[SCM] PostGIS branch master updated. 3.6.0rc2-366-g67d1d0640
git at osgeo.org
git at osgeo.org
Fri Mar 6 08:15:30 PST 2026
the project "PostGIS".
via 67d1d0640e2e01d1fff997372bf357250fecc90d (commit)
via 17f698631baf0c3b4c63ec474fed51d9518a0e1a (commit)
from 2cbc46f2915e694ec329407503574004c16311b9 (commit)
revisions in full, below.
commit 67d1d0640e2e01d1fff997372bf357250fecc90d
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Mar 6 20:14:52 2026 +0400
doc: fix comment SQL escaping and spell checks
diff --git a/.codespellrc b/.codespellrc
index 016dfb022..964a27237 100644
--- a/.codespellrc
+++ b/.codespellrc
@@ -1,3 +1,4 @@
[codespell]
-skip = *.po,spatial_ref_sys.sql,./deps,./extensions/address_standardizer,./configure*,./autom4te.cache,./build-aux,./libtool,.git,build*
+# utils/check_spelling.sh builds a deterministic list of tracked files plus
+# generated comment SQL.
ignore-words = .codespell.ignore
diff --git a/.github/workflows/codespell.yml b/.github/workflows/codespell.yml
index 302aa40a1..617153b0b 100644
--- a/.github/workflows/codespell.yml
+++ b/.github/workflows/codespell.yml
@@ -21,9 +21,12 @@ jobs:
- name: 'Install codespell'
run: |
+ sudo apt-get update
+ sudo apt-get install -y --no-install-recommends libxml2-utils docbook-xml docbook-xsl docbook-xsl-ns xsltproc
sudo pip install codespell
- name: 'Build & Test'
run: |
codespell --version
- codespell -I ".codespell.ignore"
+ make -C doc comments
+ ./utils/check_spelling.sh
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 1e0c2fb92..e468eed66 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -307,7 +307,7 @@ endif
check-spell:
ifneq (@CODESPELL@,)
- cd $(top_srcdir) && @CODESPELL@
+ cd $(top_srcdir) && ./utils/check_spelling.sh @CODESPELL@
else
@echo "SKIP: spell checking disabled"
endif
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index d319ec99a..f571d2fcc 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -4346,7 +4346,7 @@ msgid ""
"topogeometries created before the upgrade. This function fixes this "
"corruption in affected tables."
msgstr ""
-"从 PostGIS topology 版本 <3.6.0 升级到 >3.6.0+ 时,topogeometry "
+"从 PostGIS topology 版本 <3.6.0 升级到 >3.6.0+ 时,topogeometry "
"列的定义发生了变化,导致升级前创建的 topogeometry "
"数据出现损坏。这个函数用来修复受影响表中的这些损坏问题。"
diff --git a/doc/xsl/postgis_comments.sql.xsl b/doc/xsl/postgis_comments.sql.xsl
index 3e5333d2a..3e27ba993 100644
--- a/doc/xsl/postgis_comments.sql.xsl
+++ b/doc/xsl/postgis_comments.sql.xsl
@@ -22,6 +22,7 @@
<xsl:template match="db:chapter">
<xsl:variable name="ap"><xsl:text>'</xsl:text></xsl:variable>
+ <xsl:variable name="apesc"><xsl:text>''</xsl:text></xsl:variable>
<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment -->
<xsl:for-each select="db:section[not(contains(@xml:id,'Operator') or contains(@xml:id,'sfcgal') or contains(@xml:id,'GUC') )]/db:refentry">
<xsl:variable name='plaincomment'>
@@ -32,7 +33,7 @@
<xsl:call-template name="globalReplace">
<xsl:with-param name="outputString" select="$plaincomment"/>
<xsl:with-param name="target" select="$ap"/>
