[PostGIS] #5989: ST_Distance error on CurvePolygon
trac at osgeo.org
Wed Jan 21 05:28:38 PST 2026
Reporter: pramsey | Owner: pramsey
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 3.3.9
Component: postgis | Version: 3.3.x
Resolution: | Keywords:
Changes (by tiiipponen):
* resolution: fixed =>
* status: closed => reopened
Comment:
Continuation of ticket #5989 ST_Distance error on CurvePolygon
The following query should give a distance of about 14.5 m, but the result
is 0 m.
There is also another, much more complicated example, but hopefully it
will also be solved if this one is solved.
SELECT
ST_Distance(
ST_GeomFromText('MULTISURFACE(CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(25493681.3085
6678739.6419,25493637.8256 6678776.2541,25493599.9716
6678818.6604),(25493599.9716 6678818.6604,25493583.8816
6678839.494,25493590.9591 6678844.9594,25493566.9698
6678851.9051,25493526.5793 6678861.0985,25493487.3853
6678868.2546,25493447.392 6678871.7846,25493429.5033
6678876.6846,25493435.0147 6678857.4594,25493454.9254
6678821.6192,25493452.4867 6678816.1292,25493402.3226
6678828.2153,25493354.7526 6678837.8291,25493349.0217
6678838.9873,25493310.914 6678843.6926,25493306.3784
6678859.9295,25493294.1011 6678858.7864,25493169.9028
6678847.2212,25493127.549 6678843.2773,25493057.8888
6678834.6763,25493017.4547 6678826.7261,25492928.2395
6678821.5524,25492909.1067 6678795.0681,25492946.9544
6678794.8193,25492967.1292 6678794.6866,25493010.8878
6678795.9163,25493111.5564 6678804.3109,25493113.4069
6678799.5694,25493134.2375 6678806.0729),CIRCULARSTRING(25493134.2375
6678806.0729,25493223.038 6678812.0533,25493311.4919
6678802.1948,25493317.3589 6678800.9679,25493323.2107
6678799.6707),(25493323.2107 6678799.6707,25493362.6615
6678792.3924,25493364.6948 6678785.173,25493375.0512
6678781.6008,25493404.9736 6678771.2798),CIRCULARSTRING(25493404.9736
6678771.2798,25493486.8049 6678737.6728,25493566.8862
6678700.0859),(25493566.8862 6678700.0859,25493574.903
6678714.0761,25493600.2214 6678702.8803,25493654.1114
6678670.2493,25493669.7219 6678659.2147,25493677.0288
6678653.353,25493684.6468 6678648.4119,25493724.0447
6678623.7638,25493800.1925 6678583.5847,25493805.6261
6678586.1292,25493811.9258 6678582.3016,25493812.8413
6678583.0522,25493846.581 6678558.6541,25493884.2653
6678531.6272,25493900.9168 6678580.1258,25493830.7852
6678630.9518,25493789.0848 6678661.2736,25493746.1612
6678692.485,25493686.5413 6678735.8369,25493681.3085 6678739.6419))))',
3879)
,ST_GeomFromText('POLYGON ((25492929.752797972
6678919.124091367,25493008.675235115 6678876.783133076,25493098.02917443
6678854.33589699,25493139.669701554 6678977.913508233,25493122.946292613
6679011.427315322,25493050.53388224 6679068.791126598,25493140.33593199
6679140.958135231,25492931.688606273 6679401.2946243705,25492799.289171
6679295.949040241,25492651.5177725 6679115.144800108,25492929.752797972
6678919.124091367))', 3879)
) AS dist
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5989#comment:25>
