "backward" );
/* Get existing edge */
for ( uint64_t t=0; t<splitNodeEdges->numEdges; t++ )
@@ -5774,7 +5774,7 @@ _lwt_SnapEdgeToExistingNode(
LWDEBUGF(1, "Looking for next CCW edge of split edge %"
LWTFMT_ELEMID " on common node %" LWTFMT_ELEMID
- " having %llu attached edges",
+ " having %" PRIu64 " attached edges",
edge->edge_id,
commonNodeID, commonNodeEdges->numEdges
@@ -6907,7 +6907,7 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
if ( num )
- LWDEBUGF(1, "New point is within %.15g units of %llu nodes", tol, num);
+ LWDEBUGF(1, "New point is within %.15g units of %" PRIu64 " nodes", tol, num);
/* Order by distance if there are more than a single return */
if ( num > 1 )
@@ -6967,7 +6967,7 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
PGTOPO_BE_ERROR();
return -1;
- LWDEBUGF(1, "New point is within %.15g units of %llu edges", tol, num);
+ LWDEBUGF(1, "New point is within %.15g units of %" PRIu64 " edges", tol, num);
if ( num )
id = _lwt_SplitAllEdgesToNewNode(topo, edges, num, lwgeom_as_lwpoint(pt), tol, moved);
@@ -7326,7 +7326,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
PGTOPO_BE_ERROR();
return NULL;
- LWDEBUGF(1, "Line has %u points, its bbox intersects %llu edges bboxes",
+ LWDEBUGF(1, "Line has %u points, its bbox intersects %" PRIu64 " edges bboxes",
line->points->npoints, numedges);
if ( numedges )
@@ -7370,7 +7370,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
PGTOPO_BE_ERROR();
return NULL;
- LWDEBUGF(1, "Line bbox intersects %llu nodes bboxes", numnodes);
+ LWDEBUGF(1, "Line bbox intersects %" PRIu64 " nodes bboxes", numnodes);
if ( numnodes )
/* collect those whose distance from us is < tol */
@@ -7605,7 +7605,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
size_t sz;
char *wkt1 = lwgeom_to_wkt(g, WKT_EXTENDED, 15, &sz);
- LWDEBUGF(1, "Component %llu of split line is: %s", i, wkt1);
+ LWDEBUGF(1, "Component %" PRIu64 " of split line is: %s", i, wkt1);
lwfree(wkt1);
#endif
@@ -7639,11 +7639,11 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
if ( ! id )
- LWDEBUGF(1, "Component %llu of split line collapsed", i);
+ LWDEBUGF(1, "Component %" PRIu64 " of split line collapsed", i);
continue;
- LWDEBUGF(1, "Component %llu of split line is %s edge %" LWTFMT_ELEMID,
+ LWDEBUGF(1, "Component %" PRIu64 " of split line is %s edge %" LWTFMT_ELEMID,
i, forward ? "forward" : "backward", id);
ids[num++] = forward ? id : -id; /* TODO: skip duplicates */
Summary of changes:
liblwgeom/topo/lwgeom_topo.c | 58 ++++++++++++++++++++++----------------------
1 file changed, 29 insertions(+), 29 deletions(-)
hooks/post-receive