- <xsl:with-param name="replacement" select="''"/>
+ <xsl:with-param name="replacement" select="$apesc"/>
</xsl:call-template>
</xsl:variable>
<xsl:choose>
diff --git a/doc/xsl/raster_comments.sql.xsl b/doc/xsl/raster_comments.sql.xsl
index d9dd68970..450904c7d 100644
--- a/doc/xsl/raster_comments.sql.xsl
+++ b/doc/xsl/raster_comments.sql.xsl
@@ -24,6 +24,7 @@
<xsl:for-each select="db:section[not(contains(@xml:id,'Operator'))]/db:refentry">
@@ -34,7 +35,7 @@
</xsl:variable>
<!-- For each function prototype generate the DDL comment statement
@@ -51,6 +52,7 @@ COMMENT ON <xsl:choose><xsl:when test="contains(db:paramdef/db:type,'geometry se
<xsl:template match="db:section[contains(@xml:id, 'Type')]">
<xsl:for-each select="db:refentry">
<!-- If this is a raster type grab the ref entry summary and refname to make type comment -->
@@ -61,7 +63,7 @@ COMMENT ON <xsl:choose><xsl:when test="contains(db:paramdef/db:type,'geometry se
</xsl:variable>
COMMENT ON TYPE <xsl:value-of select="db:refnamediv/db:refname" /> IS 'postgis raster type: <xsl:value-of select='$comment' />';
diff --git a/doc/xsl/sfcgal_comments.sql.xsl b/doc/xsl/sfcgal_comments.sql.xsl
index 6eb857037..116da9a30 100644
--- a/doc/xsl/sfcgal_comments.sql.xsl
+++ b/doc/xsl/sfcgal_comments.sql.xsl
@@ -23,6 +23,7 @@
@@ -33,7 +34,7 @@
</xsl:variable>
diff --git a/doc/xsl/tiger_geocoder_comments.sql.xsl b/doc/xsl/tiger_geocoder_comments.sql.xsl
index 547e22747..4983947c9 100644
--- a/doc/xsl/tiger_geocoder_comments.sql.xsl
+++ b/doc/xsl/tiger_geocoder_comments.sql.xsl
@@ -23,6 +23,7 @@
<xsl:for-each select="db:section[@xml:id='Tiger_Geocoder']/db:refentry">
@@ -33,7 +34,7 @@
</xsl:variable>
diff --git a/doc/xsl/topology_comments.sql.xsl b/doc/xsl/topology_comments.sql.xsl
index 5d67d8f15..68758a455 100644
--- a/doc/xsl/topology_comments.sql.xsl
+++ b/doc/xsl/topology_comments.sql.xsl
@@ -23,6 +23,7 @@
@@ -33,7 +34,7 @@
</xsl:variable>
<xsl:choose>
diff --git a/utils/check_spelling.sh b/utils/check_spelling.sh
new file mode 100755
index 000000000..5537675ed
--- /dev/null
+++ b/utils/check_spelling.sh
@@ -0,0 +1,44 @@
+#!/bin/sh
+set -eu
+CODESPELL=${1:-codespell}
+ROOT=$(git rev-parse --show-toplevel 2>/dev/null || pwd)
+cd "$ROOT"
+tmpfiles=$(mktemp)
+trap 'rm -f "$tmpfiles"' EXIT HUP INT TERM
+# Keep the check deterministic by starting from tracked files and excluding
+# vendor data, generated trees, and authoritative datasets that are not prose.
+git ls-files -z -- . \
+ ':(exclude)deps' \
+ ':(exclude)extensions/address_standardizer' \
+ ':(exclude)doc/html' \
+ ':(exclude)doc/po' \
+ ':(exclude)doc/postgis-out.xml' \
+ ':(exclude)doc/postgis-nospecial.xml' \
+ ':(exclude)aclocal.m4' \
+ ':(exclude)configure' \
+ ':(exclude)macros/libtool.m4' \
+ ':(exclude)spatial_ref_sys.sql' \
+ ':(exclude)extensions/postgis/sql/spatial_ref_sys.sql' \
+ ':(glob,exclude)extensions/postgis/sql/postgis--*.sql' \
+ ':(glob,exclude)**/*.po' \
+ > "$tmpfiles"
+# The comment SQL files are generated from the docs and shipped in release
+# artifacts, so include them when they exist.
