[SCM] PostGIS branch master updated. 3.6.0rc2-402-gd63430387
git at osgeo.org
git at osgeo.org
Fri Mar 20 14:57:17 PDT 2026
the project "PostGIS".
via d63430387663f34c6edccac1bff47a5cf484d4c8 (commit)
from a197e6b1f2bc7ff75fb1d34b806d4a80a4060d77 (commit)
revisions in full, below.
commit d63430387663f34c6edccac1bff47a5cf484d4c8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Mar 20 14:56:33 2026 -0700
Replace func() with func(void) for zero-parameter
functions. Add in explicit fallthroughs to case statements,
all per recent clang code warnings.
diff --git a/deps/uthash/include/uthash.h b/deps/uthash/include/uthash.h
index af0546472..7ce3f1982 100644
--- a/deps/uthash/include/uthash.h
+++ b/deps/uthash/include/uthash.h
@@ -114,6 +114,22 @@ typedef unsigned char uint8_t;
#define HASH_NONFATAL_OOM 0
#endif
+#ifndef FALLTHROUGH
+ #if defined(__cplusplus) && __cplusplus >= 201703L
+ #define FALLTHROUGH [[fallthrough]]
+ #elif defined(__STDC_VERSION__) && __STDC_VERSION__ >= 202311L
+ #elif defined(__clang__)
+ #define FALLTHROUGH __attribute__((fallthrough))
+ #elif defined(__GNUC__) && __GNUC__ >= 7
+ #elif defined(_MSC_VER) && _MSC_VER >= 1910
+ #else
+ #define FALLTHROUGH ((void)0)
+ #endif
+#endif
#if HASH_NONFATAL_OOM
/* malloc failures can be recovered from */
@@ -681,16 +697,16 @@ do {
hashv += (unsigned)(keylen); \
switch ( _hj_k ) { \
- case 11: hashv += ( (unsigned)_hj_key[10] << 24 ); /* FALLTHROUGH */ \
- case 10: hashv += ( (unsigned)_hj_key[9] << 16 ); /* FALLTHROUGH */ \
- case 9: hashv += ( (unsigned)_hj_key[8] << 8 ); /* FALLTHROUGH */ \
- case 8: _hj_j += ( (unsigned)_hj_key[7] << 24 ); /* FALLTHROUGH */ \
- case 7: _hj_j += ( (unsigned)_hj_key[6] << 16 ); /* FALLTHROUGH */ \
- case 6: _hj_j += ( (unsigned)_hj_key[5] << 8 ); /* FALLTHROUGH */ \
- case 5: _hj_j += _hj_key[4]; /* FALLTHROUGH */ \
- case 4: _hj_i += ( (unsigned)_hj_key[3] << 24 ); /* FALLTHROUGH */ \
- case 3: _hj_i += ( (unsigned)_hj_key[2] << 16 ); /* FALLTHROUGH */ \
- case 2: _hj_i += ( (unsigned)_hj_key[1] << 8 ); /* FALLTHROUGH */ \
+ case 11: hashv += ( (unsigned)_hj_key[10] << 24 ); FALLTHROUGH; \
+ case 10: hashv += ( (unsigned)_hj_key[9] << 16 ); FALLTHROUGH; \
+ case 9: hashv += ( (unsigned)_hj_key[8] << 8 ); FALLTHROUGH; \
+ case 8: _hj_j += ( (unsigned)_hj_key[7] << 24 ); FALLTHROUGH; \
+ case 7: _hj_j += ( (unsigned)_hj_key[6] << 16 ); FALLTHROUGH; \
+ case 6: _hj_j += ( (unsigned)_hj_key[5] << 8 ); FALLTHROUGH; \
+ case 5: _hj_j += _hj_key[4]; FALLTHROUGH; \
+ case 4: _hj_i += ( (unsigned)_hj_key[3] << 24 ); FALLTHROUGH; \
+ case 3: _hj_i += ( (unsigned)_hj_key[2] << 16 ); FALLTHROUGH; \
+ case 2: _hj_i += ( (unsigned)_hj_key[1] << 8 ); FALLTHROUGH; \
case 1: _hj_i += _hj_key[0]; \
HASH_JEN_MIX(_hj_i, _hj_j, hashv); \
@@ -1224,4 +1240,4 @@ typedef struct UT_hash_handle {
unsigned hashv; /* result of hash-fcn(key) */
} UT_hash_handle;
-#endif /* UTHASH_H */
\ No newline at end of file
+#endif /* UTHASH_H */
diff --git a/deps/wagyu/lwgeom_wagyu.cpp b/deps/wagyu/lwgeom_wagyu.cpp
index 0afbd144b..fc6e359c6 100644
--- a/deps/wagyu/lwgeom_wagyu.cpp
+++ b/deps/wagyu/lwgeom_wagyu.cpp
@@ -250,7 +250,7 @@ lwgeom_wagyu_clip_by_box(const LWGEOM *geom, const GBOX *bbox)
const char *
-libwagyu_version()
+libwagyu_version(void)
static char str[50] = {0};
snprintf(
@@ -260,13 +260,13 @@ libwagyu_version()
void
-lwgeom_wagyu_interruptRequest()
+lwgeom_wagyu_interruptRequest(void)
mapbox::geometry::wagyu::interrupt_request();
void
-lwgeom_wagyu_interruptReset()
+lwgeom_wagyu_interruptReset(void)
mapbox::geometry::wagyu::interrupt_reset();
diff --git a/deps/wagyu/lwgeom_wagyu.h b/deps/wagyu/lwgeom_wagyu.h
index 9e557f679..52963e23a 100644
--- a/deps/wagyu/lwgeom_wagyu.h
+++ b/deps/wagyu/lwgeom_wagyu.h
@@ -52,17 +52,17 @@ LWGEOM *lwgeom_wagyu_clip_by_box(const LWGEOM *geom, const GBOX *bbox);
* Returns a pointer to the static string representing the Wagyu release
* being used (Should not be freed)
-const char *libwagyu_version();
+const char *libwagyu_version(void);
* Requests wagyu to stop processing. In this case it will return NULL
-void lwgeom_wagyu_interruptRequest();
+void lwgeom_wagyu_interruptRequest(void);
* Cancels request to stop processing.
