[SCM] PostGIS branch master updated. 3.6.0rc2-407-gbebe97d1a
git at osgeo.org
git at osgeo.org
Mon Mar 23 11:08:02 PDT 2026
the project "PostGIS".
via bebe97d1abb3c2208f29533d40fe78a08c0cf0b6 (commit)
via 08f383f7cfe6da372592a096876c1cb7c2fefc44 (commit)
via 913caaedf89827cbc61fc9b3b0ee283a2fdff866 (commit)
via acf474815d0c0bcf442ee5784050dcae5da68aef (commit)
from c52110c83f015716df310dd94d48ff76abdd7620 (commit)
revisions in full, below.
commit bebe97d1abb3c2208f29533d40fe78a08c0cf0b6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Mar 23 10:59:53 2026 -0700
remove K&R style handling of zero-arg functions
diff --git a/raster/rt_pg/rtpg_pixel.c b/raster/rt_pg/rtpg_pixel.c
index 38f6ccb34..9aa65ebea 100644
--- a/raster/rt_pg/rtpg_pixel.c
+++ b/raster/rt_pg/rtpg_pixel.c
@@ -1292,7 +1292,7 @@ struct rtpg_setvaluesgv_geomval_t {
rt_raster mask;
-static rtpg_setvaluesgv_arg rtpg_setvaluesgv_arg_init() {
+static rtpg_setvaluesgv_arg rtpg_setvaluesgv_arg_init(void) {
rtpg_setvaluesgv_arg arg = palloc(sizeof(struct rtpg_setvaluesgv_arg_t));
if (arg == NULL) {
elog(ERROR, "rtpg_setvaluesgv_arg_init: Could not allocate memory for function arguments");
commit 08f383f7cfe6da372592a096876c1cb7c2fefc44
Date: Mon Mar 23 10:53:04 2026 -0700
diff --git a/raster/rt_pg/rtpg_statistics.c b/raster/rt_pg/rtpg_statistics.c
index bffdf0e6b..03219f74e 100644
--- a/raster/rt_pg/rtpg_statistics.c
+++ b/raster/rt_pg/rtpg_statistics.c
@@ -513,7 +513,7 @@ rtpg_summarystats_arg_destroy(rtpg_summarystats_arg arg) {
static rtpg_summarystats_arg
-rtpg_summarystats_arg_init() {
+rtpg_summarystats_arg_init(void) {
rtpg_summarystats_arg arg = NULL;
arg = palloc(sizeof(struct rtpg_summarystats_arg_t));
commit 913caaedf89827cbc61fc9b3b0ee283a2fdff866
Date: Mon Mar 23 10:50:28 2026 -0700
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index 6d8ea2faa..8cf3d8c11 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -314,7 +314,7 @@ static void test_ptarray_isccw(void)
lwpoly_free(poly);
-static void test_ptarray_signed_area()
+static void test_ptarray_signed_area(void)
LWLINE *line;
double area;
@@ -340,7 +340,7 @@ static void test_ptarray_signed_area()
-static void test_ptarray_contains_point()
+static void test_ptarray_contains_point(void)
/* int ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt, int *winding_number) */
@@ -440,7 +440,7 @@ static void test_ptarray_contains_point()
lwline_free(lwline);
-static void test_ptarrayarc_contains_point()
+static void test_ptarrayarc_contains_point(void)
/* int ptarrayarc_contains_point(const POINTARRAY *pa, const POINT2D *pt) */
@@ -578,7 +578,7 @@ static void test_ptarrayarc_contains_point()
lwcircstring_free(lwcirc);
-static void test_ptarray_scale()
+static void test_ptarray_scale(void)
LWLINE *line;
POINTARRAY *pa;
@@ -627,7 +627,7 @@ static void test_ptarray_scale()
lwline_free(line);
-static void test_ptarray_scroll()
+static void test_ptarray_scroll(void)
LWLINE *line;
POINTARRAY *pa;