+for generated in doc/postgis_comments.sql \
+ doc/raster_comments.sql \
+ doc/sfcgal_comments.sql \
+ doc/tiger_geocoder_comments.sql \
+ doc/topology_comments.sql
+do
+ if [ -f "$generated" ]; then
+ printf '%s\0' "$generated" >> "$tmpfiles"
+ fi
+done
+xargs -0 "$CODESPELL" --config .codespellrc < "$tmpfiles"
commit 17f698631baf0c3b4c63ec474fed51d9518a0e1a
Date: Fri Mar 6 19:45:36 2026 +0400
geos: use fixed-width flags in signedness-sensitive paths
diff --git a/liblwgeom/cunit/cu_geos_cluster.c b/liblwgeom/cunit/cu_geos_cluster.c
index 78d8c35c9..20129f14b 100644
--- a/liblwgeom/cunit/cu_geos_cluster.c
+++ b/liblwgeom/cunit/cu_geos_cluster.c
@@ -22,7 +22,7 @@ static void assert_all_results_found(LWGEOM** results, size_t num_outputs, LWGEO
size_t i, j;
- char found_equal = 0;
+ uint8_t found_equal = 0;
for (i = 0; i < num_outputs; i++)
for (j = 0; j < num_expected_outputs; j++)
@@ -271,7 +271,7 @@ static void do_dbscan_test(struct dbscan_test_info test)
LWGEOM** geoms = WKTARRAY2LWGEOM(test.wkt_inputs, test.num_geoms);
UNIONFIND* uf = UF_create(test.num_geoms);
uint32_t* ids;
- char* in_a_cluster;
+ uint8_t *in_a_cluster;
uint32_t i;
union_dbscan(geoms, test.num_geoms, uf, test.eps, test.min_points, &in_a_cluster);
diff --git a/liblwgeom/cunit/cu_unionfind.c b/liblwgeom/cunit/cu_unionfind.c
index 223129866..fb00dc5c1 100644
--- a/liblwgeom/cunit/cu_unionfind.c
+++ b/liblwgeom/cunit/cu_unionfind.c
@@ -66,7 +66,7 @@ static void test_unionfind_ordered_by_cluster(void)
uint32_t* ids_by_cluster = UF_ordered_by_cluster(&uf);
- char encountered_cluster[] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
+ uint8_t encountered_cluster[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
uint32_t i;
for (i = 0; i < uf.N; i++)
@@ -147,7 +147,7 @@ static void test_unionfind_collapse_cluster_ids(void)
lwfree(collapsed_ids);
- char is_in_cluster[] = { 0, 1, 1, 1, 0, 1, 0, 0, 0, 0 };
+ uint8_t is_in_cluster[] = {0, 1, 1, 1, 0, 1, 0, 0, 0, 0};
uint32_t expected_collapsed_ids2[] = { 8, 0, 0, 0, 7, 0, 8, 7, 8, 7 };
collapsed_ids = UF_get_collapsed_cluster_ids(uf, is_in_cluster);
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index e3fb18625..b42f1eb69 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -1776,7 +1776,7 @@ lwgeom_voronoi_diagram(const LWGEOM* g, const GBOX* env, double tolerance, int o
uint32_t num_points = lwgeom_count_vertices(g);
LWGEOM* lwgeom_result;
- char is_3d = LW_FALSE;
+ uint8_t is_3d = LW_FALSE;
int32_t srid = lwgeom_get_srid(g);
GEOSCoordSequence* coords;
GEOSGeometry* geos_geom;
diff --git a/liblwgeom/lwgeom_geos.h b/liblwgeom/lwgeom_geos.h
index 2d80819fb..f444cb6e5 100644
--- a/liblwgeom/lwgeom_geos.h
+++ b/liblwgeom/lwgeom_geos.h
@@ -46,7 +46,12 @@ int cluster_intersecting(GEOSGeometry **geoms, uint32_t num_geoms, GEOSGeometry
int union_intersecting_pairs(GEOSGeometry** geoms, uint32_t num_geoms, UNIONFIND* uf);
int union_related_pairs(GEOSGeometry** geoms, uint32_t num_geoms, const char* im, UNIONFIND* uf);
int cluster_within_distance(LWGEOM **geoms, uint32_t num_geoms, double tolerance, LWGEOM ***clusterGeoms, uint32_t *num_clusters);
-int union_dbscan(LWGEOM **geoms, uint32_t num_geoms, UNIONFIND *uf, double eps, uint32_t min_points, char **is_in_cluster_ret);
+int union_dbscan(LWGEOM **geoms,
+ uint32_t num_geoms,
+ UNIONFIND *uf,
+ double eps,
+ uint32_t min_points,
+ uint8_t **is_in_cluster_ret);
POINTARRAY* ptarray_from_GEOSCoordSeq(const GEOSCoordSequence* cs, uint8_t want3d);
