[SCM] PostGIS branch master updated. 3.7.0alpha1-276-g90b4e1151
git at osgeo.org
git at osgeo.org
Tue Jul 14 21:39:14 PDT 2026
the project "PostGIS".
via 90b4e11513fb7ef84f6adb121661ff0c5d939042 (commit)
from 4a6d82e94fc2709cd1e20fb61da865d6cf37420e (commit)
revisions in full, below.
commit 90b4e11513fb7ef84f6adb121661ff0c5d939042
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Wed Jul 15 04:38:26 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 97.3% (5889 of 6049 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index d3ad35e45..7e2667efa 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-07-05 04:20+0000\n"
-"PO-Revision-Date: 2026-07-15 02:39+0000\n"
+"PO-Revision-Date: 2026-07-15 04:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -41450,7 +41450,7 @@ msgstr ""
#, no-c-format
msgid ""
"Creates an interpolating NURBS curve passing through all given data points"
-msgstr ""
+msgstr "全ての与えられたデータのポイントを通る補間NURBS曲線を生成します。"
#. Tag: para
#, no-c-format
@@ -41458,18 +41458,20 @@ msgid ""
"Creates a NURBS curve that interpolates through all provided data points. "
"The resulting curve passes exactly through each point in the input geometry."
msgstr ""
+"与えられたデータのポイント全てを通るNURBS曲線を生成します。得られる曲線は確実"
+"に入力ジオメトリーの各ポイントを通ります。"
#. Tag: para
#, no-c-format
msgid "Parameters:"
-msgstr ""
+msgstr "パラメーター:"
#. Tag: para
#, no-c-format
msgid ""
"<varname>data_points</varname> - A LINESTRING geometry containing the points "
"to interpolate through."
-msgstr ""
+msgstr "<varname>data_points</varname> - 補間用ポイントを持つLINESTRINGジオメトリー。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 10 ++++++----
1 file changed, 6 insertions(+), 4 deletions(-)
hooks/post-receive