@@ -664,7 +664,7 @@ static void test_ptarray_scroll()
lwline_free(line);
-static void test_ptarray_closest_vertex_2d()
+static void test_ptarray_closest_vertex_2d(void)
LWLINE *line;
POINTARRAY *pa;
@@ -696,7 +696,7 @@ static void test_ptarray_closest_vertex_2d()
lwline_free(line);
-static void test_ptarray_closest_segment_2d()
+static void test_ptarray_closest_segment_2d(void)
LWLINE *line;
POINTARRAY *pa;
diff --git a/liblwgeom/cunit/cu_remove_irrelevant_points_for_view.c b/liblwgeom/cunit/cu_remove_irrelevant_points_for_view.c
index b3bbcbcd0..ce796b939 100644
--- a/liblwgeom/cunit/cu_remove_irrelevant_points_for_view.c
+++ b/liblwgeom/cunit/cu_remove_irrelevant_points_for_view.c
@@ -15,7 +15,6 @@
#include "lwgeom_remove_irrelevant_points_for_view.h"
-// test case for lwgeom_remove_irrelevant_points_for_view()
static void test_lwgeom_remove_irrelevant_points_for_view(void)
LWGEOM *geom;
diff --git a/liblwgeom/cunit/cu_tester.c b/liblwgeom/cunit/cu_tester.c
index 0df215893..708b8070c 100644
--- a/liblwgeom/cunit/cu_tester.c
+++ b/liblwgeom/cunit/cu_tester.c
@@ -30,12 +30,12 @@ cu_debuglogger(int level, const char *fmt, va_list ap);
/* ADD YOUR SUITE SETUP FUNCTION HERE (1 of 2) */
-extern void print_suite_setup();
-extern void algorithms_suite_setup();
-extern void boundary_suite_setup();
-extern void buildarea_suite_setup();
-extern void clean_suite_setup();
-extern void clip_by_rect_suite_setup();
+extern void print_suite_setup(void);
+extern void algorithms_suite_setup(void);
+extern void boundary_suite_setup(void);
+extern void buildarea_suite_setup(void);
+extern void clean_suite_setup(void);
+extern void clip_by_rect_suite_setup(void);
extern void force_dims_suite_setup(void);
extern void force_sfs_suite_setup(void);
extern void geodetic_suite_setup(void);
diff --git a/liblwgeom/lwboundingcircle.c b/liblwgeom/lwboundingcircle.c
index ba6bc40d7..673b40a1f 100644
--- a/liblwgeom/lwboundingcircle.c
+++ b/liblwgeom/lwboundingcircle.c
@@ -33,7 +33,7 @@ typedef struct {
} SUPPORTING_POINTS;
static SUPPORTING_POINTS*
-supporting_points_create()
+supporting_points_create(void)
SUPPORTING_POINTS* s = lwalloc(sizeof(SUPPORTING_POINTS));
s->p1 = NULL;
@@ -214,7 +214,7 @@ calculate_mbc(const POINT2D** points, uint32_t max_n, SUPPORTING_POINTS* support
static LWBOUNDINGCIRCLE*
-lwboundingcircle_create()
+lwboundingcircle_create(void)
LWBOUNDINGCIRCLE* c = lwalloc(sizeof(LWBOUNDINGCIRCLE));
c->center = lwalloc(sizeof(POINT2D));
diff --git a/liblwgeom/lwgeom_api.c b/liblwgeom/lwgeom_api.c
index 8d5a0f0e1..99e51b0ca 100644
--- a/liblwgeom/lwgeom_api.c
+++ b/liblwgeom/lwgeom_api.c
@@ -35,7 +35,7 @@
#define str(s) #s
const char *
-lwgeom_version()
+lwgeom_version(void)
static char *ptr = NULL;
static char buf[256];
@@ -655,11 +655,11 @@ interpolate_point4d(const POINT4D *A, const POINT4D *B, POINT4D *I, double F)
int _lwgeom_interrupt_requested = 0;
void
-lwgeom_request_interrupt() {
+lwgeom_request_interrupt(void) {
_lwgeom_interrupt_requested = 1;
