[PostGIS] #5790: Postgis-functions in Materialized views fail in Postgres 17 due to not fully qualified search path
PostGIS trac at osgeo.org
Thu Jan 29 02:54:15 PST 2026
  Reporter:  maxbo    |      Owner:  robe
      Type:  defect   |     Status:  closed
  Priority:  high     |  Milestone:  PostGIS 3.4.4
 Component:  postgis  |    Version:  3.4.x
Resolution:  fixed    |   Keywords:
Comment (by landry):
 i dunno if i should file a new issue, because we face the exact same
 symptoms using 3.5.2/psql 17.6 on debian 13 (so, supposedly with this
 issue fixed), cf https://gitlab.com/panoramax/server/api/-/issues/304
 from a psql shell, refreshing the MV fails at the first try, but works at
 the second:
 panoramax=> refresh materialized view pictures_grid ;
 ERROR:  column "public"."pictures"."geom" must be a geometry or geography
 REFRESH MATERIALIZED VIEW
 from psycopg2 code, the sql query to refresh the MV fails all the time.
 the materialized view is defined in
 https://gitlab.com/panoramax/server/api/-/blob/develop/geovisio/migrations/20251202_01_Q3g59
 -pictures-grid-logged-only.sql#L16, and uses
 ST_EstimatedExtent('public', 'pictures', 'geom')
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5790#comment:9>
