[SCM] PostGIS branch master updated. 3.6.0rc2-351-gab39a258b
git at osgeo.org
git at osgeo.org
Wed Mar 4 12:02:01 PST 2026
the project "PostGIS".
via ab39a258bf1f6ec872452b313564d34ea5805a4c (commit)
from f0af9121d32fc84d7fc4bcb4db79f26e7abfd74c (commit)
revisions in full, below.
commit ab39a258bf1f6ec872452b313564d34ea5805a4c
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Wed Mar 4 23:57:21 2026 +0400
fuzzers: centralize OSS-Fuzz build flow in PostGIS
Move OSS-Fuzz project logic into PostGIS-owned scripts so oss-fuzz keeps only thin wrappers.
Highlights:
- add fuzzers/build_oss_fuzz.sh as the single OSS-Fuzz entrypoint
- add fuzzers/install_oss_fuzz_build_deps.sh for builder image apt dependencies
- make build_google_oss_fuzzers.sh use portable link flags (pkg-config/geos-config)
- fold runtime .so packaging/RPATH setup into build_google_oss_fuzzers.sh
- prefer provided CXX over pg_config --cc for Wagyu/FlatGeobuf checks
- rename fuzzers/README.TXT to README.md and refresh docs/issue links
- document the change in NEWS
diff --git a/NEWS b/NEWS
index eac939a70..6ed876e0c 100644
--- a/NEWS
+++ b/NEWS
@@ -41,6 +41,10 @@ This version requires GEOS 3.10 or higher
- #5593, Docs: render manual images with GraphicsMagick without temporary files,
enabling parallel builds, keeping ImageMagick fallbacks working, and
documenting the generator workflow for contributors (Darafei Praliaskouski)
+ - [fuzzers] Centralize OSS-Fuzz build/dependency logic in PostGIS scripts,
+ prefer requested CXX over pg_config --cc for internal C++ checks, and
+ make fuzzer linking/runtime dependency packaging portable
+ (Darafei Praliaskouski)
- GH-848, CG_AlphaShape now returns a MultiPolygon (Jean Felder)
PostGIS 3.6.0
@@ -3061,5 +3065,3 @@ PostGIS 0.1
- truely_inside()
- rtree index support functions
- gist index support functions
diff --git a/configure.ac b/configure.ac
index 6a01d656f..d5fb6cc1b 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1774,7 +1774,7 @@ if test "x$HAVE_PROTOBUF" = "xyes"; then
AC_SUBST([WAGYU_LIB])
dnl ============================================================
- dnl We force to use the same compiler as Postgresql
+ dnl Prefer user/toolchain CXX, falling back to PostgreSQL compiler when needed.
CXX_SAVE="$CXX"
CC_SAVE="$CC"
@@ -1784,7 +1784,13 @@ if test "x$HAVE_PROTOBUF" = "xyes"; then
LDFLAGS_SAVE="$LDFLAGS"
LIBS_SAVE="$LIBS"
- WAGYU_CXX=`"$PG_CONFIG" --cc`
+ dnl Prefer the requested C++ toolchain when provided (for example by OSS-Fuzz),
+ dnl and only fall back to PostgreSQL's compiler when CXX is unset.
+ if test "x$CXX_SAVE" != "x"; then
+ WAGYU_CXX="$CXX_SAVE"
+ else
+ WAGYU_CXX=`"$PG_CONFIG" --cc`
+ fi
CPPFLAGS="-x c++"
CFLAGS=""
LDFLAGS=""
@@ -1847,7 +1853,7 @@ FLATGEOBUF_LIB=libflatgeobuf.la
AC_SUBST([FLATGEOBUF_LIB])
-dnl We force to use the same compiler as Postgresql
+dnl Prefer user/toolchain CXX, falling back to PostgreSQL compiler when needed.
CXX_SAVE="$CXX"
CC_SAVE="$CC"
@@ -1857,7 +1863,11 @@ CPPFLAGS_SAVE="$CPPFLAGS"
LIBS_SAVE="$LIBS"
-FLATGEOBUF_CXX=`"$PG_CONFIG" --cc`
+if test "x$CXX_SAVE" != "x"; then
+ FLATGEOBUF_CXX="$CXX_SAVE"
+else
+ FLATGEOBUF_CXX=`"$PG_CONFIG" --cc`
+fi
CPPFLAGS="-x c++"
CFLAGS=""
LDFLAGS=""
diff --git a/fuzzers/README.TXT b/fuzzers/README.TXT
deleted file mode 100644
index df858ea2d..000000000
--- a/fuzzers/README.TXT
+++ /dev/null
@@ -1,38 +0,0 @@
-This directory contains fuzzer main functions and scripts for the
-Google OSS Fuzz project: https://github.com/google/oss-fuzz/
-The main build scripts are in:
-https://github.com/google/oss-fuzz/tree/master/projects/postgis
-and call scripts in this directory.