void
-lwgeom_cancel_interrupt() {
+lwgeom_cancel_interrupt(void) {
diff --git a/loader/cunit/cu_tester.c b/loader/cunit/cu_tester.c
index d47d5b1aa..37fd810ec 100644
--- a/loader/cunit/cu_tester.c
+++ b/loader/cunit/cu_tester.c
@@ -20,7 +20,7 @@
** Returns a CUE_SUCCESS on successful running, another
** CUnit error code on failure.
-int main()
+int main(void)
/* initialize the CUnit test registry */
index 2bfecf4d4..38f6ccb34 100644
@@ -349,7 +349,7 @@ struct rtpg_dumpvalues_arg_t {
bool **nodata;
-static rtpg_dumpvalues_arg rtpg_dumpvalues_arg_init() {
+static rtpg_dumpvalues_arg rtpg_dumpvalues_arg_init(void) {
rtpg_dumpvalues_arg arg = NULL;
arg = palloc(sizeof(struct rtpg_dumpvalues_arg_t));
diff --git a/raster/test/cunit/cu_band_basics.c b/raster/test/cunit/cu_band_basics.c
index 5219442e9..6a67f5d28 100644
--- a/raster/test/cunit/cu_band_basics.c
+++ b/raster/test/cunit/cu_band_basics.c
@@ -25,7 +25,7 @@
#include "CUnit/Basic.h"
#include "cu_tester.h"
-static void test_band_metadata() {
+static void test_band_metadata(void) {
rt_raster rast = NULL;
uint8_t *data = NULL;
rt_band band = NULL;
@@ -147,7 +147,7 @@ static void test_band_metadata() {
cu_free_raster(rast);
-static void test_band_pixtype_1BB() {
+static void test_band_pixtype_1BB(void) {
rt_pixtype pixtype = PT_1BB;
@@ -221,7 +221,7 @@ static void test_band_pixtype_1BB() {
rt_band_destroy(band);
-static void test_band_pixtype_2BUI() {
+static void test_band_pixtype_2BUI(void) {
rt_pixtype pixtype = PT_2BUI;
@@ -313,7 +313,7 @@ static void test_band_pixtype_2BUI() {
-static void test_band_pixtype_4BUI() {
+static void test_band_pixtype_4BUI(void) {
rt_pixtype pixtype = PT_4BUI;
@@ -419,7 +419,7 @@ static void test_band_pixtype_4BUI() {
-static void test_band_pixtype_8BUI() {
+static void test_band_pixtype_8BUI(void) {
rt_pixtype pixtype = PT_8BUI;
@@ -527,7 +527,7 @@ static void test_band_pixtype_8BUI() {
-static void test_band_pixtype_8BSI() {
+static void test_band_pixtype_8BSI(void) {
rt_pixtype pixtype = PT_8BSI;
@@ -659,7 +659,7 @@ static void test_band_pixtype_8BSI() {
-static void test_band_pixtype_16BUI() {
+static void test_band_pixtype_16BUI(void) {
rt_pixtype pixtype = PT_16BUI;
@@ -748,7 +748,7 @@ static void test_band_pixtype_16BUI() {
-static void test_band_pixtype_16BSI() {
+static void test_band_pixtype_16BSI(void) {
rt_pixtype pixtype = PT_16BSI;
@@ -860,7 +860,7 @@ static void test_band_pixtype_16BSI() {
-static void test_band_pixtype_32BUI() {
+static void test_band_pixtype_32BUI(void) {
rt_pixtype pixtype = PT_32BUI;
@@ -956,7 +956,7 @@ static void test_band_pixtype_32BUI() {
-static void test_band_pixtype_32BSI() {
+static void test_band_pixtype_32BSI(void) {
rt_pixtype pixtype = PT_32BSI;
@@ -1053,7 +1053,7 @@ static void test_band_pixtype_32BSI() {
-static void test_band_pixtype_32BF() {
+static void test_band_pixtype_32BF(void) {
rt_pixtype pixtype = PT_32BF;
@@ -1135,7 +1135,7 @@ static void test_band_pixtype_32BF() {
-static void test_band_pixtype_64BF() {
+static void test_band_pixtype_64BF(void) {
rt_pixtype pixtype = PT_64BF;
@@ -1217,7 +1217,7 @@ static void test_band_pixtype_64BF() {
-static void test_band_get_pixel_line() {
+static void test_band_get_pixel_line(void) {
rt_raster rast;
rt_band band;
int maxX = 5;
@@ -1259,7 +1259,7 @@ static void test_band_get_pixel_line() {
-static void test_band_new_offline_from_path() {
+static void test_band_new_offline_from_path(void) {
int width = 10;
int height = 10;
diff --git a/raster/test/cunit/cu_band_misc.c b/raster/test/cunit/cu_band_misc.c
