[PostGIS] #6038: Using public.geometry_columns causes 'could not open relation with OID 188954716' after drop geometry tables
trac at osgeo.org
Tue Jan 20 05:15:54 PST 2026
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone:
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
This problems seems NOT be related topology.droptopology. You get the same
problem if you use "drop SCHEMA gsk_utdata_25_784 CASCADE;" and not
"SELECT topology.createtopology('t1',4258);"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6038#comment:5>
