[SCM] PostGIS branch stable-3.5 updated. 3.5.4-17-g248bfa21a
git at osgeo.org
git at osgeo.org
Tue Jan 27 13:25:39 PST 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
via 248bfa21a0fd0091eaa883455d5c7732b5ef882d (commit)
from 7cdf70f7811c43df1220f823cd7cd59a9aedffb3 (commit)
revisions in full, below.
commit 248bfa21a0fd0091eaa883455d5c7732b5ef882d
Author: bdreiss <bd_reiss at gmx.at>
Date: Tue Jan 27 12:39:28 2026 -0800
The geodetic flag was queried after gser has been freed
################################################### BUG REPORT ##################################################
### DESCRITPION ###
The geodetic flag was queried after gser has been freed in line 143, leading to a use-after-free bug. This means the behaviour is undefined and it is not clear, which branch will be taken (and therefor, whether geometry or geography is returned). Below you find the output from gdb can be seen, that confirms that a) the point is indeed inserted with the wrong flag and b) also after selecting the point from the table remains unset. Issues when using SQL could not be produced.
### SETUP IN PG ###
CREATE EXTENSION postgis;
CREATE TABLE test_geog (id SERIAL PRIMARY KEY, geog geography(POINT, 4326));
INSERT INTO test_geog (geog) VALUES (ST_GeogFromText('SRID=4326;POINT(-77.0092 38.889588)'));
### GDB OUPUT AND STEPS TO REPRODUCE ###
postgres at localhost:~$ gdb --args /usr/local/pgsql/bin/postgres --single -D $PGDATA postgres
(gdb) break gserialized_typmod.c:143
(gdb) break gserialized_typmod.c:150
(gdb) break geography_out
(gdb) run
backend> INSERT INTO test_geog (geog) VALUES (ST_GeogFromText('SRID=4326;MULTIPOINT EMPTY'));
Breakpoint 1, postgis_valid_typmod (gser=0x58f991a3f378, typmod=1107460) at gserialized_typmod.c:143
143 gserialized_typmod.c: No such file or directory.
(gdb) call gserialized_is_geodetic(gser)
$1 = 1
(gdb) c
Continuing.
Breakpoint 2, postgis_valid_typmod (gser=0x58f991a8e150, typmod=1107460) at gserialized_typmod.c:151
151 in gserialized_typmod.c
$2 = 0
(gdb) c
Continuing.
backend>
backend> INSERT INTO test_geog (geog) VALUES (ST_GeogFromText('SRID=4326;POINT(-77.0092 38.889588)'));
Breakpoint 2, postgis_valid_typmod (gser=0x58f991a3dca8, typmod=1107460) at gserialized_typmod.c:151
$4 = 1
(gdb) c
Continuing.
backend>
backend> select geog from test_geog where id=1;
1: geog (typeid = 14296, len = -1, typmod = 1107460, byval = f)
Breakpoint 3, geography_out (fcinfo=0x7ffe871b40e0) at /usr/local/pgsql/include/server/postgres.h:319
319 return (Pointer) X;
(gdb) set $gser = (GSERIALIZED *) pg_detoast_datum((void *) fcinfo->args[0].value)
(gdb) call gserialized_is_geodetic($gser)
$7 = 0
(gdb) c
Continuing.
1: geog = "0101000020E6100000000000000000F87F000000000000F87F" (typeid = 14296, len = -1, typmod = 1107460, byval = f)
backend> select geog from test_geog where id=2;
$8 = 1
(gdb) c
Continuing.
1: geog = "0101000020E6100000E3C798BB964053C000750305DE714340" (typeid = 14296, len = -1, typmod = 1107460, byval = f)
backend>
### INFO ###
postgres=# SELECT version();
version
PostgreSQL 18.1 on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14+deb12u1) 12.2.0, 64-bit
(1 row)
postgres=# SELECT postgis_full_version();
POSTGIS="3.6.1 f533623" [EXTENSION] PGSQL="180" GEOS="3.11.1-CAPI-1.17.1" PROJ="9.1.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/home/postgres/.loc
al/share/proj DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.1.1) LIBXML="2.9.14" LIBJSON="0.16" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
(1 row)
COMPILE FLAGS USED:
CC=clang ./configure --with-pgconfig=/usr/bin/pg_config CFLAGS="-O0 -g -fsanitize=address -fno-omit-frame-pointer" LDFLAGS="-fsanitize=address"
diff --git a/postgis/gserialized_typmod.c b/postgis/gserialized_typmod.c
index b07ad9343..7ecd8617e 100644
--- a/postgis/gserialized_typmod.c
+++ b/postgis/gserialized_typmod.c
@@ -140,8 +140,9 @@ GSERIALIZED* postgis_valid_typmod(GSERIALIZED *gser, int32_t typmod)
LWPOINT *empty_point = lwpoint_construct_empty(geom_srid, geom_z, geom_m);
geom_type = POINTTYPE;
+ bool is_geodetic = gserialized_is_geodetic(gser);
pfree(gser);
- if ( gserialized_is_geodetic(gser) )
+ if ( is_geodetic )
gser = geography_serialize(lwpoint_as_lwgeom(empty_point));
else
gser = geometry_serialize(lwpoint_as_lwgeom(empty_point));
Summary of changes:
postgis/gserialized_typmod.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
