[SCM] PostGIS branch master updated. 3.6.0rc2-369-gbe42c3370
git at osgeo.org
git at osgeo.org
Fri Mar 6 09:45:58 PST 2026
the project "PostGIS".
via be42c33700f1f4bd34ae8ee181509cf1e89de680 (commit)
via 51fc9568c2fe7507600a97393dedba1d43f2d102 (commit)
via ee2614b25095b2c256a8f167601e68605587f93d (commit)
from 67d1d0640e2e01d1fff997372bf357250fecc90d (commit)
revisions in full, below.
commit be42c33700f1f4bd34ae8ee181509cf1e89de680
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Mar 6 21:28:47 2026 +0400
ci: run codespell directly with repo config
diff --git a/.codespellrc b/.codespellrc
index 964a27237..b68fd7fbf 100644
--- a/.codespellrc
+++ b/.codespellrc
@@ -1,4 +1,50 @@
[codespell]
-# utils/check_spelling.sh builds a deterministic list of tracked files plus
-# generated comment SQL.
ignore-words = .codespell.ignore
+skip =
+ ./deps/**,
+ ./extensions/address_standardizer/**,
+ ./extensions/*/sql/**,
+ ./extensions/*/sql_bits/*.sql,
+ ./extensions/postgis_tiger_geocoder/sql_bits/*.sql.in,
+ ./doc/html/**,
+ ./doc/po/**,
+ ./doc/postgis-out.xml,
+ ./doc/postgis-nospecial.xml,
+ ./postgis/*.sql,
+ ./raster/rt_pg/*.sql,
+ aclocal.m4,
+ configure,
+ libtool,
+ ./macros/libtool.m4,
+ spatial_ref_sys.sql,
+ ./postgis/*for_extension.sql,
+ ./postgis/*for_extension.sql.in,
+ ./raster/rt_pg/*for_extension.sql,
+ ./raster/rt_pg/*for_extension.sql.in,
+ ./raster/rt_pg/*upgrade*.sql,
+ ./raster/rt_pg/*upgrade*.sql.in,
+ ./regress/*garden_result.txt,
+ ./autom4te.cache/**,
+ ./build-aux/**,
+ .deps/**,
+ .libs/**,
+ **/.deps/**,
+ **/.libs/**,
+ ./regress/00-regress-install/**,
+ *.po,
+ *.o,
+ *.lo,
+ *.la,
+ *.a,
+ *.so,
+ *.so.*,
+ *.dll,
+ *.dylib,
+ *.pyc,
+ *.tmp,
+ *.generated,
+ *.needlessly-hardcoded,
+ *.gcda,
+ *.gcno,
+ *.gcov,
diff --git a/.github/workflows/codespell.yml b/.github/workflows/codespell.yml
index 617153b0b..a575d9bdd 100644
--- a/.github/workflows/codespell.yml
+++ b/.github/workflows/codespell.yml
@@ -22,11 +22,17 @@ jobs:
- name: 'Install codespell'
run: |
sudo apt-get update
- sudo apt-get install -y --no-install-recommends libxml2-utils docbook-xml docbook-xsl docbook-xsl-ns xsltproc
+ sudo apt-get install -y --no-install-recommends \
+ autoconf automake libtool pkg-config \
+ postgresql-server-dev-all \
+ libgeos-dev libproj-dev libxml2-dev \
+ libxml2-utils docbook-xml docbook-xsl docbook-xsl-ns xsltproc
sudo pip install codespell
- name: 'Build & Test'
run: |
codespell --version
+ ./autogen.sh
+ ./configure --without-raster --without-topology --without-sfcgal --without-json --without-protobuf
make -C doc comments
- ./utils/check_spelling.sh
+ codespell --config .codespellrc .
diff --git a/GNUmakefile.in b/GNUmakefile.in
index e468eed66..2318fc9a7 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -307,7 +307,7 @@ endif
check-spell:
ifneq (@CODESPELL@,)
- cd $(top_srcdir) && ./utils/check_spelling.sh @CODESPELL@
+ cd $(top_srcdir) && @CODESPELL@ --config .codespellrc .
else
@echo "SKIP: spell checking disabled"
endif
diff --git a/utils/check_spelling.sh b/utils/check_spelling.sh
deleted file mode 100755
index 5537675ed..000000000
--- a/utils/check_spelling.sh
+++ /dev/null
@@ -1,44 +0,0 @@
-#!/bin/sh
-set -eu
-CODESPELL=${1:-codespell}
-ROOT=$(git rev-parse --show-toplevel 2>/dev/null || pwd)
-cd "$ROOT"
-tmpfiles=$(mktemp)
-trap 'rm -f "$tmpfiles"' EXIT HUP INT TERM
-# Keep the check deterministic by starting from tracked files and excluding
-# vendor data, generated trees, and authoritative datasets that are not prose.
