[SCM] PostGIS branch master updated. 3.6.0rc2-295-gda86ae2c0
Tue Jan 20 13:50:19 PST 2026
the project "PostGIS".
       via  da86ae2c0914287fe2914e28aea5360dc8af0131 (commit)
       via  6ba2fd5a2f84409fd7ee069411113db562b6ddd2 (commit)
      from  35d31a02d394a2ba5394b1116f78676a286e8d17 (commit)
revisions in full, below.
commit da86ae2c0914287fe2914e28aea5360dc8af0131
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Thu Jun 5 10:30:15 2025 +0200
    fix(TriangulatedSurface): TIN can be closed as PolyhedralSurface
diff --git a/liblwgeom/lwgeom.c b/liblwgeom/lwgeom.c
index c6562b5fa..b1a557feb 100644
--- a/liblwgeom/lwgeom.c
+++ b/liblwgeom/lwgeom.c
@@ -1451,8 +1451,13 @@ int lwgeom_dimension(const LWGEOM *geom)
 	case CURVEPOLYTYPE:
 	case MULTISURFACETYPE:
 	case MULTIPOLYGONTYPE:
-	case TINTYPE:
 		return 2;
+	case TINTYPE:
+		/* A closed tin surface contains a volume. */
+		int closed = lwtin_is_closed((LWTIN*)geom);
+		return ( closed ? 3 : 2 );
 	case POLYHEDRALSURFACETYPE:
 		/* A closed polyhedral surface contains a volume. */
commit 6ba2fd5a2f84409fd7ee069411113db562b6ddd2
Date:   Thu Jun 5 10:29:41 2025 +0200
    test(TriangulatedSurface): Add tests
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index a959ad92f..a89b77bfc 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -119,6 +119,7 @@ TESTS += \
 	$(top_srcdir)/regress/core/temporal \
 	$(top_srcdir)/regress/core/temporal_knn \
 	$(top_srcdir)/regress/core/tickets \
+	$(top_srcdir)/regress/core/triangulatedsurface \
 	$(top_srcdir)/regress/core/twkb \
 	$(top_srcdir)/regress/core/typmod \
 	$(top_srcdir)/regress/core/wkb \
diff --git a/regress/core/triangulatedsurface.sql b/regress/core/triangulatedsurface.sql
new file mode 100644
index 000000000..cf0892e49
--- /dev/null
+++ b/regress/core/triangulatedsurface.sql
@@ -0,0 +1,40 @@
+-- ST_Dimension on 2D: not closed
+SELECT 'dimension_01', ST_Dimension('TIN(((0 0,1 1,0 1,0 0)))'::geometry);
+SELECT 'dimension_02', ST_Dimension('GEOMETRYCOLLECTION(TIN(((0 0,1 1,0 1,0 0))))'::geometry);
+-- ST_Dimension on 3D: closed
+SELECT 'dimension_03', ST_Dimension('TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))'::geometry);
+SELECT 'dimension_04', ST_Dimension('GEOMETRYCOLLECTION(TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0))))'::geometry);
+-- ST_Dimension on 4D: closed
+SELECT 'dimension_05', ST_Dimension('TIN(((0 0 0 0,0 0 1 0,0 1 0 2,0 0 0 0)),((0 0 0 0,0 1 0 0,1 0 0 4,0 0 0 0)),((0 0 0 0,1 0 0 0,0 0 1 6,0 0 0 0)),((1 0 0 0,0 1 0 0,0 0 1 0,1 0 0 0)))'::geometry);
+SELECT 'dimension_06', ST_Dimension('GEOMETRYCOLLECTION(TIN(((0 0 0 0,0 0 1 0,0 1 0 2,0 0 0 0)),((0 0 0 0,0 1 0 0,1 0 0 4,0 0 0 0)),((0 0 0 0,1 0 0 0,0 0 1 6,0 0 0 0)),((1 0 0 0,0 1 0 0,0 0 1 0,1 0 0 0))))'::geometry);
+-- ST_Dimension on 3D: invalid polyedron (a single edge is shared 3 times)
