[PostGIS] #6037: st_union with gridSize produces unexpected result
trac at osgeo.org
Fri Jan 16 04:30:34 PST 2026
Reporter: asgerpetersen | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.6.x
Keywords: |
`ST_Union(a, b, gridSize)` can return a polygon that is smaller than both
input polygons, even when one polygon is `st_within` the other, the
geometries are fully noded and all input coordinates lie on the specified
grid.
`ST_Union(a, b)` produces the expected result.
The documentation does not clearly state what st_union with gridSize is
supposed to do except snapping result vertices to a grid, but I think this
result is unexpected and hard to reason about.
-- These polygons are fully noded and have cm precision (0.01). B is
within A
with geoms as (
select ST_GeometryFromText('POLYGON ((450329.74 6273269.32, 450329.79
6273269.33, 450330.65 6273269.56, 450331.07 6273269.67, 450380.84
6273282.58, 450390.92 6273278.05, 450398.23 6273274.76, 450558.14
6273202.85, 449681.36 6273101.1, 449997.83 6273183.21, 449997.84
6273183.21, 450289.26 6273258.82, 450317.49 6273266.14, 450329.74
6273269.32))', 25832) as a,
ST_GeometryFromText('POLYGON ((450329.74 6273269.32, 450317.5
6273266.14, 450317.49 6273266.14, 450329.74 6273269.32))', 25832) as b
unions as (
select
st_union(a,b) as st_union,
st_union(a,b, 0.01) as st_union_gridsize
from geoms
select
st_area(a) area_a,
st_within(b, a), -- B is within A! So st_union(A, B) == A
st_equals(a, st_union) a_equals_union, -- A == st_union(A,B)
st_equals(a, st_union_gridsize) a_equals_union_gridsize, -- Not
equal!
st_area(st_union_gridsize) area_union_gridsize -- Note that the
unioned area is smaller than the area of A alone
from geoms, unions;
Tested on `POSTGIS="3.6.1 0" [EXTENSION] PGSQL="180"
GEOS="3.13.1-CAPI-1.19.2" PROJ="9.6.0 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.6.0)
LIBXML="2.13.9" LIBJSON="0.18" LIBPROTOBUF="1.5.2" WAGYU="0.5.0
(Internal)"`
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6037>
