[SCM] PostGIS branch master updated. 3.6.0rc2-360-g8b07652d0
Fri Mar 6 01:08:41 PST 2026
the project "PostGIS".
       via  8b07652d087b33fc347ee243b7af998fa58ab4a3 (commit)
      from  eabe42d06e572fedfd6684c1be542e41097e5bc2 (commit)
revisions in full, below.
commit 8b07652d087b33fc347ee243b7af998fa58ab4a3
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Mar 6 00:00:02 2026 +0400
    regress: stabilize topology output across architectures
    Break tied topology edge, node, and edge-end selections deterministically so regressions no longer depend on platform-specific ordering.
    Refresh alphashape_components expected output to match current SFCGAL behavior.
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index ba42f592c..054c2b21c 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -5193,22 +5193,48 @@ _lwt_minTolerance( LWGEOM *g )
 #define _LWT_MINTOLERANCE( topo, geom ) ( \
   topo->precision ?  topo->precision : _lwt_minTolerance(geom) )
-typedef struct scored_pointer_t {
-  void *ptr;
-  double score;
-} scored_pointer;
+typedef struct scored_node_t {
+	LWT_ISO_NODE *node;
+	double score;
+} scored_node;
 static int
-compare_scored_pointer(const void *si1, const void *si2)
+compare_scored_node(const void *si1, const void *si2)
-  double a = ((scored_pointer *)si1)->score;
-  double b = ((scored_pointer *)si2)->score;
-  if ( a < b )
-    return -1;
-  else if ( a > b )
-    return 1;
-  else
-    return 0;
+	const scored_node *a = si1;
+	const scored_node *b = si2;
+	if (a->score < b->score)
+		return -1;
+	else if (a->score > b->score)
+		return 1;
+	else if (a->node->node_id < b->node->node_id)
+		return -1;
+	else if (a->node->node_id > b->node->node_id)
+		return 1;
+	else
+		return 0;
+typedef struct scored_edge_t {
+	LWT_ISO_EDGE *edge;
+	double score;
+} scored_edge;
+static int
+compare_scored_edge(const void *si1, const void *si2)
+	const scored_edge *a = si1;
+	const scored_edge *b = si2;
+		return -1;
+		return 1;
+	else if (a->edge->edge_id < b->edge->edge_id)
+		return -1;
+	else if (a->edge->edge_id > b->edge->edge_id)
+		return 1;
+	else
+		return 0;
 /* Return identifier of an equal edge, 0 if none or -1 on error
@@ -6646,7 +6672,7 @@ static LWT_ELEMID
 _lwt_SplitAllEdgesToNewNode(LWT_TOPOLOGY* topo, LWT_ISO_EDGE *edges, uint64_t num, LWPOINT *point, double tol, int *moved)
   uint64_t i, j;
-  scored_pointer *sorted = lwalloc(sizeof(scored_pointer)*num);
+  scored_edge *sorted = lwalloc(sizeof(scored_edge) * num);
   LWT_ISO_EDGE *edges2 = NULL;
   LWT_ISO_NODE node;
   node.node_id = 0; /* unneeded, but hushes a compiler warning */
@@ -6663,7 +6689,7 @@ _lwt_SplitAllEdgesToNewNode(LWT_TOPOLOGY* topo, LWT_ISO_EDGE *edges, uint64_t nu
     dist = lwgeom_mindistance2d(lwline_as_lwgeom(edges[i].geom), lwpoint_as_lwgeom(point));
     LWDEBUGF(1, "Edge %" LWTFMT_ELEMID " distance: %.15g", e->edge_id, dist);
     if ( dist >= tol ) continue;
-    sorted[j].ptr = e;
+    sorted[j].edge = e;
     sorted[j++].score = dist;
   if ( ! j )
@@ -6673,18 +6699,18 @@ _lwt_SplitAllEdgesToNewNode(LWT_TOPOLOGY* topo, LWT_ISO_EDGE *edges, uint64_t nu
   num = j;
-  qsort(sorted, num, sizeof(scored_pointer), compare_scored_pointer);
+  qsort(sorted, num, sizeof(scored_edge), compare_scored_edge);