index 0e1686564..f3af3f0a4 100644
--- a/raster/test/cunit/cu_band_misc.c
+++ b/raster/test/cunit/cu_band_misc.c
@@ -25,7 +25,7 @@
#include <math.h>
-static void test_band_get_nearest_pixel() {
+static void test_band_get_nearest_pixel(void) {
rt_raster rast;
rt_band band;
int x, y;
@@ -287,7 +287,7 @@ static void test_band_get_nearest_pixel() {
-static void test_band_get_pixel_of_value() {
+static void test_band_get_pixel_of_value(void) {
rt_raster rast;
rt_band band;
uint32_t x, y;
@@ -367,7 +367,7 @@ static void test_band_get_pixel_of_value() {
-static void test_pixel_set_to_array(){
+static void test_pixel_set_to_array(void){
rt_raster rast;
rt_band band;
rt_mask mask = NULL;
diff --git a/raster/test/cunit/cu_band_stats.c b/raster/test/cunit/cu_band_stats.c
index cf1534987..499f37afc 100644
--- a/raster/test/cunit/cu_band_stats.c
+++ b/raster/test/cunit/cu_band_stats.c
@@ -24,7 +24,7 @@
-static void test_band_stats() {
+static void test_band_stats(void) {
rt_bandstats stats = NULL;
rt_histogram histogram = NULL;
double bin_width[] = {100};
@@ -209,7 +209,7 @@ static void test_band_stats() {
cu_free_raster(raster);
-static void test_band_value_count() {
+static void test_band_value_count(void) {
rt_valuecount vcnts = NULL;
rt_raster raster;
diff --git a/raster/test/cunit/cu_gdal.c b/raster/test/cunit/cu_gdal.c
index 4420d2062..18b1b6314 100644
--- a/raster/test/cunit/cu_gdal.c
+++ b/raster/test/cunit/cu_gdal.c
@@ -25,11 +25,11 @@
-static void test_gdal_configured() {
+static void test_gdal_configured(void) {
CU_ASSERT(rt_util_gdal_configured());
-static void test_gdal_drivers() {
+static void test_gdal_drivers(void) {
uint32_t i;
uint32_t size;
rt_gdaldriver drv = NULL;
@@ -47,7 +47,7 @@ static void test_gdal_drivers() {
rtdealloc(drv);
-static void test_gdal_rasterize() {
+static void test_gdal_rasterize(void) {
rt_raster raster;
char srs[] = "PROJCS[\"unnamed\",GEOGCS[\"unnamed ellipse\",DATUM[\"unknown\",SPHEROID[\"unnamed\",6370997,0]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]],PROJECTION[\"Lambert_Azimuthal_Equal_Area\"],PARAMETER[\"latitude_of_center\",45],PARAMETER[\"longitude_of_center\",-100],PARAMETER[\"false_easting\",0],PARAMETER[\"false_northing\",0],UNIT[\"Meter\",1],AUTHORITY[\"EPSG\",\"2163\"]]";
const char wkb_hex[] = "010300000001000000050000000000000080841ec100000000600122410000000080841ec100000000804f22410000000040e81dc100000000804f22410000000040e81dc100000000600122410000000080841ec10000000060012241";
@@ -152,7 +152,7 @@ static rt_raster fillRasterToPolygonize(int hasnodata, double nodataval) {
return raster;
-static void test_gdal_polygonize() {
+static void test_gdal_polygonize(void) {
int i;
rt_raster rt;
int nPols = 0;
@@ -301,7 +301,7 @@ test_gdal_polygonize_interrupt(void)
cu_free_raster(rt);
-static void test_raster_to_gdal() {
+static void test_raster_to_gdal(void) {
rt_raster raster = NULL;
@@ -374,7 +374,7 @@ static void test_raster_to_gdal() {
-static void test_gdal_to_raster() {
+static void test_gdal_to_raster(void) {
@@ -497,7 +497,7 @@ static void test_gdal_to_raster() {
-static void test_gdal_warp() {
+static void test_gdal_warp(void) {
diff --git a/raster/test/cunit/cu_mapalgebra.c b/raster/test/cunit/cu_mapalgebra.c
index 32e9e6e04..553cc7c36 100644
--- a/raster/test/cunit/cu_mapalgebra.c
+++ b/raster/test/cunit/cu_mapalgebra.c
@@ -492,7 +492,7 @@ static int testRasterIterator7_callback(rt_iterator_arg arg, void *userarg, doub
return 1;
-static void test_raster_iterator() {
+static void test_raster_iterator(void) {
