[SCM] PostGIS branch stable-3.4 updated. 3.4.4-72-g097b5d747
git at osgeo.org
git at osgeo.org
Tue Jan 27 13:25:55 PST 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
via 097b5d7470487e53be58fcb21982329f1b69e5e6 (commit)
from a2c1de0dadf3e913e3827454e31791e597b3b833 (commit)
revisions in full, below.
commit 097b5d7470487e53be58fcb21982329f1b69e5e6
Author: bdreiss <bd_reiss at gmx.at>
Date: Tue Jan 27 12:39:28 2026 -0800
The geodetic flag was queried after gser has been freed
################################################### BUG REPORT ##################################################
### DESCRITPION ###
The geodetic flag was queried after gser has been freed in line 143, leading to a use-after-free bug. This means the behaviour is undefined and it is not clear, which branch will be taken (and therefor, whether geometry or geography is returned). Below you find the output from gdb can be seen, that confirms that a) the point is indeed inserted with the wrong flag and b) also after selecting the point from the table remains unset. Issues when using SQL could not be produced.
### SETUP IN PG ###
CREATE EXTENSION postgis;
CREATE TABLE test_geog (id SERIAL PRIMARY KEY, geog geography(POINT, 4326));
INSERT INTO test_geog (geog) VALUES (ST_GeogFromText('SRID=4326;POINT(-77.0092 38.889588)'));
### GDB OUPUT AND STEPS TO REPRODUCE ###
postgres at localhost:~$ gdb --args /usr/local/pgsql/bin/postgres --single -D $PGDATA postgres
(gdb) break gserialized_typmod.c:143
(gdb) break gserialized_typmod.c:150
(gdb) break geography_out
(gdb) run
backend> INSERT INTO test_geog (geog) VALUES (ST_GeogFromText('SRID=4326;MULTIPOINT EMPTY'));
Breakpoint 1, postgis_valid_typmod (gser=0x58f991a3f378, typmod=1107460) at gserialized_typmod.c:143
143 gserialized_typmod.c: No such file or directory.
(gdb) call gserialized_is_geodetic(gser)
$1 = 1
(gdb) c
Continuing.
Breakpoint 2, postgis_valid_typmod (gser=0x58f991a8e150, typmod=1107460) at gserialized_typmod.c:151
151 in gserialized_typmod.c
$2 = 0
(gdb) c
Continuing.
backend>
backend> INSERT INTO test_geog (geog) VALUES (ST_GeogFromText('SRID=4326;POINT(-77.0092 38.889588)'));
Breakpoint 2, postgis_valid_typmod (gser=0x58f991a3dca8, typmod=1107460) at gserialized_typmod.c:151
$4 = 1
(gdb) c
Continuing.
backend>
backend> select geog from test_geog where id=1;
1: geog (typeid = 14296, len = -1, typmod = 1107460, byval = f)
Breakpoint 3, geography_out (fcinfo=0x7ffe871b40e0) at /usr/local/pgsql/include/server/postgres.h:319
319 return (Pointer) X;
(gdb) set $gser = (GSERIALIZED *) pg_detoast_datum((void *) fcinfo->args[0].value)
(gdb) call gserialized_is_geodetic($gser)
$7 = 0
(gdb) c
Continuing.
1: geog = "0101000020E6100000000000000000F87F000000000000F87F" (typeid = 14296, len = -1, typmod = 1107460, byval = f)
backend> select geog from test_geog where id=2;
$8 = 1
(gdb) c
Continuing.
1: geog = "0101000020E6100000E3C798BB964053C000750305DE714340" (typeid = 14296, len = -1, typmod = 1107460, byval = f)
backend>
### INFO ###
postgres=# SELECT version();
version
PostgreSQL 18.1 on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14+deb12u1) 12.2.0, 64-bit
(1 row)
postgres=# SELECT postgis_full_version();
POSTGIS="3.6.1 f533623" [EXTENSION] PGSQL="180" GEOS="3.11.1-CAPI-1.17.1" PROJ="9.1.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/home/postgres/.loc
al/share/proj DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.1.1) LIBXML="2.9.14" LIBJSON="0.16" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
(1 row)
COMPILE FLAGS USED:
CC=clang ./configure --with-pgconfig=/usr/bin/pg_config CFLAGS="-O0 -g -fsanitize=address -fno-omit-frame-pointer" LDFLAGS="-fsanitize=address"
diff --git a/postgis/gserialized_typmod.c b/postgis/gserialized_typmod.c
index b07ad9343..7ecd8617e 100644
--- a/postgis/gserialized_typmod.c
+++ b/postgis/gserialized_typmod.c
@@ -140,8 +140,9 @@ GSERIALIZED* postgis_valid_typmod(GSERIALIZED *gser, int32_t typmod)
LWPOINT *empty_point = lwpoint_construct_empty(geom_srid, geom_z, geom_m);
geom_type = POINTTYPE;
+ bool is_geodetic = gserialized_is_geodetic(gser);
pfree(gser);
- if ( gserialized_is_geodetic(gser) )
+ if ( is_geodetic )
gser = geography_serialize(lwpoint_as_lwgeom(empty_point));
else
gser = geometry_serialize(lwpoint_as_lwgeom(empty_point));
Summary of changes:
postgis/gserialized_typmod.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