diff --git a/liblwgeom/lwgeom_geos_cluster.c b/liblwgeom/lwgeom_geos_cluster.c
index 318d3558e..64ca68f5f 100644
--- a/liblwgeom/lwgeom_geos_cluster.c
+++ b/liblwgeom/lwgeom_geos_cluster.c
@@ -48,9 +48,14 @@ struct STRTree
uint32_t num_geoms;
-static struct STRTree make_strtree(void** geoms, uint32_t num_geoms, char is_lwgeom);
+static struct STRTree make_strtree(void **geoms, uint32_t num_geoms, uint8_t is_lwgeom);
static void destroy_strtree(struct STRTree * tree);
-static int combine_geometries(UNIONFIND* uf, void** geoms, uint32_t num_geoms, void*** clustersGeoms, uint32_t* num_clusters, char is_lwgeom);
+static int combine_geometries(UNIONFIND *uf,
+ void **geoms,
+ void ***clustersGeoms,
+ uint32_t *num_clusters,
+ uint8_t is_lwgeom);
/* Make a minimal GEOSGeometry* whose Envelope covers the same 2D extent as
* the supplied GBOX. This is faster and uses less memory than building a
@@ -77,7 +82,7 @@ geos_envelope_surrogate(const LWGEOM* g)
/** Make a GEOSSTRtree that stores a pointer to a variable containing
* the array index of the input geoms */
-make_strtree(void** geoms, uint32_t num_geoms, char is_lwgeom)
+make_strtree(void **geoms, uint32_t num_geoms, uint8_t is_lwgeom)
struct STRTree tree;
tree.envelopes = 0;
@@ -385,7 +390,7 @@ dbscan_update_context(GEOSSTRtree* tree, struct QueryContext* cxt, LWGEOM** geom
* Applicable to DBSCAN with minpoints > 1.
static void
-union_if_available(UNIONFIND* uf, uint32_t p, uint32_t q, char* is_in_core, char* in_a_cluster)
+union_if_available(UNIONFIND *uf, uint32_t p, uint32_t q, uint8_t *is_in_core, uint8_t *in_a_cluster)
if (in_a_cluster[q])
@@ -411,7 +416,7 @@ union_if_available(UNIONFIND* uf, uint32_t p, uint32_t q, char* is_in_core, char
* to avoid some distance computations altogether.
static int
-union_dbscan_minpoints_1(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, double eps, char** in_a_cluster_ret)
+union_dbscan_minpoints_1(LWGEOM **geoms, uint32_t num_geoms, UNIONFIND *uf, double eps, uint8_t **in_a_cluster_ret)
uint32_t p, i;
@@ -425,7 +430,7 @@ union_dbscan_minpoints_1(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, doub
if (in_a_cluster_ret)
- char* in_a_cluster = lwalloc(num_geoms * sizeof(char));
+ uint8_t *in_a_cluster = lwalloc(num_geoms * sizeof(uint8_t));
for (i = 0; i < num_geoms; i++)
in_a_cluster[i] = LW_TRUE;
*in_a_cluster_ret = in_a_cluster;
@@ -481,7 +486,12 @@ union_dbscan_minpoints_1(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, doub
static int
-union_dbscan_general(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, double eps, uint32_t min_points, char** in_a_cluster_ret)
+union_dbscan_general(LWGEOM **geoms,
+ UNIONFIND *uf,
+ double eps,
+ uint8_t **in_a_cluster_ret)
uint32_t p, i;
@@ -493,11 +503,11 @@ union_dbscan_general(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, double e
int success = LW_SUCCESS;
uint32_t* neighbors;
- char* is_in_core;
+ uint8_t *is_in_core;
- in_a_cluster = lwalloc(num_geoms * sizeof(char));
- memset(in_a_cluster, 0, num_geoms * sizeof(char));
+ in_a_cluster = lwalloc(num_geoms * sizeof(uint8_t));
+ memset(in_a_cluster, 0, num_geoms * sizeof(uint8_t));
@@ -517,8 +527,8 @@ union_dbscan_general(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, double e
return LW_FAILURE;
- is_in_core = lwalloc(num_geoms * sizeof(char));
- memset(is_in_core, 0, num_geoms * sizeof(char));
+ is_in_core = lwalloc(num_geoms * sizeof(uint8_t));
+ memset(is_in_core, 0, num_geoms * sizeof(uint8_t));
neighbors = lwalloc(min_points * sizeof(uint32_t));
