[SCM] PostGIS branch stable-3.6 updated. 3.6.2-10-g4728189d6
Fri Mar 20 14:55:28 PDT 2026
the project "PostGIS".
The branch, stable-3.6 has been updated
       via  4728189d613fa7f0b7d8edd8534d02c3a82683bd (commit)
      from  7a47242545554391f0d87e788568a97c2ff5513d (commit)
revisions in full, below.
commit 4728189d613fa7f0b7d8edd8534d02c3a82683bd
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Mar 20 14:54:56 2026 -0700
    Use Pg composite_to_json() function in 19+
    References #6058
diff --git a/NEWS b/NEWS
index 6c776454a..e8519f017 100644
--- a/NEWS
+++ b/NEWS
@@ -19,6 +19,8 @@ topogeometry corruption:
          Reported by Sven Klemm (Tiger Data), Allistair Ishmael Hakim (allistair.sh)
          and Daniel Bakker
 - GH-850 Use quote_identifier to build tables in pgis_tablefromflatgeobuf (Ariel Mashraki)
+- #6058, Use Pg composite_to_json() function in 19+ (Paul Ramsey)
 PostGIS 3.6.2
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index 0338cdf18..3e74708bd 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -62,8 +62,12 @@ static void composite_to_geojson(FunctionCallInfo fcinfo,
 				 bool use_line_feeds,
 				 Oid geom_oid,
 				 Oid geog_oid);
+#if POSTGIS_PGSQL_VERSION < 190
 static void composite_to_json(Datum composite, StringInfo result,
 							  bool use_line_feeds);
+#endif
 static void datum_to_json(Datum val, bool is_null, StringInfo result,
 						  JsonTypeCategory tcategory, Oid outfuncoid,
 						  bool key_scalar);
@@ -533,6 +537,7 @@ array_to_json_internal(Datum array, StringInfo result, bool use_line_feeds)
  * Turn a composite / record into JSON.
 static void
 composite_to_json(Datum composite, StringInfo result, bool use_line_feeds)
@@ -598,6 +603,7 @@ composite_to_json(Datum composite, StringInfo result, bool use_line_feeds)
 	appendStringInfoChar(result, '}');
 	ReleaseTupleDesc(tupdesc);
+#endif
  * Process a single dimension of an array.
Summary of changes:
 NEWS                         | 2 ++
 postgis/lwgeom_out_geojson.c | 6 ++++++
 2 files changed, 8 insertions(+)
hooks/post-receive