   edges2 = lwalloc(sizeof(LWT_ISO_EDGE)*num);
   for (j=0, i=0; i<num; ++i)
     if ( sorted[i].score == sorted[0].score )
-      edges2[j++] = *((LWT_ISO_EDGE*)sorted[i].ptr);
+	    edges2[j++] = *sorted[i].edge;
     else
-      //lwline_free(((LWT_ISO_EDGE*)sorted[i].ptr)->geom);
+	    // lwline_free(sorted[i].edge->geom);
   num = j;
@@ -6890,7 +6916,7 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
   LWT_ISO_NODE *nodes, *nodes2;
   LWT_ISO_EDGE *edges;
   LWGEOM *pt = lwpoint_as_lwgeom(point);
-  scored_pointer *sorted;
+  scored_node *sorted;
   int flds;
   LWT_ELEMID id = 0;
@@ -6921,20 +6947,20 @@ _lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
     /* Order by distance if there are more than a single return */
     if ( num > 1 )
-      sorted = lwalloc(sizeof(scored_pointer)*num);
-      for (i=0; i<num; ++i)
-        sorted[i].ptr = nodes+i;
-        sorted[i].score = lwgeom_mindistance2d(lwpoint_as_lwgeom(nodes[i].geom), pt);
-        LWDEBUGF(1, "Node %" LWTFMT_ELEMID " distance: %.15g",
-          ((LWT_ISO_NODE*)(sorted[i].ptr))->node_id, sorted[i].score);
-      nodes2 = lwalloc(sizeof(LWT_ISO_NODE)*num);
-        nodes2[i] = *((LWT_ISO_NODE*)sorted[i].ptr);
+		    sorted = lwalloc(sizeof(scored_node) * num);
+		    for (i = 0; i < num; ++i)
+			    sorted[i].node = nodes + i;
+			    sorted[i].score = lwgeom_mindistance2d(lwpoint_as_lwgeom(nodes[i].geom), pt);
+			    LWDEBUGF(
+				1, "Node %" LWTFMT_ELEMID " distance: %.15g", sorted[i].node->node_id, sorted[i].score);
+		    qsort(sorted, num, sizeof(scored_node), compare_scored_node);
+		    nodes2 = lwalloc(sizeof(LWT_ISO_NODE) * num);
+			    nodes2[i] = *sorted[i].node;
       lwfree(sorted);
       lwfree(nodes);
       nodes = nodes2;
diff --git a/liblwgeom/topo/lwt_edgeend_star.c b/liblwgeom/topo/lwt_edgeend_star.c
index 600e7b6da..a9a0e7acb 100644
--- a/liblwgeom/topo/lwt_edgeend_star.c
+++ b/liblwgeom/topo/lwt_edgeend_star.c
@@ -135,6 +135,14 @@ lwt_edgeEnd_compare(const void *i1, const void *i2)
 		ret = -1;
 	else if ( ee1->azimuth > ee2->azimuth )
 		ret = 1;
+	else if (ee1->edge->edge_id < ee2->edge->edge_id)
+		ret = -1;
+	else if (ee1->edge->edge_id > ee2->edge->edge_id)
+		ret = 1;
+	else if (ee1->outgoing < ee2->outgoing)
+		ret = -1;
+	else if (ee1->outgoing > ee2->outgoing)
+		ret = 1;
 	else
 		ret = 0;
diff --git a/regress/run_test.pl b/regress/run_test.pl
index bf7386bbe..40fcce21e 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -524,7 +524,6 @@ print "  GDAL: $gdalver\n" if $gdalver;
 # allow hook scripts to perform arbitrary reports via output of INFO strings
 system("grep INFO $REGRESS_LOG | sed 's/INFO://'");
 # Run the tests
diff --git a/sfcgal/regress/alphashape_components_expected b/sfcgal/regress/alphashape_components_expected
index a30a4ad59..022ef1221 100644
--- a/sfcgal/regress/alphashape_components_expected
+++ b/sfcgal/regress/alphashape_components_expected
@@ -1,2 +1,2 @@
-CG_Optimalalphashape_2components|MULTIPOLYGON(((8.3 11.8,6.2 12.1,4.1 11.9,2.6 11.2,1.1 10.1,0.3 8.2,0.1 6.1,0.4 4,1.2 2.3,2.5 1,4.2 0.3,6 0,8.1 0.1,10.1 0.2,9.2 2.4,7.8 2.2,6 2.3,3.6 6.2,7.6 9.8,9.1 9.9,10.2 11.1,8.3 11.8)),((55.6 12.1,55.8 15,54.3 15.2,52.9 10.6,52.7 7.3,52.8 4.1,46.9 2.8,43.3 7.1,43.1 10.4,43.1 15.3,41.9 15.6,40.5 15.2,40.2 12.3,40.4 9,39.8 6.2,40.1 3.1,40.3 0.4,42.1 0.3,44.2 0.2,49.8 -0.2,52.6 0.1,55.4 0.5,55.7 3.3,55.5 6,55.9 9.2,55.6 12.1)))