rt_raster rast1;
rt_raster rast2;
rt_raster rast3;
@@ -793,7 +793,7 @@ static void test_raster_iterator() {
if (rtn != NULL) cu_free_raster(rtn);
-static void test_band_reclass() {
+static void test_band_reclass(void) {
rt_reclassexpr *exprset;
rt_raster raster;
@@ -879,7 +879,7 @@ static void test_band_reclass() {
rt_band_destroy(newband);
-static void test_raster_colormap() {
+static void test_raster_colormap(void) {
rt_raster raster;
rt_raster rtn;
rt_band band;
diff --git a/raster/test/cunit/cu_misc.c b/raster/test/cunit/cu_misc.c
index 24c618dbd..791d70136 100644
--- a/raster/test/cunit/cu_misc.c
+++ b/raster/test/cunit/cu_misc.c
@@ -24,7 +24,7 @@
-static void test_rgb_to_hsv() {
+static void test_rgb_to_hsv(void) {
double rgb[3] = {0, 0, 0};
double hsv[3] = {0, 0, 0};
@@ -66,7 +66,7 @@ static void test_rgb_to_hsv() {
CU_ASSERT_DOUBLE_EQUAL(hsv[2], 0.4, DBL_EPSILON);
-static void test_hsv_to_rgb() {
+static void test_hsv_to_rgb(void) {
@@ -108,7 +108,7 @@ static void test_hsv_to_rgb() {
CU_ASSERT_DOUBLE_EQUAL(rgb[2], 0.4, DBL_EPSILON);
-static void test_util_gdal_open() {
+static void test_util_gdal_open(void) {
extern char *gdal_enabled_drivers;
GDALDatasetH ds;
diff --git a/raster/test/cunit/cu_pixtype.c b/raster/test/cunit/cu_pixtype.c
index b69db7b37..6ef05cd64 100644
--- a/raster/test/cunit/cu_pixtype.c
+++ b/raster/test/cunit/cu_pixtype.c
@@ -25,7 +25,7 @@
-static void test_pixtype_size() {
+static void test_pixtype_size(void) {
CU_ASSERT_EQUAL(rt_pixtype_size(PT_1BB), 1);
CU_ASSERT_EQUAL(rt_pixtype_size(PT_2BUI), 1);
CU_ASSERT_EQUAL(rt_pixtype_size(PT_4BUI), 1);
@@ -42,11 +42,11 @@ static void test_pixtype_size() {
CU_ASSERT_EQUAL(rt_pixtype_size(PT_END), -1);
-static void test_pixtype_alignment() {
+static void test_pixtype_alignment(void) {
/* rt_pixtype_alignment() just forwards to rt_pixtype_size() */
-static void test_pixtype_name() {
+static void test_pixtype_name(void) {
CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_1BB), "1BB");
CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_2BUI), "2BUI");
CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_4BUI), "4BUI");
@@ -63,7 +63,7 @@ static void test_pixtype_name() {
CU_ASSERT_STRING_EQUAL(rt_pixtype_name(PT_END), "Unknown");
-static void test_pixtype_index_from_name() {
+static void test_pixtype_index_from_name(void) {
CU_ASSERT_EQUAL(rt_pixtype_index_from_name("1BB"), PT_1BB);
CU_ASSERT_EQUAL(rt_pixtype_index_from_name("2BUI"), PT_2BUI);
CU_ASSERT_EQUAL(rt_pixtype_index_from_name("4BUI"), PT_4BUI);
@@ -83,7 +83,7 @@ static void test_pixtype_index_from_name() {
CU_ASSERT_EQUAL(rt_pixtype_index_from_name("3BUI"), PT_END);
-static void test_pixtype_get_min_value() {
+static void test_pixtype_get_min_value(void) {
CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_1BB), rt_util_clamp_to_1BB((double) CHAR_MIN), DBL_EPSILON);
CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_2BUI), rt_util_clamp_to_2BUI((double) CHAR_MIN), DBL_EPSILON);
CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_4BUI), rt_util_clamp_to_4BUI((double) CHAR_MIN), DBL_EPSILON);
@@ -105,7 +105,7 @@ static void test_pixtype_get_min_value() {
CU_ASSERT_DOUBLE_EQUAL(rt_pixtype_get_min_value(PT_END), rt_util_clamp_to_8BUI((double) CHAR_MIN), DBL_EPSILON);
-static void test_pixtype_compare_clamped_values() {
+static void test_pixtype_compare_clamped_values(void) {
int isequal = 0;
/* 1BB */
diff --git a/raster/test/cunit/cu_raster_basics.c b/raster/test/cunit/cu_raster_basics.c
index 98d640a1a..ad68cba9d 100644
