[SCM] PostGIS branch master updated. 3.6.0rc2-401-ga197e6b1f
git at osgeo.org
git at osgeo.org
Fri Mar 20 14:54:37 PDT 2026
the project "PostGIS".
via a197e6b1f2bc7ff75fb1d34b806d4a80a4060d77 (commit)
from c4426d4baaaed9a3e8ba6fbab2a05ba962dccdea (commit)
revisions in full, below.
commit a197e6b1f2bc7ff75fb1d34b806d4a80a4060d77
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Mar 20 14:54:06 2026 -0700
Use Pg composite_to_json() function in 19+ (Paul Ramsey)
References #6058
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index 5e0a6f589..293d68ef0 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -69,8 +69,12 @@ static void composite_to_geojson(FunctionCallInfo fcinfo,
bool use_line_feeds,
Oid geom_oid,
Oid geog_oid);
+#if POSTGIS_PGSQL_VERSION < 190
static void composite_to_json(Datum composite, StringInfo result,
bool use_line_feeds);
+#endif
static void datum_to_json(Datum val, bool is_null, StringInfo result,
JsonTypeCategory tcategory, Oid outfuncoid,
bool key_scalar);
@@ -570,6 +574,7 @@ array_to_json_internal(Datum array, StringInfo result, bool use_line_feeds)
* Turn a composite / record into JSON.
static void
composite_to_json(Datum composite, StringInfo result, bool use_line_feeds)
@@ -635,6 +640,7 @@ composite_to_json(Datum composite, StringInfo result, bool use_line_feeds)
appendStringInfoChar(result, '}');
ReleaseTupleDesc(tupdesc);
+#endif
* Process a single dimension of an array.
Summary of changes:
postgis/lwgeom_out_geojson.c | 6 ++++++
1 file changed, 6 insertions(+)
hooks/post-receive
