[SCM] PostGIS branch master updated. 3.6.0rc2-356-g8a31ce8c6
Thu Mar 5 10:19:42 PST 2026
the project "PostGIS".
       via  8a31ce8c686766caacde19e8fa5977ed49a4068e (commit)
      from  04b9a7cb3a17edde9291944ad0d0e1ab1398d568 (commit)
revisions in full, below.
commit 8a31ce8c686766caacde19e8fa5977ed49a4068e
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Mar 5 22:18:25 2026 +0400
    Fix mingw clang redeclaration errors in gserialized_estimate
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index 7f5e6d89c..15791f382 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -124,12 +124,9 @@ dimensionality cases. (2D geometry) &&& (3D column), etc.
 /* Prototypes */
-Datum gserialized_gist_joinsel(PG_FUNCTION_ARGS);
 Datum gserialized_gist_joinsel_2d(PG_FUNCTION_ARGS);
 Datum gserialized_gist_joinsel_nd(PG_FUNCTION_ARGS);
-Datum gserialized_gist_sel(PG_FUNCTION_ARGS);
 Datum gserialized_gist_sel_2d(PG_FUNCTION_ARGS);
 Datum gserialized_gist_sel_nd(PG_FUNCTION_ARGS);
 Datum gserialized_analyze_nd(PG_FUNCTION_ARGS);
@@ -1087,36 +1084,6 @@ estimate_join_selectivity(const ND_STATS *s1, const ND_STATS *s2)
 	return selectivity;
-* For (geometry &&& geometry) and (geography && geography)
-* we call into the N-D mode.
-PG_FUNCTION_INFO_V1(gserialized_gist_joinsel_nd);
-Datum gserialized_gist_joinsel_nd(PG_FUNCTION_ARGS)
-	PG_RETURN_DATUM(DirectFunctionCall5(
-	   gserialized_gist_joinsel,
-	   PG_GETARG_DATUM(0), PG_GETARG_DATUM(1),
-	   PG_GETARG_DATUM(2), PG_GETARG_DATUM(3),
-	   Int32GetDatum(0) /* ND mode */
-* For (geometry && geometry)
-* we call into the 2-D mode.
-PG_FUNCTION_INFO_V1(gserialized_gist_joinsel_2d);
-Datum gserialized_gist_joinsel_2d(PG_FUNCTION_ARGS)
-	   Int32GetDatum(2) /* 2D mode */
 double
 gserialized_joinsel_internal(PlannerInfo *root, List *args, JoinType jointype, int mode)
@@ -1201,6 +1168,40 @@ Datum gserialized_gist_joinsel(PG_FUNCTION_ARGS)
 	PG_RETURN_FLOAT8(gserialized_joinsel_internal(root, args, jointype, mode));
+ * For (geometry &&& geometry) and (geography && geography)
+ * we call into the N-D mode.
+PG_FUNCTION_INFO_V1(gserialized_gist_joinsel_nd);
+Datum
+gserialized_gist_joinsel_nd(PG_FUNCTION_ARGS)
+	PG_RETURN_DATUM(DirectFunctionCall5(gserialized_gist_joinsel,
+					    PG_GETARG_DATUM(0),
+					    PG_GETARG_DATUM(1),
+					    PG_GETARG_DATUM(2),
+					    PG_GETARG_DATUM(3),
+					    Int32GetDatum(0) /* ND mode */
+ * For (geometry && geometry)
+ * we call into the 2-D mode.
+PG_FUNCTION_INFO_V1(gserialized_gist_joinsel_2d);
+Datum
+gserialized_gist_joinsel_2d(PG_FUNCTION_ARGS)
+					    Int32GetDatum(2) /* 2D mode */
  * The gserialized_analyze_nd sets this function as a
  * callback on the stats object when called by the ANALYZE
@@ -2017,37 +2018,6 @@ Datum _postgis_gserialized_joinsel(PG_FUNCTION_ARGS)
 	PG_RETURN_FLOAT8(selectivity);
-PG_FUNCTION_INFO_V1(gserialized_gist_sel_2d);
-Datum gserialized_gist_sel_2d(PG_FUNCTION_ARGS)
-	   gserialized_gist_sel,
-	   Int32GetDatum(2) /* 2-D mode */
-PG_FUNCTION_INFO_V1(gserialized_gist_sel_nd);
-Datum gserialized_gist_sel_nd(PG_FUNCTION_ARGS)
-	   Int32GetDatum(0) /* N-D mode */
  * This function should return an estimation of the number of
  * rows returned by a query involving an overlap check
@@ -2132,6 +2102,40 @@ Datum gserialized_gist_sel(PG_FUNCTION_ARGS)
+PG_FUNCTION_INFO_V1(gserialized_gist_sel_2d);
+Datum
+gserialized_gist_sel_2d(PG_FUNCTION_ARGS)
+	PG_RETURN_DATUM(DirectFunctionCall5(gserialized_gist_sel,
+					    Int32GetDatum(2) /* 2-D mode */
+PG_FUNCTION_INFO_V1(gserialized_gist_sel_nd);
+Datum
+gserialized_gist_sel_nd(PG_FUNCTION_ARGS)
+					    Int32GetDatum(0) /* N-D mode */
Summary of changes:
 postgis/gserialized_estimate.c | 132 +++++++++++++++++++++--------------------
 1 file changed, 68 insertions(+), 64 deletions(-)
hooks/post-receive
