[SCM] PostGIS branch master updated. 3.7.0alpha1-274-g7130c2d83
git at osgeo.org
git at osgeo.org
Tue Jul 14 03:39:15 PDT 2026
the project "PostGIS".
via 7130c2d837f3b84237d2274c7b9e9bc1bb997596 (commit)
from a67110e787e5b8ca585ed91ef4dbaf4d1fc9832f (commit)
revisions in full, below.
commit 7130c2d837f3b84237d2274c7b9e9bc1bb997596
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Tue Jul 14 09:09:57 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 96.6% (5849 of 6049 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 9dd9aaa13..46c622597 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-07-05 04:20+0000\n"
-"PO-Revision-Date: 2026-07-14 08:41+0000\n"
+"PO-Revision-Date: 2026-07-14 10:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -36769,11 +36769,13 @@ msgstr ""
msgid ""
"Rid = 1 has no bands, hence the NOTICE and the NULL value for st_disjoint."
msgstr ""
+"Rid = 1 にバンドが無く、したがってST_DisjointはNOTICEを出してNULL値を返します"
#. Tag: para
#, no-c-format
msgid "This time, without specifying band numbers."
-msgstr ""
+msgstr "今度はバンド番号の指定をしません。"
#. Tag: refpurpose
#, no-c-format
@@ -36810,7 +36812,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Different bands of same raster."
-msgstr ""
+msgstr "同じラスターの異なるバンド。"
#. Tag: para
#, no-c-format
@@ -36854,7 +36856,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Comparing different bands of same raster."
-msgstr ""
+msgstr "同じラスターの異なるバンドの比較です。"
#. Tag: refpurpose
#, no-c-format
@@ -37633,14 +37635,14 @@ msgstr "<varname>LINESTRING</varname> / <varname>POINT</varname>"
#. Tag: para
#, no-c-format
msgid "This example tests a circle within another circle."
-msgstr ""
+msgstr "この例ではある円がもう一つの円の中にあるかどうかをテストします。"
#. Tag: para
#, no-c-format
msgid ""
"This example demonstrates the difference between contains and contains-"
"properly predicates."
-msgstr ""
+msgstr "この例ではST_ContainsとST_ContainsProperlyとの差異を示します。"
#. Tag: para
#, no-c-format
@@ -37797,7 +37799,7 @@ msgstr "これはOGC標準と違いますがOracleは持っています。"
#. Tag: para
#, no-c-format
msgid "This example tests a circle covered by another circle."
-msgstr ""
+msgstr "この例ではある円がもう一つの円に覆われているかどうかをテストします。"
#. Tag: para
#, no-c-format
@@ -37888,7 +37890,7 @@ msgstr "ジオメトリの例"
#. Tag: para
#, no-c-format
msgid "This example tests a circle covering another circle."
-msgstr ""
+msgstr "この例ではある円がもう一つの円を覆っているかどうかをテストします。"
#. Tag: para
#, no-c-format
@@ -38724,6 +38726,8 @@ msgid ""
"Find compounds that properly intersect (not just touch) a poly (Interior "
"Intersects)"
msgstr ""
+"ポリゴンと確実にインターセクト (接触だけは除く)している (内部でインターセクト"
+"している)ものを探索します。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 20 ++++++++++++--------
1 file changed, 12 insertions(+), 8 deletions(-)
hooks/post-receive
