[SCM] PostGIS branch stable-3.6 updated. 3.6.2-9-g7a4724254
Wed Mar 18 14:39:18 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  7a47242545554391f0d87e788568a97c2ff5513d (commit)
      from  5ff3eaca52ba8db6d45e46c3b40c91b0b9c49248 (commit)
revisions in full, below.
commit 7a47242545554391f0d87e788568a97c2ff5513d
Author: Ariel Mashraki <ariel at mashraki.co.il>
Date:   Wed Mar 18 13:03:43 2026 +0200
    Use read-only SPI execution for user-supplied expressions in ST_MapAlgebraExpr
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index e08c65975..6e4b9da38 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -4911,7 +4911,7 @@ Datum RASTER_mapAlgebraExpr(PG_FUNCTION_ARGS)
         /* Execute the expression into newval */
-        ret = SPI_execute(initexpr, FALSE, 0);
+        ret = SPI_execute(initexpr, TRUE, 0);
         if (ret != SPI_OK_SELECT || SPI_tuptable == NULL || SPI_processed != 1) {
@@ -5141,7 +5141,7 @@ Datum RASTER_mapAlgebraExpr(PG_FUNCTION_ARGS)
-                        ret = SPI_execute_plan(spi_plan, values, nulls, FALSE, 0);
+                        ret = SPI_execute_plan(spi_plan, values, nulls, TRUE, 0);
                             if (SPI_tuptable)
diff --git a/raster/test/regress/rt_mapalgebra_expr.sql b/raster/test/regress/rt_mapalgebra_expr.sql
index 78f90bb21..e1dd3a5a7 100644
--- a/raster/test/regress/rt_mapalgebra_expr.sql
+++ b/raster/test/regress/rt_mapalgebra_expr.sql
@@ -160,6 +160,39 @@ SELECT 'T12',
     '[rast.x]'
   ) AS rast;
+-- Test read-only expression (prepared plan path via [rast.val])
+CREATE TABLE _rast_dml_guard (id int);
+SELECT 'T13', ST_MapAlgebraExpr(
+    ST_AddBand(ST_MakeEmptyRaster(1, 1, 0, 0, 1, 1, 0, 0, 0), '8BUI'::text, 1, 0),
+    1, '8BUI'::text,
+    '[rast.val])::double precision; INSERT INTO _rast_dml_guard VALUES(1); SELECT (1'::text,
+    NULL::double precision
+) IS NULL;
+DROP TABLE _rast_dml_guard;
+-- Test read-only expression blocks COPY TO PROGRAM (constant expression path)
+SELECT 'T14', ST_MapAlgebraExpr(
+    1, '8BUI'::text,
+    '1)::double precision; COPY (SELECT 1) TO PROGRAM ''touch /tmp/pwned''--'::text,
+) IS NULL;
+-- Parameterized queries do not prevent injection; expression is concatenated inside SPI_execute.
+CREATE TABLE _rast_drop_guard (id int);
+PREPARE _rast_safe_query(raster, int, text, text, float8) AS
+    SELECT ST_MapAlgebraExpr($1, $2, $3, $4, $5);
+EXECUTE _rast_safe_query(
+    ST_AddBand(ST_MakeEmptyRaster(1,1,0,0,1,1,0,0,0), '8BUI'::text, 1, 0),
+    1, '8BUI',
+    '1)::double precision FROM generate_series(1,1); DROP TABLE _rast_drop_guard; SELECT (1',
+    NULL
+DEALLOCATE _rast_safe_query;
+-- Table must still exist after the blocked DROP
+SELECT 'T15', COUNT(*) = 0 FROM _rast_drop_guard;
+DROP TABLE _rast_drop_guard;
 DROP FUNCTION ST_TestRaster(ulx float8, uly float8, val float8);
 DROP FUNCTION raster_plus_twenty(pixel FLOAT, VARIADIC args TEXT[]);
 DROP FUNCTION raster_plus_arg1(pixel FLOAT, VARIADIC args TEXT[]);
diff --git a/raster/test/regress/rt_mapalgebra_expr_expected b/raster/test/regress/rt_mapalgebra_expr_expected
index dccd7fc46..e6974dfbc 100644
--- a/raster/test/regress/rt_mapalgebra_expr_expected
+++ b/raster/test/regress/rt_mapalgebra_expr_expected
@@ -22,6 +22,10 @@ ERROR:  rtpg_nmapalgebraexpr_callback: rast2 argument specified in single-raster
 T11.1|10|2
 T11.2|10|2
 T12|t|t|t|t
+ERROR:  INSERT is not allowed in a non-volatile function
+ERROR:  COPY is not allowed in a non-volatile function
+ERROR:  DROP TABLE is not allowed in a non-volatile function
+T15|t
 0|1|INTERSECTION|0.000|0.000|2|2|1.000|1.000|0.000|0.000|0|1|32BF|0.000|1.000|1.000
 0|2|INTERSECTION|1.000|-1.000|1|2|1.000|1.000|0.000|0.000|0|1|32BF|0.000|1.000|1.000
 0|3|INTERSECTION|1.000|1.000|1|1|1.000|1.000|0.000|0.000|0|1|32BF|0.000|1.000|1.000
Summary of changes:
 raster/rt_pg/rtpg_mapalgebra.c                  |  4 +--
 raster/test/regress/rt_mapalgebra_expr.sql      | 33 +++++++++++++++++++++++++
 raster/test/regress/rt_mapalgebra_expr_expected |  4 +++
 3 files changed, 39 insertions(+), 2 deletions(-)
hooks/post-receive