-git ls-files -z -- . \
- ':(exclude)deps' \
- ':(exclude)extensions/address_standardizer' \
- ':(exclude)doc/html' \
- ':(exclude)doc/po' \
- ':(exclude)doc/postgis-out.xml' \
- ':(exclude)doc/postgis-nospecial.xml' \
- ':(exclude)aclocal.m4' \
- ':(exclude)configure' \
- ':(exclude)macros/libtool.m4' \
- ':(exclude)spatial_ref_sys.sql' \
- ':(exclude)extensions/postgis/sql/spatial_ref_sys.sql' \
- ':(glob,exclude)extensions/postgis/sql/postgis--*.sql' \
- ':(glob,exclude)**/*.po' \
- > "$tmpfiles"
-# The comment SQL files are generated from the docs and shipped in release
-# artifacts, so include them when they exist.
-for generated in doc/postgis_comments.sql \
- doc/raster_comments.sql \
- doc/sfcgal_comments.sql \
- doc/tiger_geocoder_comments.sql \
- doc/topology_comments.sql
-do
- if [ -f "$generated" ]; then
- printf '%s\0' "$generated" >> "$tmpfiles"
- fi
-done
-xargs -0 "$CODESPELL" --config .codespellrc < "$tmpfiles"
commit 51fc9568c2fe7507600a97393dedba1d43f2d102
Date: Fri Mar 6 20:58:20 2026 +0400
sfcgal/tests: restore 2-component alpha shape expectations
diff --git a/sfcgal/regress/alphashape_components.sql b/sfcgal/regress/alphashape_components.sql
index 3dcfa350c..38e896ffd 100644
--- a/sfcgal/regress/alphashape_components.sql
+++ b/sfcgal/regress/alphashape_components.sql
@@ -1,6 +1,4 @@
--- Normalize POLYGON vs MULTIPOLYGON output so this SFCGAL 2.3+ regression
--- checks the stable shape result rather than a raw return-type difference.
SELECT 'CG_Optimalalphashape_2components',
- ST_AsText(ST_Normalize(ST_Multi(CG_OptimalAlphaShape('MULTIPOINT((10.1 0.2),(8.1 0.1),(6.0 0.0),(4.2 0.3),(2.5 1.0),(1.2 2.3),(0.4 4.0),(0.1 6.1),(0.3 8.2),(1.1 10.1),(2.6 11.2),(4.1 11.9),(6.2 12.1),(8.3 11.8),(10.2 11.1),(9.1 9.9),(7.6 9.8),(6.1 9.9),(4.8 9.2),(3.8 8.0),(3.6 6.2),(3.7 4.1),(4.6 2.9),(6.0 2.3),(7.8 2.2),(9.2 2.4),(40.3 0.4),(40.1 3.1),(39.8 6.2),(40.4 9.0),(40.2 12.3),(40.5 15.2),(41.9 15.6),(43.1 15.3),(54.3 15.2),(55.8 15.0),(55.6 12.1),(55.9 9.2),(55.5 6.0),(55.7 3.3),(55.4 0.5),(52.6 0.1),(49.8 -0.2),(46.9 2.8),(44.2 0.2),(42.1 0.3),(43.0 3.8),(43.3 7.1),(43.1 10.4),(52.9 10.6),(52.7 7.3),(52.8 4.1))', allow_holes => false, nb_components => 2))));
+ ST_AsText(CG_OptimalAlphaShape('MULTIPOINT((10.1 0.2),(8.1 0.1),(6.0 0.0),(4.2 0.3),(2.5 1.0),(1.2 2.3),(0.4 4.0),(0.1 6.1),(0.3 8.2),(1.1 10.1),(2.6 11.2),(4.1 11.9),(6.2 12.1),(8.3 11.8),(10.2 11.1),(9.1 9.9),(7.6 9.8),(6.1 9.9),(4.8 9.2),(3.8 8.0),(3.6 6.2),(3.7 4.1),(4.6 2.9),(6.0 2.3),(7.8 2.2),(9.2 2.4),(40.3 0.4),(40.1 3.1),(39.8 6.2),(40.4 9.0),(40.2 12.3),(40.5 15.2),(41.9 15.6),(43.1 15.3),(54.3 15.2),(55.8 15.0),(55.6 12.1),(55.9 9.2),(55.5 6.0),(55.7 3.3),(55.4 0.5),(52.6 0.1),(49.8 -0.2),(46.9 2.8),(44.2 0.2),(42.1 0.3),(43.0 3.8),(43.3 7.1),(43.1 10.4),(52.9 10.6),(52.7 7.3),(52.8 4.1))', allow_holes => false, nb_components => 2));