-The list of issues is in:
-https://bugs.chromium.org/p/oss-fuzz/issues/list?q=postgis
-- Simulate the build of (dummy) fuzzers like OSS Fuzz does:
- $ make dummyfuzzers
- They are created in /tmp/*_fuzzer as well as with the
- /tmp/*_fuzzer_seed_corpus.zip files
- Run one:
- $ /tmp/wkt_import_fuzzer a_file_name
-- Run locally OSS Fuzz:
- $ git clone --depth=1 https://github.com/google/oss-fuzz.git
- $ cd oss-fuzz
- $ python infra/helper.py build_image postgis
- Build fuzzers with the address sanitizer (could use undefined, etc...)
- $ python infra/helper.py build_fuzzers --sanitizer address postgis
- Test a particular fuzzer (replace wkt_import_fuzzer by other fuzzers
- like the ones generated in /tmp by "make dummyfuzzers")
- $ python infra/helper.py run_fuzzer postgis wkt_import_fuzzer
-How to deal with issues reported in https://bugs.chromium.org/p/oss-fuzz/issues/list?q=postgis ?
- 1. Leave a comment in (chromium database) bug entry to indicate that you work on it
- 2. Work
- 3. Commit a bug fix with log including "Credit to OSS-Fuzz" and a link to the bugs.chromium.org ticket
- 4. Add in the bugs.chromium.org ticket a link to the Trac changeset implementing the fix.
- 5. Check chromium closed the bug (after one or two days typically)
diff --git a/fuzzers/README.md b/fuzzers/README.md
new file mode 100644
index 000000000..0c167e4f3
--- /dev/null
+++ b/fuzzers/README.md
@@ -0,0 +1,64 @@
+# PostGIS Fuzzers
+This directory contains fuzzer entry points and helper scripts for the
+[Google OSS-Fuzz project](https://github.com/google/oss-fuzz/).
+## OSS-Fuzz Build Entrypoint
+The main OSS-Fuzz build orchestration lives in:
+- `./fuzzers/build_oss_fuzz.sh`
+The wrapper in
+[`oss-fuzz/projects/postgis`](https://github.com/google/oss-fuzz/tree/master/projects/postgis)
+should call this script.
+## OSS-Fuzz Image Dependencies
+The package list for the OSS-Fuzz builder image lives in:
+- `./fuzzers/install_oss_fuzz_build_deps.sh`
+The `oss-fuzz` project `Dockerfile` should call this script during image build.
+## Issues
+- [PostGIS OSS-Fuzz issue list](https://issues.oss-fuzz.com/issues?q=postgis)
+## Local Workflow
+### Simulate Dummy Fuzzer Build
+```bash
+make dummyfuzzers
+Artifacts are created in `/tmp`:
+- `/tmp/*_fuzzer`
+- `/tmp/*_fuzzer_seed_corpus.zip`
+- Runtime shared libraries in `/tmp/lib` (when available)
+Run one fuzzer locally:
+```bash
+/tmp/wkt_import_fuzzer a_file_name
+### Run OSS-Fuzz Locally
+```bash
+git clone --depth=1 https://github.com/google/oss-fuzz.git
+cd oss-fuzz
+python infra/helper.py build_image postgis
+python infra/helper.py build_fuzzers --sanitizer address postgis
+python infra/helper.py run_fuzzer postgis wkt_import_fuzzer
+## Handling Reported OSS-Fuzz Issues
+1. Leave a comment in the bug entry to indicate that you are working on it.
+2. Implement the fix.
+3. Commit with a message including `Credit to OSS-Fuzz` and a link to the OSS-Fuzz ticket.
+4. Add a link to the implementing changeset/commit in the OSS-Fuzz ticket.
+5. Verify OSS-Fuzz closes the bug (usually within a day or two).
diff --git a/fuzzers/build_google_oss_fuzzers.sh b/fuzzers/build_google_oss_fuzzers.sh
index cca450323..4f1435c24 100755
--- a/fuzzers/build_google_oss_fuzzers.sh
+++ b/fuzzers/build_google_oss_fuzzers.sh
@@ -18,6 +18,11 @@ if [ "$CXX" == "" ]; then
fi
SRC_DIR=$(dirname $0)/..
