[SCM] PostGIS branch stable-3.6 updated. 3.6.1-14-g928180043
Thu Jan 15 22:13:18 PST 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  928180043ce24b69d35e9c1e8fc968b2adff0e41 (commit)
      from  dff60191e1c48d4c1b50482fe8cd527284db9d9c (commit)
revisions in full, below.
commit 928180043ce24b69d35e9c1e8fc968b2adff0e41
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Fri Jan 16 06:25:48 2026 +0100
    test(sfcgal): Fix Buffer3D tests against SFCGAL 2.3.0
    SFCGAL 2.3.0 improves sphere generation using icosahedron algorithm to
    avoid float issue.
    The geometry is slightly different and test must be adapted accordingly.
diff --git a/sfcgal/regress/sfcgal_v2.sql b/sfcgal/regress/sfcgal_v2.sql
index aedb60a49..49ba93a7b 100644
--- a/sfcgal/regress/sfcgal_v2.sql
+++ b/sfcgal/regress/sfcgal_v2.sql
@@ -11,7 +11,7 @@ SELECT 'CG_3DScaleAroundCenter', ST_AsText(ST_ReducePrecision(CG_3DScaleAroundCe
 SELECT 'CG_Translate', ST_AsText(CG_Translate('LINESTRING(1 1, 2 2)', 1, -1), 0);
 SELECT 'CG_3DTranslate', ST_AsText(CG_3DTranslate('POINT(1 1 1)', 1, -1, 2), 0);
 SELECT 'CG_StraightSkeletonPartition', ST_AsText(ST_Collect(dmp.geom), 2) FROM ST_Dump(CG_StraightSkeletonPartition('POLYGON((0 0, 4 0, 2 2, 0 0))', true)) as dmp;
-SELECT 'CG_3DBuffer', ST_AsText(CG_3DBuffer('POINT(0 0 0)', 1, 8, 0), 2);
+SELECT 'CG_3DBuffer', ST_GeometryType(CG_3DBuffer('POINT(0 0 0)', 1, 8, 0));
 SELECT 'CG_Rotate', ST_AsText(ST_ReducePrecision(CG_Rotate('LINESTRING  EMPTY', pi()/2), 0.1));
 SELECT 'CG_2DRotate', ST_AsText(CG_2DRotate('POINT EMPTY', pi()/2, 1, 1), 0);
 SELECT 'CG_3DRotate', ST_AsText(ST_ReducePrecision(CG_3DRotate('POINT EMPTY', pi()/2, 0, 0, 1), 0.1));
diff --git a/sfcgal/regress/sfcgal_v2_expected b/sfcgal/regress/sfcgal_v2_expected
index 4560a0926..7696edd07 100644
--- a/sfcgal/regress/sfcgal_v2_expected
+++ b/sfcgal/regress/sfcgal_v2_expected
@@ -10,7 +10,7 @@ CG_3DScaleAroundCenter|POINT Z (1.5 1.5 1.5)
 CG_Translate|LINESTRING(2 0,3 1)
 CG_3DTranslate|POINT Z (2 0 3)
 CG_StraightSkeletonPartition|MULTIPOLYGON(((0 0,2 0.83,2 2)),((4 0,2 0.83,0 0)),((2 2,2 0.83,4 0)))
-CG_3DBuffer|POLYHEDRALSURFACE Z (((0 0 1,0.5 -0.5 0.71,0 -0.71 0.71,0 0 1)),((0 0 1,0.71 -4.33e-17 0.71,0.5 -0.5 0.71,0 0 1)),((0 0 1,0.5 0.5 0.71,0.71 -4.33e-17 0.71,0 0 1)),((0 0 1,8.66e-17 0.71 0.71,0.5 0.5 0.71,0 0 1)),((0 0 1,-0.5 0.5 0.71,8.66e-17 0.71 0.71,0 0 1)),((0 0 1,-0.71 1.3e-16 0.71,-0.5 0.5 0.71,0 0 1)),((0 0 1,-0.5 -0.5 0.71,-0.71 1.3e-16 0.71,0 0 1)),((0 0 1,0 -0.71 0.71,-0.5 -0.5 0.71,0 0 1)),((0 -0.71 0.71,0.5 -0.5 0.71,0.71 -0.71 6.12e-17,0 -0.71 0.71)),((0 -0.71 0.71,0.71 -0.71 6.12e-17,0 -1 6.12e-17,0 -0.71 0.71)),((0.5 -0.5 0.71,0.71 -4.33e-17 0.71,1 -6.12e-17 6.12e-17,0.5 -0.5 0.71)),((0.5 -0.5 0.71,1 -6.12e-17 6.12e-17,0.71 -0.71 6.12e-17,0.5 -0.5 0.71)),((0.71 -4.33e-17 0.71,0.5 0.5 0.71,0.71 0.71 6.12e-17,0.71 -4.33e-17 0.71)),((0.71 -4.33e-17 0.71,0.71 0.71 6.12e-17,1 -6.12e-17 6.12e-17,0.71 -4.33e-17 0.71)),((0.5 0.5 0.71,8.66e-17 0.71 0.71,1.22e-16 1 6.12e-17,0.5 0.5 0.71)),((0.5 0.5 0.71,1.22e-16 1 6.12e-17,0.71 0.71 6.12e-17,0.5 0.5 0.71)),((8.66e-17
