[SCM] PostGIS branch master updated. 3.7.0alpha1-278-gc2e4ca848
Wed Jul 15 01:39:23 PDT 2026
the project "PostGIS".
       via  c2e4ca8487b41b7c269bb4dc5a4fd853e9145391 (commit)
      from  c86c6094bd58a48955dd52e6d93dea9b56d336ea (commit)
revisions in full, below.
commit c2e4ca8487b41b7c269bb4dc5a4fd853e9145391
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Wed Jul 15 06:59:56 2026 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 97.8% (5918 of 6049 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 6164943ee..12a28d05f 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2026-07-05 04:20+0000\n"
-"PO-Revision-Date: 2026-07-15 06:39+0000\n"
+"PO-Revision-Date: 2026-07-15 08:39+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
 "manual/ja/>\n"
@@ -42593,7 +42593,7 @@ msgstr "Availability: 1.1.2 1.2.2でRotateYからST_RotateYに名称変更しま
 #. Tag: para
 #, no-c-format
 msgid "This example rotates a line 90 degrees around the Y axis."
-msgstr ""
+msgstr "この例ではラインをY軸回りに90°回転させます。"
 #. Tag: para
 #, no-c-format
@@ -42634,7 +42634,7 @@ msgstr "Availability: 1.1.2 1.2.2でRotateZからST_RotateZに名称変更しま
 #. Tag: para
 #, no-c-format
 msgid "This example rotates a line 90 degrees around the Z axis."
-msgstr ""
+msgstr "この例ではラインをZ軸回りに90°回転させます。"
 #. Tag: para
 #, no-c-format
@@ -42712,22 +42712,22 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "This example scales X, Y, and Z values."
-msgstr ""
+msgstr "この例ではX,Y,Z値を拡大縮小します。"
 #. Tag: para
 #, no-c-format
 msgid "This example scales X and Y values."
-msgstr ""
+msgstr "この例ではX,Y値を拡大縮小します。"
 #. Tag: para
 #, no-c-format
 msgid "This example scales X, Y, Z, and M values."
-msgstr ""
+msgstr "この例ではX,Y,Z,M値を拡大縮小します。"
 #. Tag: para
 #, no-c-format
 msgid "This example scales X and Y values using a false origin."
-msgstr ""
+msgstr "この例では仮原点を使ってX,Y値を拡大縮小します。"
 #. Tag: para
 #, no-c-format
@@ -42746,6 +42746,8 @@ msgid ""
 "y,delta z units. Units are based on the units defined in spatial reference "
 "(SRID) for this geometry. M coordinates are preserved."
 msgstr ""
+"座標がX増分、Y増分、Z増分で変換した新しいジオメトリーを返します。単位は"
+"ジオメトリーのSRID (空間参照系)の単位です。M値は保存されます。"
 #. Tag: para
 #, no-c-format
@@ -42765,7 +42767,7 @@ msgstr "3次元ポイントを移動させます。"
 #. Tag: para
 #, no-c-format
 msgid "Move points with a measure coordinate"
-msgstr ""
+msgstr "M値を持つポイントを移動させます"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 18 ++++++++++--------
 1 file changed, 10 insertions(+), 8 deletions(-)
hooks/post-receive
