[PostGIS] #5790: Postgis-functions in Materialized views fail in Postgres 17 due to not fully qualified search path
trac at osgeo.org
Thu Jan 29 07:51:10 PST 2026
Reporter: maxbo | Owner: robe
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 3.4.4
Component: postgis | Version: 3.4.x
Resolution: fixed | Keywords:
Comment (by robe):
@landry,
I think this might be a separate issue cause I think the error for these
usually included the function in question. Unfortunately I don't have a
PostGIS 3.5.1 or 3.5.2 lying around.
I tested this on 3.6.1 and behaved correctly:
Can you try this and see if you get the same area.
DROP TABLE IF EXISTS public.test;
CREATE TABLE public.test AS
SELECT ST_MakeEnvelope(35,45, 36,i, 4326) AS geom
FROM generate_series(46,50) AS i;
ANALYZE public.test;
DROP MATERIALIZED VIEW IF EXISTS test_grid;
CREATE MATERIALIZED VIEW test_grid AS
SELECT *
FROM
ST_SquareGrid(
0.1,
ST_SetSRID(ST_EstimatedExtent('public', 'test', 'geom'), 4326)
) AS g;
SET search_path=pg_catalog;
SELECT * FROM public.test_grid;
Can you also confirm your public.pictures.geom column is really a geometry
or geography.
You can do that in psql with
\d+ public.pictures
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5790#comment:10>
