[SCM] PostGIS branch master updated. 3.6.0rc2-354-g163620225
Thu Mar 5 07:50:52 PST 2026
the project "PostGIS".
       via  1636202258b8e3aa41784b57191400c7d4509f08 (commit)
      from  032bbd6237c705c4c5a3bc53a5e366f62e6d88ab (commit)
revisions in full, below.
commit 1636202258b8e3aa41784b57191400c7d4509f08
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Mar 5 19:21:40 2026 +0400
    CI: stabilize topology error locations and fix FreeBSD raster make race
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index ae60d2132..ba42f592c 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -37,17 +37,29 @@
 #include <inttypes.h>
+static bool
+_lwt_describe_point(const LWPOINT *pt, char *buf, size_t bufsize)
+	POINT2D p;
+	if (!pt || !pt->point || !pt->point->npoints)
+		return false;
+	getPoint2d_p(pt->point, 0, &p);
+	snprintf(buf, bufsize, " at POINT(%.15g %.15g)", p.x, p.y);
+	return true;
- * Report a human readable location along with topology errors so callers can
- * narrow down robustness issues such as #5886/#5889 without further tracing.
- * Using a point-on-surface keeps the message compact while remaining
- * representative for any dimensionality of the offending intersection.
+ * Report a deterministic GEOS-derived location for topology errors.
+ * Normalize the intersection geometry so PointOnSurface is stable
+ * across operand-order and platform differences.
 static bool
 _lwt_describe_intersection_point(const GEOSGeometry *g1, const GEOSGeometry *g2, char *buf, size_t bufsize)
 	unsigned int n = 0;
-	POINT2D pt;
+	POINT2D p;
 	GEOSGeometry *isect;
 	GEOSGeometry *surface_pt;
 	const GEOSCoordSequence *seq;
@@ -56,6 +68,12 @@ _lwt_describe_intersection_point(const GEOSGeometry *g1, const GEOSGeometry *g2,
 	if (!isect)
 		return false;
+	if (GEOSNormalize(isect) != 0)
+		GEOSGeom_destroy(isect);
+		return false;
 	surface_pt = GEOSPointOnSurface(isect);
 	if (!surface_pt)
@@ -74,26 +92,13 @@ _lwt_describe_intersection_point(const GEOSGeometry *g1, const GEOSGeometry *g2,
 		return false;
-	if (!GEOSCoordSeq_getX(seq, 0, &pt.x) || !GEOSCoordSeq_getY(seq, 0, &pt.y))
+	if (!GEOSCoordSeq_getX(seq, 0, &p.x) || !GEOSCoordSeq_getY(seq, 0, &p.y))
 		GEOSGeom_destroy(surface_pt);
 		return false;
-	snprintf(buf, bufsize, " at POINT(%.15g %.15g)", pt.x, pt.y);
-	return true;
-static bool
-_lwt_describe_point(const LWPOINT *pt, char *buf, size_t bufsize)
-	POINT2D p;
-	if (!pt || !pt->point || !pt->point->npoints)
-		return false;
-	getPoint2d_p(pt->point, 0, &p);
 	return true;
@@ -796,9 +801,10 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
     match = GEOSRelatePatternMatch(relate, "1FFF*FFF2");
     if ( match ) {
 	    char locinfo[128] = "";
-	    const char *locsuffix = match == 2        ? ""
-				    : _lwt_describe_intersection_point(edgegg, eegg, locinfo, sizeof(locinfo)) ? locinfo
+	    const char *locsuffix = match == 2                                                        ? ""
+				    : _lwt_describe_intersection_point(edgegg, eegg, locinfo, sizeof(locinfo))
+					? locinfo
 	    GEOSGeom_destroy(eegg);
 	    GEOSGeom_destroy(edgegg);
 	    _lwt_release_edges(edges, num_edges);
@@ -817,9 +823,10 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
     match = GEOSRelatePatternMatch(relate, "1********");
     if ( match ) {
+					? locinfo
@@ -838,9 +845,10 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
     match = GEOSRelatePatternMatch(relate, "T********");
     if ( match ) {
+					? locinfo
@@ -860,9 +868,10 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
     match = GEOSRelatePatternMatch(relate, "*T*******");
     if ( match ) {
+					? locinfo
@@ -883,9 +892,10 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
     match = GEOSRelatePatternMatch(relate, "***T*****");
     if ( match ) {
+					? locinfo
diff --git a/topology/test/regress/st_addedgemodface_expected b/topology/test/regress/st_addedgemodface_expected
index d55e6ce19..29aef17ce 100644
--- a/topology/test/regress/st_addedgemodface_expected
+++ b/topology/test/regress/st_addedgemodface_expected
@@ -8,7 +8,7 @@ ERROR:  SQL/MM Spatial exception - curve not simple
 ERROR:  Invalid edge (no two distinct vertices exist)
 ERROR:  SQL/MM Spatial exception - coincident edge 8 at POINT(35 22)
-ERROR:  SQL/MM Spatial exception - geometry crosses edge 5 at POINT(48.0714285714286 41.9285714285714)
+ERROR:  SQL/MM Spatial exception - geometry crosses edge 5 at POINT(57 33)
 ERROR:  SQL/MM Spatial exception - geometry crosses edge 4 at POINT(45 32)
 ERROR:  Spatial exception - geometry intersects edge 4 at POINT(36 38)
 L1
diff --git a/topology/test/regress/st_addedgenewfaces_expected b/topology/test/regress/st_addedgenewfaces_expected
index bb2a7a572..df23f1044 100644
--- a/topology/test/regress/st_addedgenewfaces_expected
+++ b/topology/test/regress/st_addedgenewfaces_expected
 L1
diff --git a/utils/Makefile.in b/utils/Makefile.in
index 329bbd3b1..090bbedfd 100644
--- a/utils/Makefile.in
+++ b/utils/Makefile.in
@@ -68,7 +68,7 @@ $(top_builddir)/sfcgal/uninstall_sfcgal.sql:
 $(top_builddir)/raster/rt_pg/uninstall_rtpostgis.sql:
 	$(MAKE) -C ../raster/rt_pg uninstall_rtpostgis.sql
-$(top_builddir)/raster/rt_pg/rtpostgis_upgrade.sql:
+$(top_builddir)/raster/rt_pg/rtpostgis_upgrade.sql: $(top_builddir)/raster/rt_pg/uninstall_rtpostgis.sql
 	$(MAKE) -C ../raster/rt_pg rtpostgis_upgrade.sql
 $(top_builddir)/topology/topology_upgrade.sql:
Summary of changes:
 liblwgeom/topo/lwgeom_topo.c                      | 78 +++++++++++++----------
 topology/test/regress/st_addedgemodface_expected  |  2 +-
 topology/test/regress/st_addedgenewfaces_expected |  2 +-
 utils/Makefile.in                                 |  2 +-
 4 files changed, 47 insertions(+), 37 deletions(-)
hooks/post-receive