+SELECT 'dimension_07', ST_Dimension('TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,0 1 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))'::geometry);
+-- ST_Dimension on 3D: invalid polyedron (redundant point inside each face)
+SELECT 'dimension_08', ST_Dimension('TIN(((0 0 0,1 0 0,1 0 0,0 0 0)),((0 0 1,1 0 1,1 0 1,0 0 1)),((0 0 2,1 0 2,1 0 2,0 0 2)),((0 0 3,1 0 3,1 0 3,0 0 3)))'::geometry);
+-- ST_NumPatches
+SELECT 'numpatches_01', ST_NumPatches('TIN EMPTY'::geometry);
+SELECT 'numpatches_02', ST_NumPatches('TIN(((0 0,0 0,0 1,0 0)))'::geometry);
+SELECT 'numpatches_03', ST_NumPatches('TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))'::geometry);
+-- ST_PatchN
+SELECT 'patchN_01', ST_AsEWKT(ST_patchN('TIN EMPTY'::geometry, 1));
+SELECT 'patchN_02', ST_AsEWKT(ST_patchN('TIN(((0 0,0 0,0 1,0 0)))'::geometry, 1));
+SELECT 'patchN_03', ST_AsEWKT(ST_patchN('TIN(((0 0,0 0,0 1,0 0)))'::geometry, 0));
+SELECT 'patchN_04', ST_AsEWKT(ST_patchN('TIN(((0 0,0 0,0 1,0 0)))'::geometry, 2));
+SELECT 'patchN_05', ST_AsEWKT(ST_patchN('TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))'::geometry, 2));
+-- ST_NumGeometries
+SELECT 'numgeometries_01', ST_NumGeometries('TIN EMPTY'::geometry);
+SELECT 'numgeometries_02', ST_NumGeometries('TIN(((0 0,0 0,0 1,0 0)))'::geometry);
+SELECT 'numgeometries_03', ST_NumGeometries('TIN(((0 0 0,0 0 1,0 1 0,0 0 0)),((0 0 0,0 1 0,1 0 0,0 0 0)),((0 0 0,1 0 0,0 0 1,0 0 0)),((1 0 0,0 1 0,0 0 1,1 0 0)))'::geometry);
+-- ST_GeometryN
+SELECT 'geometryN_01', ST_AsEWKT(ST_GeometryN('TIN EMPTY'::geometry, 1));
+SELECT 'geometryN_02', ST_AsEWKT(ST_GeometryN('TIN(((0 0,0 0,0 1,0 0)))'::geometry, 1));
+SELECT 'geometryN_03', ST_AsEWKT(ST_GeometryN('TIN(((0 0,0 0,0 1,0 0)))'::geometry, 0));
+SELECT 'geometryN_04', ST_AsEWKT(ST_GeometryN('TIN(((0 0,0 0,0 1,0 0)))'::geometry, 2));
diff --git a/regress/core/triangulatedsurface_expected b/regress/core/triangulatedsurface_expected
index 000000000..ab5d737f8
--- /dev/null
+++ b/regress/core/triangulatedsurface_expected
@@ -0,0 +1,23 @@
+dimension_01|2
+dimension_02|2
+dimension_03|3
+dimension_04|3
+dimension_05|3
+dimension_06|3
+dimension_07|2
+dimension_08|2
+numpatches_01|0
+numpatches_02|1
+numpatches_03|4
+patchN_01|
+patchN_02|TRIANGLE((0 0,0 0,0 1,0 0))
+patchN_03|
+patchN_04|
+patchN_05|TRIANGLE((0 0 0,0 1 0,1 0 0,0 0 0))
+numgeometries_01|0
+numgeometries_02|1
+numgeometries_03|1
+geometryN_01|
+geometryN_02|TIN(((0 0,0 0,0 1,0 0)))
+geometryN_03|
+geometryN_04|
Summary of changes:
 liblwgeom/lwgeom.c                                 |  7 +++-
 regress/core/tests.mk.in                           |  1 +
 regress/core/triangulatedsurface.sql               | 40 ++++++++++++++++++++++
 ...rface_expected => triangulatedsurface_expected} |  6 ++--
 4 files changed, 50 insertions(+), 4 deletions(-)
 create mode 100644 regress/core/triangulatedsurface.sql
 copy regress/core/{polyhedralsurface_expected => triangulatedsurface_expected} (69%)
hooks/post-receive
