[SCM] PostGIS branch master updated. 3.6.0rc2-353-g032bbd623
Thu Mar 5 01:38:16 PST 2026
the project "PostGIS".
       via  032bbd6237c705c4c5a3bc53a5e366f62e6d88ab (commit)
      from  13cacae51bf7d39ecb714543bbde04d54c1366ac (commit)
revisions in full, below.
commit 032bbd6237c705c4c5a3bc53a5e366f62e6d88ab
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Mar 5 13:37:40 2026 +0400
    CI: fix latest builds and improve regression failure logging
diff --git a/.cirrus.yml b/.cirrus.yml
index a7dcf094f..bb9728ac8 100644
--- a/.cirrus.yml
+++ b/.cirrus.yml
@@ -50,7 +50,29 @@ task:
       ccache -s
   test_script:
-      gmake ${MAKEJOBS} check RUNTESTFLAGS="-v --extension --dumprestore" || { service postgresql onestop; exit 1; }
+      show_regression_diffs() {
+        local tmpdir="${PGIS_REG_TMPDIR:-/tmp/pgis_reg}"
+        local found=0
+        for f in "${tmpdir}"/*_diff; do
+          [ -f "${f}" ] || continue
+          if [ "${found}" -eq 0 ]; then
+            echo "---- BEGIN REGRESSION DIFFS (${tmpdir}) ----"
+          fi
+          found=1
+          echo "---- ${f} ----"
+          cat "${f}"
+        done
+          echo "No regression diff files found in ${tmpdir}"
+        else
+          echo "---- END REGRESSION DIFFS ----"
+        fi
+      gmake ${MAKEJOBS} check RUNTESTFLAGS="-v --extension --dumprestore" || {
+        service postgresql onestop
+        exit 1
   freebsd_instance:
     cpu: ${NCPU}
@@ -85,6 +107,25 @@ task:
   test_script:
+        local found=0
+          fi
+          found=1
+          cat "${f}"
+        done
+        else
+        fi
       export PGCONFIG="${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin/pg_config"
       export CFLAGS="-I${HOMEBREW_PREFIX}/opt/gettext/include \
                      -I${HOMEBREW_PREFIX}/opt/postgresql@${PG}/include \
@@ -105,7 +146,11 @@ task:
       brew services start postgresql@${PG}
       make -j$(sysctl -n hw.logicalcpu) || { brew services stop postgresql@${PG}; exit 1; }
-      make -j$(sysctl -n hw.logicalcpu) check || { brew services stop postgresql@${PG}; exit 1; }
+      make -j$(sysctl -n hw.logicalcpu) check || {
+        brew services stop postgresql@${PG}
+        exit 1
   macos_cache:
diff --git a/raster/rt_pg/rtpg_geometry.c b/raster/rt_pg/rtpg_geometry.c
index a4059a8bc..5bfd62ad9 100644
--- a/raster/rt_pg/rtpg_geometry.c
+++ b/raster/rt_pg/rtpg_geometry.c
@@ -1572,9 +1572,8 @@ Datum RASTER_asRaster(PG_FUNCTION_ARGS)
 		srs = NULL;
 	/* determine number of bands */
-	/* MIN macro is from GDAL's cpl_port.h */
-	num_bands = MIN(pixtypes_len, values_len);
-	num_bands = MIN(num_bands, nodatavals_len);
+	num_bands = Min(pixtypes_len, values_len);
+	num_bands = Min(num_bands, nodatavals_len);
 	POSTGIS_RT_DEBUGF(3, "RASTER_asRaster: pixtypes_len = %d", pixtypes_len);
 	POSTGIS_RT_DEBUGF(3, "RASTER_asRaster: values_len = %d", values_len);
 	POSTGIS_RT_DEBUGF(3, "RASTER_asRaster: nodatavals_len = %d", nodatavals_len);
Summary of changes:
 .cirrus.yml                  | 49 ++++++++++++++++++++++++++++++++++++++++++--
 raster/rt_pg/rtpg_geometry.c |  5 ++---
 2 files changed, 49 insertions(+), 5 deletions(-)
hooks/post-receive
