[SCM] PostGIS branch master updated. 3.7.0alpha1-272-gb337fe61b
git at osgeo.org
git at osgeo.org
Mon Jul 13 23:39:14 PDT 2026
the project "PostGIS".
via b337fe61bc11358245f52f590f652122f471b107 (commit)
from 0ccadb462a520bdb598443862fb06c4b09df6c44 (commit)
revisions in full, below.
commit b337fe61bc11358245f52f590f652122f471b107
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Tue Jul 14 06:33:47 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 96.3% (5829 of 6049 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index ffb8ad008..1a05772ed 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-07-05 04:20+0000\n"
-"PO-Revision-Date: 2026-07-14 03:39+0000\n"
+"PO-Revision-Date: 2026-07-14 06:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -32850,6 +32850,8 @@ msgid ""
"Output the first three bands, mapping band 2 to red, band 1 to green, and "
"band 3 to blue, using progressive encoding at 90 percent quality."
msgstr ""
+"先頭から3バンドを、2番バンドは赤に、1番バンドは緑に、3番バンドは青に、それぞ"
+"れ割り当て、プログレッシブを使用した90%品質で出力します。"
#. Tag: para
#, no-c-format
@@ -33136,7 +33138,7 @@ msgstr "例: 1バンドの切り取り (touched でない)"
#. Tag: para
#, no-c-format
msgid "Clip the first band of an aerial tile by a 20 meter buffer."
-msgstr ""
+msgstr "タイルの最初のバンドを20mバッファーでクリップします。"
#. Tag: para
#, no-c-format
@@ -33168,6 +33170,8 @@ msgid ""
"ST_AddBand. Because ST_AddBand requires all bands be the same Width and "
"height."
msgstr ""
+"前と同じ例ですがST_AddBandを使えるようにするにはcropをFALSEにする必要がありま"
+"す。ST_AddBandは全てのバンドが同一の縦横幅になっている必要があるためです。"
#. Tag: para
#, no-c-format
@@ -33185,6 +33189,8 @@ msgid ""
"Clip all bands of an aerial tile by a 20 meter buffer. Only difference is we "
"don't specify a specific band to clip. So all bands are clipped."
msgstr ""
+"タイルの全てのバンドを20mバッファーでクリップします。クリップするバンドを指定"
+"しない点だけが違います。全てのバンドがクリップされます。"
#. Tag: para
#, no-c-format
@@ -33367,7 +33373,7 @@ msgstr "これは試行のためのがらくたテーブルです。"
#. Tag: para
#, no-c-format
msgid "Setup test raster table."
-msgstr ""
+msgstr "テスト用ラスターテーブルを準備します。"
#. Tag: title
#, no-c-format
@@ -33835,6 +33841,10 @@ msgid ""
"are passed through to the specified <varname>callbackfunc</varname>, and are "
"contained in the <varname>userargs</varname> argument."
msgstr ""
+"<varname>callbackfunc</varname>が第3引数を宣言している場合には、第3引数"
+"は<type>variadic text</type>配列です。全ての引き渡されるテキスト引数は指定し"
+"た<varname>callbackfunc</varname>に渡され、<varname>userargs</varname>引数に"
+"含まれます。"
#. Tag: para
#, no-c-format
@@ -34402,7 +34412,7 @@ msgstr "例: 2バンドの共有と結合"
#. Tag: para
#, no-c-format
msgid "Create a cool set of rasters."
-msgstr ""
+msgstr "ラスターのいかした集合を生成します。"
#. Tag: para
#, no-c-format
@@ -34422,7 +34432,7 @@ msgstr "例: 別個のバンドとしてキャンバス上にラスタをオー
#. Tag: para
#, no-c-format
msgid "We use ST_AsPNG to render the image so all single band ones look grey."
-msgstr ""
+msgstr "画像生成にST_AsPNG使うので、全ての単一バンドのラスターは灰色に見えます。"
#. Tag: para
#, no-c-format
@@ -34457,6 +34467,9 @@ msgid ""
"3rd band with our geometry. This query took 3.6 seconds on PostGIS windows "
"64-bit install."
msgstr ""
+"新しい三つのバンドのラスターを生成します。最初の二つはバンドはクリップして、3"
+"番目のバンドはジオメトリーをオーバーラップさせます。このクエリーはPostGIS "
+"Windows 64ビット版で3.6秒かかりました。"
#. Tag: para
#, no-c-format
@@ -34701,7 +34714,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Define our user defined function."
-msgstr ""
+msgstr "ユーザー定義関数を定義します。"
#. Tag: para
#, no-c-format
@@ -34851,7 +34864,7 @@ msgstr ""
msgid ""
"A simple 'callback' user function that averages up all the values in a "
"neighborhood."
-msgstr ""
+msgstr "単純な'callback'として隣接ピクセルの値を全て平均する関数を使います。"
#. Tag: para
#, no-c-format
@@ -35107,6 +35120,8 @@ msgid ""
"This creates a single band from first band of raster tiles. That form the "
"original file system tile."
msgstr ""
+"ラスタータイルの1番バンドから単一のバンドを生成します。元のファイルシステムの"
+"タイルを形成します。"
#. Tag: title
#, no-c-format
@@ -35124,6 +35139,10 @@ msgid ""
"raster. , new union works on all bands by default. This is equivalent to "
"unionarg: ARRAY[ROW(1, 'LAST'), ROW(2, 'LAST'), ROW(3, 'LAST')]::unionarg[]."
msgstr ""
+"ここではラインにインターセクトする全てのタイルを集めたマルチバンドラスターを"
+"生成します。2.0では、単一バンドラスターを返します。新しい結合はデフォルトで全"
+"てのバンドで動作します。これは ARRAY[ROW(1, 'LAST'), ROW(2, 'LAST'), ROW(3, "
+"'LAST')]::unionarg[] と同じです。"
#. Tag: para
#, no-c-format
@@ -35140,6 +35159,8 @@ msgid ""
"This creates a multi band raster collecting all the tiles that intersect a "
"line."
msgstr ""
+"ラインとインターセクトするタイルの全てを集めたマルチバンドラスターを生成しま"
+"す。"
#. Tag: para
#, no-c-format
@@ -36056,7 +36077,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Note envelope and convexhull are more or less the same."
-msgstr ""
+msgstr "エンベロープと凸包とはほぼ同じものです。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 37 +++++++++++++++++++++++++++++--------
1 file changed, 29 insertions(+), 8 deletions(-)
hooks/post-receive