for (p = 0; p < num_geoms; p++)
@@ -619,7 +629,13 @@ union_dbscan_general(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, double e
return success;
-int union_dbscan(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, double eps, uint32_t min_points, char** in_a_cluster_ret)
+int
+union_dbscan(LWGEOM **geoms,
+ UNIONFIND *uf,
+ double eps,
if (min_points <= 1)
return union_dbscan_minpoints_1(geoms, num_geoms, uf, eps, in_a_cluster_ret);
@@ -651,7 +667,12 @@ cluster_within_distance(LWGEOM** geoms, uint32_t num_geoms, double tolerance, LW
* GeometryCollections. Supplied geometry array may be of either LWGEOM* or GEOSGeometry*; is_lwgeom is used to
* identify which. Caller is responsible for freeing input geometry array but not the items contained within it. */
static int
-combine_geometries(UNIONFIND* uf, void** geoms, uint32_t num_geoms, void*** clusterGeoms, uint32_t* num_clusters, char is_lwgeom)
+combine_geometries(UNIONFIND *uf,
+ void **geoms,
+ void ***clusterGeoms,
size_t i, j, k;
diff --git a/liblwgeom/lwunionfind.c b/liblwgeom/lwunionfind.c
index 854a9e807..9ca47a1c3 100644
--- a/liblwgeom/lwunionfind.c
+++ b/liblwgeom/lwunionfind.c
@@ -142,13 +142,13 @@ UF_ordered_by_cluster(UNIONFIND* uf)
return ordered_ids;
-uint32_t*
-UF_get_collapsed_cluster_ids(UNIONFIND* uf, const char* is_in_cluster)
+uint32_t *
+UF_get_collapsed_cluster_ids(UNIONFIND *uf, const uint8_t *is_in_cluster)
uint32_t* ordered_components = UF_ordered_by_cluster(uf);
uint32_t* new_ids = lwalloc(uf->N * sizeof(uint32_t));
uint32_t last_old_id, current_new_id, i;
- char encountered_cluster = LW_FALSE;
+ uint8_t encountered_cluster = LW_FALSE;
current_new_id = 0; last_old_id = 0;
for (i = 0; i < uf->N; i++)
diff --git a/liblwgeom/lwunionfind.h b/liblwgeom/lwunionfind.h
index 75e0ae788..8964a3671 100644
--- a/liblwgeom/lwunionfind.h
+++ b/liblwgeom/lwunionfind.h
@@ -57,5 +57,4 @@ uint32_t* UF_ordered_by_cluster(UNIONFIND* uf);
* If is_in_cluster array is provided, it will be used to skip any indexes
* that are not in a cluster.
-uint32_t* UF_get_collapsed_cluster_ids(UNIONFIND* uf, const char* is_in_cluster);
+uint32_t *UF_get_collapsed_cluster_ids(UNIONFIND *uf, const uint8_t *is_in_cluster);
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 9b1ef3e0f..e93db0af7 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -1551,7 +1551,7 @@ Datum isvalid(PG_FUNCTION_ARGS)
GSERIALIZED *geom1;
LWGEOM *lwgeom;
- char result;
+ int8_t result;
GEOSGeom g1;
geom1 = PG_GETARG_GSERIALIZED_P(0);
@@ -1628,7 +1628,7 @@ Datum isvaliddetail(PG_FUNCTION_ARGS)
char *reason = NULL;
GEOSGeometry *geos_location = NULL;
LWGEOM *location = NULL;
- char valid = 0;
+ int8_t valid = 0;
HeapTupleHeader result;
TupleDesc tupdesc;
HeapTuple tuple;
@@ -1706,7 +1706,7 @@ Datum issimple(PG_FUNCTION_ARGS)
GSERIALIZED *geom;
LWGEOM *lwgeom_in;
- int result;
+ int8_t result;
POSTGIS_DEBUG(2, "issimple called");
@@ -1732,7 +1732,7 @@ Datum isring(PG_FUNCTION_ARGS)
GSERIALIZED *geom;
GEOSGeometry *g1;
- int result;
+ int8_t result;
geom = PG_GETARG_GSERIALIZED_P(0);
@@ -1762,7 +1762,7 @@ Datum isring(PG_FUNCTION_ARGS)
GSERIALIZED *
-GEOS2POSTGIS(GEOSGeom geom, char want3d)
+GEOS2POSTGIS(GEOSGeom geom, uint8_t want3d)
LWGEOM *lwgeom;
GSERIALIZED *result;
@@ -2662,7 +2662,7 @@ Datum LWGEOM_dfullywithin(PG_FUNCTION_ARGS)
double radius = PG_GETARG_FLOAT8(2);
GEOSGeometry *buffer1 = NULL;
GEOSGeometry *geos1 = NULL, *geos2 = NULL;
- char contained;
+ int8_t contained;
if (radius < 0.0)