-CG_OptimalAlphaShape_hole_2components|MULTIPOLYGON(((5.5 8.5,5 9,4.5 9.5,4 10,3 10,2 10,1 10,0.5 10,0.23 10,0.03 9.82,0 9,0 8,0 7,0 6,0 5,0 4,0 3,0 2,0 1,0 0,0.5 0,1 0,2 0,3 0,4 0,5 0,5.5 0.5,6 1,6 2,5.8 2.5,5.5 3,5 3.5,4.5 4,4 4.5,5 5,5.5 5.5,6 6,6 7,6 8,5.5 8.5),(0.5 2,0.5 3,1 4,2 4,3 4,4 4,4.5 3.5,5 3,5.1 2.5,5.5 2,5.5 1,5 0.5,4 0.5,3 0.5,2 0.5,1 0.5,0.5 1,0.5 2),(0.5 7,0.5 8,0.5 9,1 9.5,2 9.5,3 9.5,4 9.5,4.5 9,5 8.5,5.5 8,5.5 7,5.5 6.5,5.5 6,5 5.5,4 5.5,3 5.5,2 5.5,1 5.5,0.5 6,0.5 7)),((17.5 8.5,17 9,16.5 9.5,16 10,15 10,14 10,13 10,12.5 10,12 10,12 9,12 8,12 7,12 6,12 5,12 4,12 3,12 2,12 1,12 0,12.5 0,13 1,13 2,13 3,13 4,13 5,14 5,15 5,16 5,17 5,17.5 5.5,18 6,18 7,18 7.3,18 8,17.5 8.5),(12.5 7,12.5 8,12.5 9,13 9.5,14 9.5,15 9.5,16 9.5,16.5 9,17 8.5,17.5 8,17.5 7.4,17.5 7,17.5 6.5,17.5 6,17 5.5,16 5.5,15 5.5,14 5.5,13 5.5,12.5 6,12.5 7)))
+CG_Optimalalphashape_2components|POLYGON((0.1 6.1,0.3 8.2,1.1 10.1,2.6 11.2,4.1 11.9,6.2 12.1,8.3 11.8,10.2 11.1,9.1 9.9,7.6 9.8,3.6 6.2,6 2.3,7.8 2.2,9.2 2.4,10.1 0.2,8.1 0.1,6 0,4.2 0.3,2.5 1,1.2 2.3,0.4 4,55.6 12.1,55.9 9.2,55.5 6,55.7 3.3,55.4 0.5,52.6 0.1,49.8 -0.2,44.2 0.2,42.1 0.3,40.3 0.4,40.1 3.1,39.8 6.2,40.4 9,40.2 12.3,40.5 15.2,41.9 15.6,43.1 15.3,43.1 10.4,43.3 7.1,46.9 2.8,52.8 4.1,52.7 7.3,52.9 10.6,54.3 15.2,55.8 15,0.1 6.1))
+CG_OptimalAlphaShape_hole_2components|POLYGON((0 0,0 1,0 2,0 3,0 4,0 5,0 6,0 7,0 8,0 9,0.03 9.82,0.23 10,0.5 10,1 10,2 10,3 10,4 10,4.5 9.5,5 9,5.5 8.5,6 8,6 7,6 6,5.5 5.5,5 5,4 4.5,4.5 4,5 3.5,5.5 3,5.8 2.5,6 2,6 1,5.5 0.5,5 0,4 0,3 0,2 0,1 0,0.5 0,12 0,12 1,12 2,12 3,12 4,12 5,12 6,12 7,12 8,12 9,12 10,12.5 10,13 10,14 10,15 10,16 10,16.5 9.5,17 9,17.5 8.5,18 8,18 7.3,18 7,18 6,17.5 5.5,17 5,16 5,15 5,14 5,13 5,13 4,13 3,13 2,13 1,12.5 0,0 0),(0.5 1,0.5 2,0.5 3,1 4,2 4,3 4,4 4,4.5 3.5,5 3,5.1 2.5,5.5 2,5.5 1,5 0.5,4 0.5,3 0.5,2 0.5,1 0.5,0.5 6,0.5 7,0.5 8,0.5 9,1 9.5,2 9.5,3 9.5,4 9.5,4.5 9,5 8.5,5.5 8,5.5 7,5.5 6.5,5.5 6,5 5.5,4 5.5,3 5.5,2 5.5,1 5.5,0.5 1),(12.5 6,12.5 7,12.5 8,12.5 9,13 9.5,14 9.5,15 9.5,16 9.5,16.5 9,17 8.5,17.5 8,17.5 7.4,17.5 7,17.5 6.5,17.5 6,17 5.5,16 5.5,15 5.5,14 5.5,13 5.5,12.5 6))
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index f6bd71a5c..7707ece2b 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -3048,7 +3048,11 @@ cb_getClosestEdge( const LWT_BE_TOPOLOGY* topo, const LWPOINT* pt, uint64_t *num
   appendStringInfoString(sql, "SELECT ");
   addEdgeFields(sql, fields, 0);
-  appendStringInfo(sql, " FROM \"%s\".edge_data ORDER BY geom <-> $1 ASC LIMIT 1", topo->name);
+  appendStringInfo(sql,
+		   " FROM \"%s\".edge_data"
+		   " ORDER BY geom <-> $1 ASC, edge_id ASC"
+		   " LIMIT 1",
+		   topo->name);
   POSTGIS_DEBUGF(1, "cb_getClosestEdge query: %s", sql->data);
Summary of changes:
 liblwgeom/topo/lwgeom_topo.c                  | 94 +++++++++++++++++----------
 liblwgeom/topo/lwt_edgeend_star.c             |  8 +++
 regress/run_test.pl                           |  1 -
 sfcgal/regress/alphashape_components_expected |  4 +-
 topology/postgis_topology.c                   |  6 +-
 5 files changed, 75 insertions(+), 38 deletions(-)
hooks/post-receive