SELECT 'CG_OptimalAlphaShape_hole_2components',
- ST_AsText(ST_Normalize(ST_Multi(CG_OptimalAlphaShape('MULTIPOINT((0 0),(0 1),(0 2),(0 3),(0 4),(0 5),(0 6),(0 7),(0 8),(0 9),(1 10),(2 10),(3 10),(4 10),(4.5 9.5),(5 9),(5.5 8.5),(6 8),(6 7),(6 6),(5.5 5.5),(5 5),(4 5),(3 5),(2 5),(1 5),(1 4),(2 4),(3 4),(4 4),(4.5 3.5),(5 3),(6 2),(6 1),(5.5 0.5),(5 0),(4 0),(3 0),(2 0),(1 0),(0.5 0),(0.5 1),(0.5 2),(0.5 3),(0.5 4),(0.5 5),(0.5 6),(0.5 7),(0.5 8),(0.5 9),(0.5 10),(1 9.5),(2 9.5),(3 9.5),(4 9.5),(4.5 9),(5 8.5),(5.5 8),(5.5 7),(5.5 6),(5.5 6.5),(5 5.5),(4 5.5),(3 5.5),(2 5.5),(1 5.5),(1.5 4.5),(2.5 4.5),(3.5 4.5),(4 4.5),(4.5 4),(5 3.5),(5.5 3),(5.5 2),(5.5 1),(5 0.5),(4 0.5),(3 0.5),(2 0.5),(1 0.5),(12 0),(12 1),(12 2),(12 3),(12 4),(12 5),(12 6),(12 7),(12 8),(12 9),(12 10),(13 10),(14 10),(15 10),(16 10),(16.5 9.5),(17 9),(17.5 8.5),(18 8),(18 7),(18 6),(17.5 5.5),(17 5),(16 5),(15 5),(14 5),(13 5),(12.5 0),(12.5 1),(12.5 2),(12.5 3),(12.5 4),(12.5 5),(12.5 6),(12.5 7),(12.5 8),(12.5 9),(12.5 10),(13 9.5),(14 9.5),(15 9.5)
,(16 9.5),(16.5 9),(17 8.5),(17.5 8),(17.5 7),(17.5 6),(17.5 6.5),(17 5.5),(16 5.5),(15 5.5),(14 5.5),(13 5.5),(13 1),(13 2),(13 3),(13 4),(17.5 7.4),(18 7.3),(5.1 2.5),(5.8 2.5),(0.03 9.82),(0.23 10))', allow_holes => true, nb_components => 2))));
+ ST_AsText(CG_OptimalAlphaShape('MULTIPOINT((0 0),(0 1),(0 2),(0 3),(0 4),(0 5),(0 6),(0 7),(0 8),(0 9),(1 10),(2 10),(3 10),(4 10),(4.5 9.5),(5 9),(5.5 8.5),(6 8),(6 7),(6 6),(5.5 5.5),(5 5),(4 5),(3 5),(2 5),(1 5),(1 4),(2 4),(3 4),(4 4),(4.5 3.5),(5 3),(6 2),(6 1),(5.5 0.5),(5 0),(4 0),(3 0),(2 0),(1 0),(0.5 0),(0.5 1),(0.5 2),(0.5 3),(0.5 4),(0.5 5),(0.5 6),(0.5 7),(0.5 8),(0.5 9),(0.5 10),(1 9.5),(2 9.5),(3 9.5),(4 9.5),(4.5 9),(5 8.5),(5.5 8),(5.5 7),(5.5 6),(5.5 6.5),(5 5.5),(4 5.5),(3 5.5),(2 5.5),(1 5.5),(1.5 4.5),(2.5 4.5),(3.5 4.5),(4 4.5),(4.5 4),(5 3.5),(5.5 3),(5.5 2),(5.5 1),(5 0.5),(4 0.5),(3 0.5),(2 0.5),(1 0.5),(12 0),(12 1),(12 2),(12 3),(12 4),(12 5),(12 6),(12 7),(12 8),(12 9),(12 10),(13 10),(14 10),(15 10),(16 10),(16.5 9.5),(17 9),(17.5 8.5),(18 8),(18 7),(18 6),(17.5 5.5),(17 5),(16 5),(15 5),(14 5),(13 5),(12.5 0),(12.5 1),(12.5 2),(12.5 3),(12.5 4),(12.5 5),(12.5 6),(12.5 7),(12.5 8),(12.5 9),(12.5 10),(13 9.5),(14 9.5),(15 9.5),(16 9.5),(16.5 9),(17