  0.71 0.71,-0.5 0.5 0.71,-0.71 0.71 6.12e-17,8.66e-17 0.71 0.71)),((8.66e-17 0.71 0.71,-0.71 0.71 6.12e-17,1.22e-16 1 6.12e-17,8.66e-17 0.71 0.71)),((-0.5 0.5 0.71,-0.71 1.3e-16 0.71,-1 1.84e-16 6.12e-17,-0.5 0.5 0.71)),((-0.5 0.5 0.71,-1 1.84e-16 6.12e-17,-0.71 0.71 6.12e-17,-0.5 0.5 0.71)),((-0.71 1.3e-16 0.71,-0.5 -0.5 0.71,-0.71 -0.71 6.12e-17,-0.71 1.3e-16 0.71)),((-0.71 1.3e-16 0.71,-0.71 -0.71 6.12e-17,-1 1.84e-16 6.12e-17,-0.71 1.3e-16 0.71)),((-0.5 -0.5 0.71,0 -0.71 0.71,0 -1 6.12e-17,-0.5 -0.5 0.71)),((-0.5 -0.5 0.71,0 -1 6.12e-17,-0.71 -0.71 6.12e-17,-0.5 -0.5 0.71)),((0 -1 6.12e-17,0.71 -0.71 6.12e-17,0.5 -0.5 -0.71,0 -1 6.12e-17)),((0 -1 6.12e-17,0.5 -0.5 -0.71,0 -0.71 -0.71,0 -1 6.12e-17)),((0.71 -0.71 6.12e-17,1 -6.12e-17 6.12e-17,0.71 -4.33e-17 -0.71,0.71 -0.71 6.12e-17)),((0.71 -0.71 6.12e-17,0.71 -4.33e-17 -0.71,0.5 -0.5 -0.71,0.71 -0.71 6.12e-17)),((1 -6.12e-17 6.12e-17,0.71 0.71 6.12e-17,0.5 0.5 -0.71,1 -6.12e-17 6.12e-17)),((1 -6.12e-17 6.12e-17,0.5 0.5 -0.71,0.
 71 -4.33e-17 -0.71,1 -6.12e-17 6.12e-17)),((0.71 0.71 6.12e-17,1.22e-16 1 6.12e-17,8.66e-17 0.71 -0.71,0.71 0.71 6.12e-17)),((0.71 0.71 6.12e-17,8.66e-17 0.71 -0.71,0.5 0.5 -0.71,0.71 0.71 6.12e-17)),((1.22e-16 1 6.12e-17,-0.71 0.71 6.12e-17,-0.5 0.5 -0.71,1.22e-16 1 6.12e-17)),((1.22e-16 1 6.12e-17,-0.5 0.5 -0.71,8.66e-17 0.71 -0.71,1.22e-16 1 6.12e-17)),((-0.71 0.71 6.12e-17,-1 1.84e-16 6.12e-17,-0.71 1.3e-16 -0.71,-0.71 0.71 6.12e-17)),((-0.71 0.71 6.12e-17,-0.71 1.3e-16 -0.71,-0.5 0.5 -0.71,-0.71 0.71 6.12e-17)),((-1 1.84e-16 6.12e-17,-0.71 -0.71 6.12e-17,-0.5 -0.5 -0.71,-1 1.84e-16 6.12e-17)),((-1 1.84e-16 6.12e-17,-0.5 -0.5 -0.71,-0.71 1.3e-16 -0.71,-1 1.84e-16 6.12e-17)),((-0.71 -0.71 6.12e-17,0 -1 6.12e-17,0 -0.71 -0.71,-0.71 -0.71 6.12e-17)),((-0.71 -0.71 6.12e-17,0 -0.71 -0.71,-0.5 -0.5 -0.71,-0.71 -0.71 6.12e-17)),((0 0 -1,0 -0.71 -0.71,0.5 -0.5 -0.71,0 0 -1)),((0 0 -1,0.5 -0.5 -0.71,0.71 -4.33e-17 -0.71,0 0 -1)),((0 0 -1,0.71 -4.33e-17 -0.71,0.5 0.5 -0.71,0 0 -1)),((0 0
 -1,0.5 0.5 -0.71,8.66e-17 0.71 -0.71,0 0 -1)),((0 0 -1,8.66e-17 0.71 -0.71,-0.5 0.5 -0.71,0 0 -1)),((0 0 -1,-0.5 0.5 -0.71,-0.71 1.3e-16 -0.71,0 0 -1)),((0 0 -1,-0.71 1.3e-16 -0.71,-0.5 -0.5 -0.71,0 0 -1)),((0 0 -1,-0.5 -0.5 -0.71,0 -0.71 -0.71,0 0 -1)))
+CG_3DBuffer|ST_PolyhedralSurface
 CG_Rotate|LINESTRING EMPTY
 CG_2DRotate|POINT EMPTY
 CG_3DRotate|POINT Z EMPTY
Summary of changes:
 sfcgal/regress/sfcgal_v2.sql      | 2 +-
 sfcgal/regress/sfcgal_v2_expected | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