diff --git a/postgis/lwgeom_geos.h b/postgis/lwgeom_geos.h
index 07707c459..1fdc58e83 100644
--- a/postgis/lwgeom_geos.h
+++ b/postgis/lwgeom_geos.h
@@ -34,7 +34,7 @@
** Public prototypes for GEOS utility functions.
-GSERIALIZED *GEOS2POSTGIS(GEOSGeom geom, char want3d);
+GSERIALIZED *GEOS2POSTGIS(GEOSGeom geom, uint8_t want3d);
GEOSGeometry *POSTGIS2GEOS(const GSERIALIZED *g);
GEOSGeometry** ARRAY2GEOS(ArrayType* array, uint32_t nelems, int* is3d, int* srid);
LWGEOM** ARRAY2LWGEOM(ArrayType* array, uint32_t nelems, int* is3d, int* srid);
diff --git a/postgis/lwgeom_geos_predicates.c b/postgis/lwgeom_geos_predicates.c
index 1219117f8..87d34a694 100644
--- a/postgis/lwgeom_geos_predicates.c
+++ b/postgis/lwgeom_geos_predicates.c
@@ -65,8 +65,8 @@ Datum ST_Equals(PG_FUNCTION_ARGS);
* Utility to quickly check for polygonal geometries
-static inline char
-is_poly(const GSERIALIZED* g)
+static inline uint8_t
+is_poly(const GSERIALIZED *g)
int type = gserialized_get_type(g);
return type == POLYGONTYPE || type == MULTIPOLYGONTYPE;
@@ -75,8 +75,8 @@ is_poly(const GSERIALIZED* g)
* Utility to quickly check for point geometries
-static inline char
-is_point(const GSERIALIZED* g)
+is_point(const GSERIALIZED *g)
return type == POINTTYPE || type == MULTIPOINTTYPE;
@@ -95,7 +95,7 @@ Datum ST_Intersects(PG_FUNCTION_ARGS)
SHARED_GSERIALIZED *shared_geom2 = ToastCacheGetGeometry(fcinfo, 1);
const GSERIALIZED *geom1 = shared_gserialized_get(shared_geom1);
const GSERIALIZED *geom2 = shared_gserialized_get(shared_geom2);
- int result;
+ int8_t result;
GBOX box1, box2;
PrepGeomCache *prep_cache;
@@ -174,7 +174,7 @@ Datum ST_Equals(PG_FUNCTION_ARGS)
- char result;
+ int8_t result;
GBOX box1, box2;
GEOSGeometry *g1, *g2;
@@ -233,7 +233,7 @@ Datum touches(PG_FUNCTION_ARGS)
- char result;
+ int8_t result;
GBOX box1, box2;
@@ -297,7 +297,7 @@ Datum disjoint(PG_FUNCTION_ARGS)
- char result;
+ int8_t result;
GBOX box1, box2;
@@ -365,7 +365,7 @@ Datum overlaps(PG_FUNCTION_ARGS)
- char result;
+ int8_t result;
GBOX box1, box2;
@@ -432,7 +432,7 @@ Datum crosses(PG_FUNCTION_ARGS)
- int result;
+ int8_t result;
GBOX box1, box2;
@@ -500,7 +500,7 @@ Datum contains(PG_FUNCTION_ARGS)
- int result;
+ int8_t result;
GBOX box1, box2;
@@ -581,7 +581,7 @@ Datum within(PG_FUNCTION_ARGS)
- int result;
+ int8_t result;
GBOX box1, box2;
@@ -661,7 +661,7 @@ Datum containsproperly(PG_FUNCTION_ARGS)
- char result;
+ int8_t result;
GBOX box1, box2;
@@ -726,7 +726,7 @@ Datum covers(PG_FUNCTION_ARGS)
- int result;
+ int8_t result;
GBOX box1, box2;
@@ -810,7 +810,7 @@ Datum coveredby(PG_FUNCTION_ARGS)
- int result;
