[PostGIS] #6038: Using public.geometry_columns causes 'could not open relation with OID 188954716' after drop geometry tables
trac at osgeo.org
Fri Jan 23 03:36:13 PST 2026
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone:
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
The problem seems not to be related to public.geometry_columns changing
OID
[local] lop at t1=# SELECT 'public.geometry_columns'::regclass::oid;
oid
188950672
(1 row)
[local] lop at t1=# select SRID from public.geometry_columns where
(f_table_schema = 't1') and f_table_name = 'edge_data' and
f_geometry_column = 'geom';
ERROR: XX000: could not open relation with OID 188967127
ERROR: 25P02: current transaction is aborted, commands ignored until end
of transaction block
[local] lop at t1=# \q
lop at Larss-MacBook-Pro-2 rmp_ws_03 % psql t1
Null display is "[NULL]".
Expanded display is used automatically.
psql (16.10 (Homebrew))
Type "help" for help.
oid
188950672
(1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6038#comment:6>
