[SCM] PostGIS branch stable-3.6 updated. 3.6.1-18-g4abcddfda
Tue Jan 27 13:25:13 PST 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  4abcddfda4c8bbb6055b4489624b561613a855f3 (commit)
      from  d063e2a19fa045818bdc226ec8da6dbf155d6310 (commit)
revisions in full, below.
commit 4abcddfda4c8bbb6055b4489624b561613a855f3
Author: bdreiss <bd_reiss at gmx.at>
Date:   Tue Jan 27 12:39:28 2026 -0800
    The geodetic flag was queried after gser has been freed
    ################################################### BUG REPORT ##################################################
    ### DESCRITPION ###
    The geodetic flag was queried after gser has been freed in line 143, leading to a use-after-free bug. This means the behaviour is undefined and it is not clear, which branch will be taken (and therefor, whether geometry or geography is returned). Below you find the output from gdb can be seen, that confirms that a) the point is indeed inserted with the wrong flag and b) also after selecting the point from the table remains unset. Issues when using SQL could not be produced.
    ### SETUP IN PG ###
    CREATE EXTENSION postgis;
    CREATE TABLE test_geog (id SERIAL PRIMARY KEY, geog geography(POINT, 4326));
    INSERT INTO test_geog (geog) VALUES (ST_GeogFromText('SRID=4326;POINT(-77.0092 38.889588)'));
    ### GDB OUPUT AND STEPS TO REPRODUCE ###
    postgres at localhost:~$ gdb --args /usr/local/pgsql/bin/postgres --single -D $PGDATA postgres
    (gdb) break gserialized_typmod.c:143
    (gdb) break gserialized_typmod.c:150
    (gdb) break geography_out
    (gdb) run
    backend> INSERT INTO test_geog (geog) VALUES (ST_GeogFromText('SRID=4326;MULTIPOINT EMPTY'));
    Breakpoint 1, postgis_valid_typmod (gser=0x58f991a3f378, typmod=1107460) at gserialized_typmod.c:143
    143     gserialized_typmod.c: No such file or directory.
    (gdb) call gserialized_is_geodetic(gser)
    $1 = 1
    (gdb) c
    Continuing.
    Breakpoint 2, postgis_valid_typmod (gser=0x58f991a8e150, typmod=1107460) at gserialized_typmod.c:151
    151     in gserialized_typmod.c
    $2 = 0
    (gdb) c
    Continuing.
    backend>
    backend> INSERT INTO test_geog (geog) VALUES (ST_GeogFromText('SRID=4326;POINT(-77.0092 38.889588)'));
    Breakpoint 2, postgis_valid_typmod (gser=0x58f991a3dca8, typmod=1107460) at gserialized_typmod.c:151
    $4 = 1
    (gdb) c
    Continuing.
    backend>
    backend> select geog from test_geog where id=1;
             1: geog        (typeid = 14296, len = -1, typmod = 1107460, byval = f)
    Breakpoint 3, geography_out (fcinfo=0x7ffe871b40e0) at /usr/local/pgsql/include/server/postgres.h:319
    319             return (Pointer) X;
    (gdb) set $gser = (GSERIALIZED *) pg_detoast_datum((void *) fcinfo->args[0].value)
    (gdb) call gserialized_is_geodetic($gser)
    $7 = 0
    (gdb) c
    Continuing.
             1: geog = "0101000020E6100000000000000000F87F000000000000F87F" (typeid = 14296, len = -1, typmod = 1107460, byval = f)
    backend> select geog from test_geog where id=2;
    $8 = 1
    (gdb) c
    Continuing.
             1: geog = "0101000020E6100000E3C798BB964053C000750305DE714340" (typeid = 14296, len = -1, typmod = 1107460, byval = f)
    backend>
    ### INFO ###
    postgres=# SELECT version();
                                                  version
     PostgreSQL 18.1 on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14+deb12u1) 12.2.0, 64-bit
    (1 row)
    postgres=# SELECT postgis_full_version();
     POSTGIS="3.6.1 f533623" [EXTENSION] PGSQL="180" GEOS="3.11.1-CAPI-1.17.1" PROJ="9.1.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/home/postgres/.loc
    al/share/proj DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.1.1) LIBXML="2.9.14" LIBJSON="0.16" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
    (1 row)
    COMPILE FLAGS USED:
    CC=clang ./configure --with-pgconfig=/usr/bin/pg_config CFLAGS="-O0 -g -fsanitize=address -fno-omit-frame-pointer" LDFLAGS="-fsanitize=address"
diff --git a/postgis/gserialized_typmod.c b/postgis/gserialized_typmod.c
index b07ad9343..7ecd8617e 100644
--- a/postgis/gserialized_typmod.c
+++ b/postgis/gserialized_typmod.c
@@ -140,8 +140,9 @@ GSERIALIZED* postgis_valid_typmod(GSERIALIZED *gser, int32_t typmod)
 		LWPOINT *empty_point = lwpoint_construct_empty(geom_srid, geom_z, geom_m);
 		geom_type = POINTTYPE;
+		bool is_geodetic = gserialized_is_geodetic(gser);
 		pfree(gser);
-		if ( gserialized_is_geodetic(gser) )
+		if ( is_geodetic )
 			gser = geography_serialize(lwpoint_as_lwgeom(empty_point));
 		else
 			gser = geometry_serialize(lwpoint_as_lwgeom(empty_point));
Summary of changes:
 postgis/gserialized_typmod.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
