[SCM] PostGIS branch master updated. 3.6.0rc2-352-g13cacae51
git at osgeo.org
git at osgeo.org
Wed Mar 4 17:51:22 PST 2026
the project "PostGIS".
via 13cacae51bf7d39ecb714543bbde04d54c1366ac (commit)
from ab39a258bf1f6ec872452b313564d34ea5805a4c (commit)
revisions in full, below.
commit 13cacae51bf7d39ecb714543bbde04d54c1366ac
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date: Thu Mar 5 00:04:19 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.8% (5886 of 5893 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index c44a91f76..b512408b0 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2026-03-04 11:51+0000\n"
+"PO-Revision-Date: 2026-03-05 01:51+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -1715,49 +1715,49 @@ msgid "(token number <code>0</code>): Unparsed building identifiers and types."
msgstr "(トークン番号 <code>0</code>): パースされていない建物識別子と種別。"
#. Tag: para
-#, fuzzy, no-c-format
+#, no-c-format
msgid ""
"(token number <code>14</code>): The <emphasis role=\"bold\">BOX</emphasis> "
"in <code>BOX 3B</code>"
msgstr ""
-"(トークン番号 <code>14</code>): <code>BOX 3B</code>内の <emphasis "
-"role=\"bold\">BOX</emphasis>にあたります。"
+"(トークン番号 <code>14</code>): <emphasis role=\"bold\">BOX</emphasis>となっ"
+"ている場合には、たとえば<code>BOX 3B</code>から得られます。"
#. Tag: para
+#, no-c-format
msgid ""
"(token number <code>15</code>): The <emphasis role=\"bold\">3B</emphasis> in "
"<code>BOX 3B</code>"
msgstr ""
-"(トークン番号 <code>15</code>): <code>BOX 3B</code>内の<emphasis "
-"role=\"bold\">3B</emphasis>にあたります。"
+"(トークン番号 <code>15</code>): <emphasis role=\"bold\">3B</emphasis>となって"
+"いる場合には、たとえば<code>BOX 3B</code>から得られます。"
#. Tag: para
+#, no-c-format
msgid ""
"(token number <code>8</code>): The <emphasis role=\"bold\">RR</emphasis> in "
"<code>RR 7</code>"
msgstr ""
-"(トークン番号 <code>8</code>): <code>RR 7</code>内の<emphasis role=\"bold\">"
-"RR</emphasis>にあたります。"
+"(トークン番号 <code>8</code>): <emphasis role=\"bold\">RR</emphasis>となって"
+"いる場合には、たとえば<code>RR 7</code>から得られます。"
#. Tag: para
+#, no-c-format
msgid ""
"(token number <code>16</code>): The <emphasis role=\"bold\">APT</emphasis> "
"in <code>APT 3B</code>"
msgstr ""
-"(トークン番号 <code>16</code>): <code>APT 3B</code>内の<emphasis "
-"role=\"bold\">APT</emphasis>にあたります。"
+"(トークン番号 <code>16</code>): <emphasis role=\"bold\">APT</emphasis>となっ"
+"ている場合には、たとえば<code>APT 3B</code>から得られます。"
#. Tag: para
+#, no-c-format
msgid ""
"(token number <code>17</code>): The <emphasis role=\"bold\">3B</emphasis> in "
"<code>APT 3B</code>"
msgstr ""
-"(トークン番号<code>17</code>): <code>APT 3B</code>内の<emphasis "
+"(トークン番号<code>17</code>): <emphasis role=\"bold\">3B</emphasis>となって"
+"いる場合には、たとえば<code>APT 3B</code>から得られます。"
#. Tag: para
#, no-c-format
@@ -2037,7 +2037,7 @@ msgid "Variant 1: Takes an address as a single line."
msgstr "1番目の形式: 単一行で住所を取る形式です。"
#. Tag: para
+#, no-c-format
msgid ""
"Variant 2: Takes an address as 2 parts. A <varname>micro</varname> "
"consisting of standard first line of postal address e.g. <code>house_num "
@@ -2045,9 +2045,9 @@ msgid ""
"address e.g <code>city, state postal_code country</code>."
msgstr ""
"2番目の形式: 住所を二つの部分から取ります。<varname>micro</varname>は<code>"
-"house_num street</code>等のような、標準的な宛先書式の1行目です。<varname>"
-"macro</varname>は、<code>city, state postal_code country</code>等のような、標"
-"準的な宛先書式の2行目です。"
+"house_num street</code>等のような、標準的な宛先書式の1行目です。macroは"
+"、<code>city, state postal_code country</code>等のような、標準的な宛先書式の2"
+"行目です。"
#. Tag: para
#, no-c-format
@@ -9753,15 +9753,15 @@ msgstr ""
"要なだけダウンロードできます。"
#. Tag: para
+#, no-c-format
msgid ""
"After the states you desire have been loaded, make sure to run the: "
"<programlisting>SELECT install_missing_indexes();</programlisting> as "
"described in <xref linkend=\"Install_Missing_Indexes\"/>."
msgstr ""
-"求める州データをロードした後は、<xref linkend=\"Install_Missing_Indexes\"/>に"
-"示すように、<programlisting>SELECT install_missing_indexes();</"
-"programlisting>を実行するようにして下さい。"
+"求める州データをロードした後は<programlisting>SELECT install_missing_indexes"
+"();</programlisting>を実行するようにして下さい。<xref "
+"linkend=\"Install_Missing_Indexes\"/>に記載があります。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 48 ++++++++++++++++++++++-----------------------
1 file changed, 24 insertions(+), 24 deletions(-)
hooks/post-receive
