[SCM] PostGIS branch master updated. 3.6.0rc2-361-g99af6dc68
git at osgeo.org
git at osgeo.org
Fri Mar 6 01:18:58 PST 2026
the project "PostGIS".
via 99af6dc68c1085547e6cc8158178de20f982191c (commit)
from 8b07652d087b33fc347ee243b7af998fa58ab4a3 (commit)
revisions in full, below.
commit 99af6dc68c1085547e6cc8158178de20f982191c
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Mar 6 13:16:51 2026 +0400
regress: stabilize parser locations in core SQL tests
diff --git a/regress/core/bestsrid.sql b/regress/core/bestsrid.sql
index 2437a4d02..4745e808f 100644
--- a/regress/core/bestsrid.sql
+++ b/regress/core/bestsrid.sql
@@ -26,6 +26,6 @@ select 'world', _ST_BestSRID(ST_Point(-160, -40), ST_Point(160, 40));
-- infinite coords
SELECT _ST_BestSRID(ST_Point('-infinity', 'infinity'));
-SELECT '#5347', ST_Intersection('0102000020E610000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geography,
- '0101000020E6100000000000000000F07F000000000000F07F'::geography);
+-- Keep this statement on one line so parser notice locations stay stable
+-- across LF and CRLF platforms.
+SELECT '#5347', ST_Intersection('0102000020E610000005000000000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F000000000000F07F'::geography, '0101000020E6100000000000000000F07F000000000000F07F'::geography);
diff --git a/regress/core/bestsrid_expected b/regress/core/bestsrid_expected
index 3947d96ec..ecc32b2a9 100644
--- a/regress/core/bestsrid_expected
+++ b/regress/core/bestsrid_expected
@@ -128,5 +128,5 @@ world|999000
NOTICE: Coordinate values were coerced into range [-180 -90, 180 90] for GEOGRAPHY
ERROR: Error in geography_bestsrid calling with infinite coordinate geographies
NOTICE: Coordinate values were coerced into range [-180 -90, 180 90] for GEOGRAPHY at character 33
-NOTICE: Coordinate values were coerced into range [-180 -90, 180 90] for GEOGRAPHY at character 257
+NOTICE: Coordinate values were coerced into range [-180 -90, 180 90] for GEOGRAPHY at character 234
diff --git a/regress/core/dumpsegments.sql b/regress/core/dumpsegments.sql
index 8dd838912..566adb095 100644
--- a/regress/core/dumpsegments.sql
+++ b/regress/core/dumpsegments.sql
@@ -98,15 +98,13 @@ FROM st_dumpsegments(
-- Check dumping a degenerate (even number of points) circular string
-SELECT 'dumpsegments15', path, st_astext(geom)
-FROM st_dumpsegments(
-'010800000006000000000000000000f03f000000000000f03f0000000000000040000000000000004000000000000008400000000000000840000000000000104000000000000010400000000000001440000000000000144000000000000018400000000000001840'
+SELECT 'dumpsegments15', path, st_astext(geom) FROM st_dumpsegments('010800000006000000000000000000f03f000000000000f03f0000000000000040000000000000004000000000000008400000000000000840000000000000104000000000000010400000000000001440000000000000144000000000000018400000000000001840');
-- Check dumping a compound that contains a degenerate circular
-- string
-SELECT 'dumpsegments16', path, st_astext(geom)
-'010900000002000000010200000007000000000000000000f03f000000000000f03f00000000000000400000000000000040000000000000084000000000000008400000000000001040000000000000104000000000000014400000000000001440000000000000184000000000000018400000000000001c400000000000001c400108000000060000000000000000001c400000000000001c400000000000001840000000000000184000000000000014400000000000001440000000000000104000000000000010400000000000000840000000000000084000000000000000400000000000000040'
+SELECT 'dumpsegments16', path, st_astext(geom) FROM st_dumpsegments('010900000002000000010200000007000000000000000000f03f000000000000f03f00000000000000400000000000000040000000000000084000000000000008400000000000001040000000000000104000000000000014400000000000001440000000000000184000000000000018400000000000001c400000000000001c400108000000060000000000000000001c400000000000001c400000000000001840000000000000184000000000000014400000000000001440000000000000104000000000000010400000000000000840000000000000084000000000000000400000000000000040');
diff --git a/regress/core/dumpsegments_expected b/regress/core/dumpsegments_expected
index d08b9a948..6bc404677 100644
--- a/regress/core/dumpsegments_expected
+++ b/regress/core/dumpsegments_expected
@@ -70,10 +70,10 @@ dumpsegments14|{1,1,1,6}|LINESTRING(6 6,7 7)
dumpsegments14|{1,1,2,1}|CIRCULARSTRING(7 7,6 6,5 5)
dumpsegments14|{1,1,2,2}|CIRCULARSTRING(5 5,4 4,3 3)
dumpsegments14|{1,1,2,3}|CIRCULARSTRING(3 3,2 2,1 1)
-NOTICE: lwcircstring_construct: invalid point count 6 at character 70
+NOTICE: lwcircstring_construct: invalid point count 6 at character 69
dumpsegments15|{1}|CIRCULARSTRING(1 1,2 2,3 3)
dumpsegments15|{2}|CIRCULARSTRING(3 3,4 4,5 5)
dumpsegments16|{1,1}|LINESTRING(1 1,2 2)
dumpsegments16|{1,2}|LINESTRING(2 2,3 3)
dumpsegments16|{1,3}|LINESTRING(3 3,4 4)
Summary of changes:
regress/core/bestsrid.sql | 6 +++---
regress/core/bestsrid_expected | 2 +-
regress/core/dumpsegments.sql | 14 ++++++--------
regress/core/dumpsegments_expected | 4 ++--
4 files changed, 12 insertions(+), 14 deletions(-)
hooks/post-receive