8.5),(17.5 8),(17.5 7),(17.5 6),(17.5 6.5),(17 5.5),(16 5.5),(15 5.5),(14 5.5),(13 5.5),(13 1),(13 2),(13 3),(13 4),(17.5 7.4),(18 7.3),(5.1 2.5),(5.8 2.5),(0.03 9.82),(0.23 10))', allow_holes => true, nb_components => 2));
diff --git a/sfcgal/regress/alphashape_components_expected b/sfcgal/regress/alphashape_components_expected
index 00efc058f..a30a4ad59 100644
--- a/sfcgal/regress/alphashape_components_expected
+++ b/sfcgal/regress/alphashape_components_expected
@@ -1,2 +1,2 @@
-CG_Optimalalphashape_2components|MULTIPOLYGON(((39.8 6.2,40.4 9,40.2 12.3,40.5 15.2,41.9 15.6,43.1 15.3,43.1 10.4,43.3 7.1,46.9 2.8,52.8 4.1,52.7 7.3,52.9 10.6,54.3 15.2,55.8 15,55.6 12.1,55.9 9.2,55.5 6,55.7 3.3,55.4 0.5,52.6 0.1,49.8 -0.2,44.2 0.2,42.1 0.3,40.3 0.4,40.1 3.1,39.8 6.2)),((0.1 6.1,0.3 8.2,1.1 10.1,2.6 11.2,4.1 11.9,6.2 12.1,8.3 11.8,10.2 11.1,9.1 9.9,7.6 9.8,3.6 6.2,6 2.3,7.8 2.2,9.2 2.4,10.1 0.2,8.1 0.1,6 0,4.2 0.3,2.5 1,1.2 2.3,0.4 4,0.1 6.1)))
-CG_OptimalAlphaShape_hole_2components|MULTIPOLYGON(((0 0,0 1,0 2,0 3,0 4,0 5,0 6,0 7,0 8,0 9,0.03 9.82,0.23 10,0.5 10,1 10,2 10,3 10,4 10,4.5 9.5,5 9,5.5 8.5,6 8,6 7,6 6,5.5 5.5,5 5,4 4.5,4.5 4,5 3.5,5.5 3,5.8 2.5,6 2,6 1,5.5 0.5,5 0,4 0,3 0,2 0,1 0,0.5 0,0 0),(0.5 6,1 5.5,2 5.5,3 5.5,4 5.5,5 5.5,5.5 6,5.5 6.5,5.5 7,5.5 8,5 8.5,4.5 9,4 9.5,3 9.5,2 9.5,1 9.5,0.5 9,0.5 8,0.5 7,0.5 6),(0.5 1,1 0.5,2 0.5,3 0.5,4 0.5,5 0.5,5.5 1,5.5 2,5.1 2.5,5 3,4.5 3.5,4 4,3 4,2 4,1 4,0.5 3,0.5 2,0.5 1)),((12 0,12 1,12 2,12 3,12 4,12 5,12 6,12 7,12 8,12 9,12 10,12.5 10,13 10,14 10,15 10,16 10,16.5 9.5,17 9,17.5 8.5,18 8,18 7.3,18 7,18 6,17.5 5.5,17 5,16 5,15 5,14 5,13 5,13 4,13 3,13 2,13 1,12.5 0,12 0),(12.5 6,13 5.5,14 5.5,15 5.5,16 5.5,17 5.5,17.5 6,17.5 6.5,17.5 7,17.5 7.4,17.5 8,17 8.5,16.5 9,16 9.5,15 9.5,14 9.5,13 9.5,12.5 9,12.5 8,12.5 7,12.5 6)))
+CG_Optimalalphashape_2components|MULTIPOLYGON(((8.3 11.8,6.2 12.1,4.1 11.9,2.6 11.2,1.1 10.1,0.3 8.2,0.1 6.1,0.4 4,1.2 2.3,2.5 1,4.2 0.3,6 0,8.1 0.1,10.1 0.2,9.2 2.4,7.8 2.2,6 2.3,3.6 6.2,7.6 9.8,9.1 9.9,10.2 11.1,8.3 11.8)),((55.6 12.1,55.8 15,54.3 15.2,52.9 10.6,52.7 7.3,52.8 4.1,46.9 2.8,43.3 7.1,43.1 10.4,43.1 15.3,41.9 15.6,40.5 15.2,40.2 12.3,40.4 9,39.8 6.2,40.1 3.1,40.3 0.4,42.1 0.3,44.2 0.2,49.8 -0.2,52.6 0.1,55.4 0.5,55.7 3.3,55.5 6,55.9 9.2,55.6 12.1)))