+ int8_t result;
GBOX box1, box2;
@@ -909,7 +909,7 @@ Datum relate_pattern(PG_FUNCTION_ARGS)
text *imPtr = DatumGetTextP(DirectFunctionCall2(text_left,
PG_GETARG_DATUM(2), Int32GetDatum(9)));
char *im = text_to_cstring(imPtr);
- char result;
+ int8_t result;
uint32_t i;
#if POSTGIS_GEOS_VERSION >= 31300
@@ -1045,7 +1045,7 @@ Datum LWGEOM_dwithin(PG_FUNCTION_ARGS)
PrepGeomCache *prep_cache = NULL;
const size_t small_threshold = 1024;
- char is_dwithin = -1;
+ int8_t is_dwithin = -1;
* Only enter the GEOS/PreparedGeometry code line if one of the
@@ -1103,5 +1103,3 @@ Datum LWGEOM_dwithin(PG_FUNCTION_ARGS)
PG_RETURN_BOOL(is_dwithin);
diff --git a/postgis/lwgeom_window.c b/postgis/lwgeom_window.c
index 4e931af53..409b94503 100644
--- a/postgis/lwgeom_window.c
+++ b/postgis/lwgeom_window.c
@@ -49,14 +49,14 @@ typedef struct {
typedef struct
uint32_t cluster_id;
- char is_null; /* NULL may result from a NULL geometry input, or it may be used by
- algorithms such as DBSCAN that do not assign all inputs to a
- cluster. */
+ uint8_t is_null; /* NULL may result from a NULL geometry input, or it may be used by
+ algorithms such as DBSCAN that do not assign all inputs to a
+ cluster. */
} cluster_entry;
typedef struct
- char is_error;
+ uint8_t is_error;
cluster_entry clusters[1];
} cluster_context;
@@ -129,7 +129,7 @@ Datum ST_ClusterDBSCAN(PG_FUNCTION_ARGS)
uint32_t i;
uint32_t* result_ids;
LWGEOM** geoms;
- char* is_in_cluster = NULL;
+ uint8_t *is_in_cluster = NULL;
UNIONFIND* uf;
bool tolerance_is_null;
bool minpoints_is_null;
@@ -1035,5 +1035,3 @@ Datum ST_CoverageUnion(PG_FUNCTION_ARGS)
PG_RETURN_POINTER(result);
Summary of changes:
.codespellrc | 3 +-
.github/workflows/codespell.yml | 5 +++-
GNUmakefile.in | 2 +-
doc/po/zh_Hans/postgis-manual.po | 2 +-
doc/xsl/postgis_comments.sql.xsl | 3 +-
doc/xsl/raster_comments.sql.xsl | 6 ++--
doc/xsl/sfcgal_comments.sql.xsl | 3 +-
doc/xsl/tiger_geocoder_comments.sql.xsl | 3 +-
doc/xsl/topology_comments.sql.xsl | 3 +-
liblwgeom/cunit/cu_geos_cluster.c | 4 +--
liblwgeom/cunit/cu_unionfind.c | 4 +--
liblwgeom/lwgeom_geos.c | 2 +-
liblwgeom/lwgeom_geos.h | 7 ++++-
liblwgeom/lwgeom_geos_cluster.c | 51 +++++++++++++++++++++++----------
liblwgeom/lwunionfind.c | 6 ++--
liblwgeom/lwunionfind.h | 3 +-
postgis/lwgeom_geos.c | 12 ++++----
postgis/lwgeom_geos.h | 2 +-
postgis/lwgeom_geos_predicates.c | 36 +++++++++++------------
postgis/lwgeom_window.c | 12 ++++----
utils/check_spelling.sh | 44 ++++++++++++++++++++++++++++
21 files changed, 144 insertions(+), 69 deletions(-)
create mode 100755 utils/check_spelling.sh
hooks/post-receive
