[SCM] PostGIS branch stable-3.6 updated. 3.6.2-4-gd3171abe3
Mon Mar 16 13:21:01 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  d3171abe3b30c898bd15e37b072fb34c3b6cc675 (commit)
      from  6d032d7f203aca9e77badfcc26e9c84968cd3655 (commit)
revisions in full, below.
commit d3171abe3b30c898bd15e37b072fb34c3b6cc675
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Mar 16 13:20:54 2026 -0700
    Build on latest Pg19 master
diff --git a/postgis/flatgeobuf.c b/postgis/flatgeobuf.c
index eb29f8920..ae3f8fb53 100644
--- a/postgis/flatgeobuf.c
+++ b/postgis/flatgeobuf.c
@@ -313,12 +313,12 @@ static void decode_properties(struct flatgeobuf_decode_ctx *ctx, Datum *values,
 			break;
 		case flatgeobuf_column_type_byte: {
-			int8_t value;
-			if (offset + sizeof(int8_t) > size)
+			char value;
+			if (offset + sizeof(char) > size)
 				elog(ERROR, "flatgeobuf: decode_properties: Invalid size for byte value");
-			memcpy(&value, data + offset, sizeof(int8_t));
-			values[ci] = Int8GetDatum(value);
-			offset += sizeof(int8_t);
+			memcpy(&value, data + offset, sizeof(char));
+			values[ci] = CharGetDatum(value);
+			offset += sizeof(char);
 			break;
 		case flatgeobuf_column_type_ubyte: {
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index c1cac17c3..e08c65975 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -6544,6 +6544,7 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS)
 		case ET_FIRST:
 			i = 0;
 			/* fall through */
+			__attribute__((fallthrough));
 		case ET_SECOND:
 			if (i > 1)
 				i = 1;
Summary of changes:
 postgis/flatgeobuf.c           | 10 +++++-----
 raster/rt_pg/rtpg_mapalgebra.c |  1 +
 2 files changed, 6 insertions(+), 5 deletions(-)
hooks/post-receive