+CG_OptimalAlphaShape_hole_2components|MULTIPOLYGON(((5.5 8.5,5 9,4.5 9.5,4 10,3 10,2 10,1 10,0.5 10,0.23 10,0.03 9.82,0 9,0 8,0 7,0 6,0 5,0 4,0 3,0 2,0 1,0 0,0.5 0,1 0,2 0,3 0,4 0,5 0,5.5 0.5,6 1,6 2,5.8 2.5,5.5 3,5 3.5,4.5 4,4 4.5,5 5,5.5 5.5,6 6,6 7,6 8,5.5 8.5),(0.5 2,0.5 3,1 4,2 4,3 4,4 4,4.5 3.5,5 3,5.1 2.5,5.5 2,5.5 1,5 0.5,4 0.5,3 0.5,2 0.5,1 0.5,0.5 1,0.5 2),(0.5 7,0.5 8,0.5 9,1 9.5,2 9.5,3 9.5,4 9.5,4.5 9,5 8.5,5.5 8,5.5 7,5.5 6.5,5.5 6,5 5.5,4 5.5,3 5.5,2 5.5,1 5.5,0.5 6,0.5 7)),((17.5 8.5,17 9,16.5 9.5,16 10,15 10,14 10,13 10,12.5 10,12 10,12 9,12 8,12 7,12 6,12 5,12 4,12 3,12 2,12 1,12 0,12.5 0,13 1,13 2,13 3,13 4,13 5,14 5,15 5,16 5,17 5,17.5 5.5,18 6,18 7,18 7.3,18 8,17.5 8.5),(12.5 7,12.5 8,12.5 9,13 9.5,14 9.5,15 9.5,16 9.5,16.5 9,17 8.5,17.5 8,17.5 7.4,17.5 7,17.5 6.5,17.5 6,17 5.5,16 5.5,15 5.5,14 5.5,13 5.5,12.5 6,12.5 7)))
commit ee2614b25095b2c256a8f167601e68605587f93d
Date: Fri Mar 6 20:41:35 2026 +0400
doc/uk: fix localized XML markup
diff --git a/doc/po/uk/postgis-manual.po b/doc/po/uk/postgis-manual.po
index 62e629932..9cb094ad0 100644
--- a/doc/po/uk/postgis-manual.po
+++ b/doc/po/uk/postgis-manual.po
@@ -4750,7 +4750,7 @@ msgid ""
"topogeometries created before the upgrade. This function fixes this "
"corruption in affected tables."
msgstr ""
-"При оновленні топології PostGIS <3.6.0 до версії >3.6.0+ було змінено "
+"При оновленні топології PostGIS <3.6.0 до версії >3.6.0+ було змінено "
"визначення стовпця topogeometry. Це спричинило пошкодження топогеометрій, "
"створених до оновлення. Ця функція виправляє це пошкодження в уражених "
"таблицях."
@@ -8653,7 +8653,7 @@ msgid ""
msgstr ""
"Для створення зображень, що використовуються в документації, необхідна "
"програма GraphicsMagick (<filename>gm convert</filename>). GraphicsMagick "
-"доступна за адресою <link xlink:href=«http://www.graphicsmagick.org/»> "
+"доступна за адресою <link xlink:href=\"http://www.graphicsmagick.org/\"> "
"http://www.graphicsmagick.org/ </link> ."
#. Tag: title
@@ -44475,8 +44475,8 @@ msgid ""
"postgresql.org/docs/current/rowtypes.html\">composite data type</link> "
"containing the fields:"
msgstr ""
-"<varname>geometry_dump</varname> — це <link xlink:href=«https://www."
-"postgresql.org/docs/current/rowtypes.html»>складний тип даних</link>, що "
+"<varname>geometry_dump</varname> — це <link xlink:href=\"https://www."
+"postgresql.org/docs/current/rowtypes.html\">складний тип даних</link>, що "
"містить такі поля:"
#. Tag: para
Summary of changes:
.codespellrc | 50 +++++++++++++++++++++++++--
.github/workflows/codespell.yml | 10 ++++--
GNUmakefile.in | 2 +-
doc/po/uk/postgis-manual.po | 8 ++---
sfcgal/regress/alphashape_components.sql | 6 ++--
sfcgal/regress/alphashape_components_expected | 4 +--
utils/check_spelling.sh | 44 -----------------------
7 files changed, 65 insertions(+), 59 deletions(-)
delete mode 100755 utils/check_spelling.sh
hooks/post-receive