+JSON_C_LIBS=$(pkg-config --libs json-c)
+GEOS_LIBS=$(geos-config --clibs)
+PROJ_XML2_LIBS=$(pkg-config --libs proj libxml-2.0)
+POSTGIS_FUZZER_LIBS="$JSON_C_LIBS $GEOS_LIBS $PROJ_XML2_LIBS"
+POSTGIS_PACKAGE_RUNTIME_LIBS="${POSTGIS_PACKAGE_RUNTIME_LIBS:-1}"
build_fuzzer()
@@ -28,7 +33,37 @@ build_fuzzer()
echo "Building fuzzer $fuzzerName"
$CXX $CXXFLAGS -std=c++11 -I$SRC_DIR/liblwgeom \
$sourceFilename $* -o $OUT/$fuzzerName \
- -lFuzzingEngine -lstdc++ $SRC_DIR/liblwgeom/.libs/liblwgeom.a /usr/lib/x86_64-linux-gnu/libjson-c.a
+ -lFuzzingEngine -lstdc++ $SRC_DIR/liblwgeom/.libs/liblwgeom.a $POSTGIS_FUZZER_LIBS
+package_runtime_libs()
+ mkdir -p "$OUT/lib"
+ for fuzzer in "$OUT"/*_fuzzer; do
+ [ -f "$fuzzer" ] || continue
+ if command -v patchelf >/dev/null 2>&1; then
+ patchelf --set-rpath '$ORIGIN/lib' "$fuzzer"
+ fi
+ while read -r lib; do
+ [ -f "$lib" ] || continue
+ base="$(basename "$lib")"
+ case "$base" in
+ libc.so.*|libm.so.*|libdl.so.*|libpthread.so.*|librt.so.*|libgcc_s.so.*|ld-linux*.so.*|linux-vdso.so.*|libresolv.so.*)
+ continue
+ esac
+ cp -n "$lib" "$OUT/lib/" || true
+ done < <(ldd "$fuzzer" | awk '/=> \// {print $3}')
+ done
+ patchelf --set-rpath '$ORIGIN' "$OUT"/lib/*.so* 2>/dev/null || true
+ fi
fuzzerFiles=$(dirname $0)/*.cpp
@@ -38,3 +73,7 @@ for F in $fuzzerFiles; do
done
cp $(dirname $0)/*.dict $(dirname $0)/*.options $(dirname $0)/*.zip $OUT/
+if [ "$POSTGIS_PACKAGE_RUNTIME_LIBS" != "0" ]; then
+ package_runtime_libs
+fi
diff --git a/fuzzers/build_oss_fuzz.sh b/fuzzers/build_oss_fuzz.sh
new file mode 100755
index 000000000..5b65ddcda
--- /dev/null
+++ b/fuzzers/build_oss_fuzz.sh
@@ -0,0 +1,45 @@
+#!/usr/bin/env bash
+set -e
+if [ "$CC" == "" ]; then
+ echo "CC env var not defined"
+ exit 1
+fi
+if [ "$CXX" == "" ]; then
+ echo "CXX env var not defined"
+ exit 1
+fi
+if [ "$OUT" == "" ]; then
+ echo "OUT env var not defined"
+ exit 1
+fi
+FUZZERS_DIR=$(cd "$(dirname "$0")" && pwd)
+SRC_DIR=$(dirname "$FUZZERS_DIR")
+mkdir -p "$OUT"
+if [ "$SRC" == "" ]; then
+ export SRC="$SRC_DIR"
+fi
+export CXXFLAGS="$CXXFLAGS -std=c++11"
+POSTGIS_OSS_FUZZ_CONFIGURE_FLAGS=(
+ --enable-static
+ --without-raster
+ --without-protobuf
+ --enable-debug
+cd "$SRC_DIR"
+./autogen.sh
+./configure CC="$CC" CXX="$CXX" "${POSTGIS_OSS_FUZZ_CONFIGURE_FLAGS[@]}"
+cd liblwgeom
+make clean -s
+make -j"$(nproc)" -s
+cd ..
+bash ./fuzzers/build_google_oss_fuzzers.sh
+bash ./fuzzers/build_seed_corpus.sh
diff --git a/fuzzers/install_oss_fuzz_build_deps.sh b/fuzzers/install_oss_fuzz_build_deps.sh
index 000000000..992d20369
--- /dev/null
+++ b/fuzzers/install_oss_fuzz_build_deps.sh
@@ -0,0 +1,23 @@
+set -e
+if ! command -v apt-get >/dev/null 2>&1; then
+ echo "apt-get not found"
+ exit 1
+fi
+if [ "$(id -u)" -ne 0 ]; then
+ echo "This script must run as root inside the OSS-Fuzz builder image"
+ exit 1
+fi
+export DEBIAN_FRONTEND="${DEBIAN_FRONTEND:-noninteractive}"
+apt-get update
+apt-get install -y --no-install-recommends \
+ make autoconf automake libtool g++ postgresql-server-dev-all \
+ libgeos-dev libproj-dev libxml2-dev pkg-config libjson-c-dev \
+ libc++-dev libc++abi-dev patchelf
+rm -rf /var/lib/apt/lists/*
Summary of changes:
NEWS | 6 ++--
configure.ac | 18 +++++++---
fuzzers/README.TXT | 38 --------------------
fuzzers/README.md | 64 ++++++++++++++++++++++++++++++++++
fuzzers/build_google_oss_fuzzers.sh | 41 +++++++++++++++++++++-
fuzzers/build_oss_fuzz.sh | 45 ++++++++++++++++++++++++
fuzzers/install_oss_fuzz_build_deps.sh | 23 ++++++++++++
7 files changed, 190 insertions(+), 45 deletions(-)
delete mode 100644 fuzzers/README.TXT
create mode 100644 fuzzers/README.md
create mode 100755 fuzzers/build_oss_fuzz.sh
create mode 100755 fuzzers/install_oss_fuzz_build_deps.sh
hooks/post-receive