-void lwgeom_wagyu_interruptReset();
+void lwgeom_wagyu_interruptReset(void);
#ifdef __cplusplus
diff --git a/libpgcommon/lwgeom_transform.c b/libpgcommon/lwgeom_transform.c
index 61975dc0f..53fe0a5d3 100644
--- a/libpgcommon/lwgeom_transform.c
+++ b/libpgcommon/lwgeom_transform.c
@@ -96,7 +96,7 @@ PROJSRSDestroyPortalCache(void *portalCache)
* If it doesn't exist, make a new blank one and return it.
PROJSRSCache *
-GetPROJSRSCache()
+GetPROJSRSCache(void)
PROJSRSCache* cache = PROJ_CACHE;
if (!cache)
diff --git a/libpgcommon/lwgeom_transform.h b/libpgcommon/lwgeom_transform.h
index be0ae1978..c42d21530 100644
--- a/libpgcommon/lwgeom_transform.h
+++ b/libpgcommon/lwgeom_transform.h
@@ -57,7 +57,7 @@ typedef struct srs_precision
} srs_precision;
/* Prototypes */
-PROJSRSCache* GetPROJSRSCache();
+PROJSRSCache* GetPROJSRSCache(void);
int lwproj_lookup(int32_t srid_from, int32_t srid_to, LWPROJ **pj);
int lwproj_is_latlong(const LWPROJ *pj);
int spheroid_init_from_srid(int32_t srid, SPHEROID *s);
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 0cfa08da7..7806f6ccb 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2744,7 +2744,8 @@ Datum LWGEOM_angle(PG_FUNCTION_ARGS)
default: /*always executed*/
for (j = 0; j <= i; j++)
PG_FREE_IF_COPY(seri_geoms[j], j);
- /*FALLTHROUGH*/
+ pg_fallthrough; /* FALLTHROUGH */
case 1:
lwpgerror("Empty geometry");
PG_RETURN_NULL();
diff --git a/postgis/lwgeom_geos_prepared.c b/postgis/lwgeom_geos_prepared.c
index 2f971a64c..79dafad7e 100644
--- a/postgis/lwgeom_geos_prepared.c
+++ b/postgis/lwgeom_geos_prepared.c
@@ -336,7 +336,7 @@ PrepGeomCacheCleaner(GeomCache *cache)
static GeomCache*
-PrepGeomCacheAllocator()
+PrepGeomCacheAllocator(void)
PrepGeomCache* prepcache = palloc(sizeof(PrepGeomCache));
memset(prepcache, 0, sizeof(PrepGeomCache));
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index 4a23fe3fc..16a32fc54 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -409,7 +409,7 @@ srs_tuple_from_entry(const struct srs_entry* entry, TupleDesc tuple_desc)
static struct srs_data *
-srs_state_init()
+srs_state_init(void)
struct srs_data *state = palloc0(sizeof(*state));
state->capacity = 8192;
diff --git a/postgis/postgis_module.c b/postgis/postgis_module.c
index 8c420ac53..8d79254ab 100644
--- a/postgis/postgis_module.c
+++ b/postgis/postgis_module.c
@@ -53,7 +53,7 @@ PG_MODULE_MAGIC;
#endif
-static void interrupt_geos_callback()
+static void interrupt_geos_callback(void)
#ifdef WIN32
if (UNBLOCKED_SIGNAL_QUEUE())
@@ -72,7 +72,7 @@ static void interrupt_geos_callback()
-static void interrupt_liblwgeom_callback()
+static void interrupt_liblwgeom_callback(void)
#ifdef WIN32
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index 8a0e0516d..0e355ebe3 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -6567,8 +6567,8 @@ Datum RASTER_mapAlgebra2(PG_FUNCTION_ARGS)
switch (extenttype) {
case ET_FIRST:
i = 0;
- /* fall through */
- __attribute__((fallthrough));
case ET_SECOND:
if (i > 1)
i = 1;
Summary of changes:
deps/uthash/include/uthash.h | 38 +++++++++++++++++++++++++++-----------
deps/wagyu/lwgeom_wagyu.cpp | 6 +++---
deps/wagyu/lwgeom_wagyu.h | 6 +++---
libpgcommon/lwgeom_transform.c | 2 +-
libpgcommon/lwgeom_transform.h | 2 +-
postgis/lwgeom_functions_basic.c | 3 ++-
postgis/lwgeom_geos_prepared.c | 2 +-
postgis/lwgeom_transform.c | 2 +-
postgis/postgis_module.c | 4 ++--
raster/rt_pg/rtpg_mapalgebra.c | 4 ++--
10 files changed, 43 insertions(+), 26 deletions(-)
hooks/post-receive
