[SCM] PostGIS branch master updated. 3.6.0rc2-355-g04b9a7cb3
Thu Mar 5 09:34:45 PST 2026
the project "PostGIS".
       via  04b9a7cb3a17edde9291944ad0d0e1ab1398d568 (commit)
      from  1636202258b8e3aa41784b57191400c7d4509f08 (commit)
revisions in full, below.
commit 04b9a7cb3a17edde9291944ad0d0e1ab1398d568
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Mar 5 21:33:14 2026 +0400
    Fix legacy symbol bindings for mingw clang CI
diff --git a/postgis/legacy.sql.in b/postgis/legacy.sql.in
index 9c90a154a..d67a7f00f 100644
--- a/postgis/legacy.sql.in
+++ b/postgis/legacy.sql.in
@@ -96,8 +96,8 @@ CREATE OR REPLACE FUNCTION SE_M(geometry)
 -- PostGIS equivalent function: locate_between_measures(geometry, float8, float8)
 CREATE OR REPLACE FUNCTION SE_LocateBetween(geometry, float8, float8)
 	RETURNS geometry
-	AS 'MODULE_PATHNAME', 'LWGEOM_locate_between_m'
-	LANGUAGE 'c' IMMUTABLE STRICT;
+	AS $$ SELECT ST_LocateBetween($1, $2, $3, 0.0) $$
+	LANGUAGE 'sql' IMMUTABLE STRICT;
 -- PostGIS equivalent function: locate_along_measure(geometry, float8)
 CREATE OR REPLACE FUNCTION SE_LocateAlong(geometry, float8)
@@ -1248,8 +1248,8 @@ CREATE OR REPLACE FUNCTION LinestringFromWKB(bytea)
 -- Deprecation in 1.2.3
 CREATE OR REPLACE FUNCTION locate_between_measures(geometry, float8, float8)
 	RETURNS geometry
 CREATE OR REPLACE FUNCTION M(geometry)
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 989faabf7..9b1ef3e0f 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -741,17 +741,6 @@ Datum ST_Union(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(result);
-/* This is retained for backward ABI compatibility
- * with PostGIS < 3.1.0 */
-PG_FUNCTION_INFO_V1(symdifference);
-Datum symdifference(PG_FUNCTION_ARGS)
-  PG_RETURN_DATUM(DirectFunctionCall2(
-     ST_SymDifference,
-     PG_GETARG_DATUM(0), PG_GETARG_DATUM(1)
  *  @example symdifference {@link #symdifference} - SELECT ST_SymDifference(
  *      'POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))',
diff --git a/postgis/postgis_legacy.c b/postgis/postgis_legacy.c
index 5a250c716..0856c5ba0 100644
--- a/postgis/postgis_legacy.c
+++ b/postgis/postgis_legacy.c
@@ -101,6 +101,7 @@ POSTGIS_DEPRECATE("3.1.0", postgis_sfcgal_noop)
 POSTGIS_DEPRECATE("3.1.0", LWGEOM_locate_between_m)
 POSTGIS_DEPRECATE("3.1.0", postgis_svn_version)
+POSTGIS_DEPRECATE("3.1.0", symdifference)
 POSTGIS_DEPRECATE("3.3.0", pgis_geometry_union_finalfn)
 /**START: Removal of transactin lock feature **/
Summary of changes:
 postgis/legacy.sql.in    |  8 ++++----
 postgis/lwgeom_geos.c    | 11 -----------
 postgis/postgis_legacy.c |  1 +
 3 files changed, 5 insertions(+), 15 deletions(-)
hooks/post-receive