--- a/raster/test/cunit/cu_raster_basics.c
+++ b/raster/test/cunit/cu_raster_basics.c
@@ -24,7 +24,7 @@
-static void test_raster_new() {
+static void test_raster_new(void) {
raster = rt_raster_new(0, 0);
@@ -40,7 +40,7 @@ static void test_raster_new() {
-static void test_raster_empty() {
+static void test_raster_empty(void) {
/* check that raster is empty */
@@ -59,7 +59,7 @@ static void test_raster_empty() {
-static void test_raster_metadata() {
+static void test_raster_metadata(void) {
/* create raster */
@@ -96,7 +96,7 @@ static void test_raster_metadata() {
-static void test_raster_clone() {
+static void test_raster_clone(void) {
rt_raster rast1;
rt_raster rast2;
rt_band band;
@@ -140,7 +140,7 @@ static void test_raster_clone() {
cu_free_raster(rast1);
-static void test_raster_from_band() {
+static void test_raster_from_band(void) {
uint32_t bandNums[] = {1,3};
int lenBandNums = 2;
rt_raster raster;
@@ -169,7 +169,7 @@ static void test_raster_from_band() {
-static void test_raster_replace_band() {
+static void test_raster_replace_band(void) {
rt_raster raster;
rt_band band;
rt_band rband;
diff --git a/raster/test/cunit/cu_raster_geometry.c b/raster/test/cunit/cu_raster_geometry.c
index 162e44789..97ebb40f4 100644
--- a/raster/test/cunit/cu_raster_geometry.c
+++ b/raster/test/cunit/cu_raster_geometry.c
@@ -24,7 +24,7 @@
-static void test_raster_envelope() {
+static void test_raster_envelope(void) {
rt_envelope rtenv;
@@ -85,7 +85,7 @@ static void test_raster_envelope() {
-static void test_raster_envelope_geom() {
+static void test_raster_envelope_geom(void) {
LWGEOM *env = NULL;
LWPOLY *poly = NULL;
@@ -163,7 +163,7 @@ static void test_raster_envelope_geom() {
-static void test_raster_convex_hull() {
+static void test_raster_convex_hull(void) {
LWGEOM *hull = NULL;
@@ -252,7 +252,7 @@ lwgeom_to_text(const LWGEOM *lwgeom) {
return wkt;
-static void test_raster_surface() {
+static void test_raster_surface(void) {
rt_raster rast;
rt_band band;
const int maxX = 5;
@@ -374,7 +374,7 @@ static void test_raster_surface() {
-static void test_raster_perimeter() {
+static void test_raster_perimeter(void) {
rt_raster rast;
rt_band band;
const int maxX = 5;
@@ -528,7 +528,7 @@ static void test_raster_perimeter() {
-static void test_raster_pixel_as_polygon() {
+static void test_raster_pixel_as_polygon(void) {
rt_raster rast;
rt_band band;
uint32_t x, y;
@@ -576,7 +576,7 @@ static void test_raster_pixel_as_polygon() {
-static void test_raster_get_pixel_bilinear() {
+static void test_raster_get_pixel_bilinear(void) {
uint32_t width = 2;
uint32_t height = 2;
double ul_x = 0.0;
diff --git a/raster/test/cunit/cu_raster_misc.c b/raster/test/cunit/cu_raster_misc.c
index b2ed95e17..90888a9aa 100644
--- a/raster/test/cunit/cu_raster_misc.c
+++ b/raster/test/cunit/cu_raster_misc.c
@@ -24,7 +24,7 @@
-static void test_raster_cell_to_geopoint() {
+static void test_raster_cell_to_geopoint(void) {
rt_raster raster;
int rtn;
double xw, yw;
@@ -43,7 +43,7 @@ static void test_raster_cell_to_geopoint() {
-static void test_raster_geopoint_to_cell() {
+static void test_raster_geopoint_to_cell(void) {
rt_raster raster;
int rtn;
double xr, yr;
@@ -62,7 +62,7 @@ static void test_raster_geopoint_to_cell() {
-static void test_raster_from_two_rasters() {
+static void test_raster_from_two_rasters(void) {
rt_raster rast1;
rt_raster rast2;
@@ -175,7 +175,7 @@ static void test_raster_from_two_rasters() {
-static void test_raster_compute_skewed_raster() {
+static void test_raster_compute_skewed_raster(void) {
rt_envelope extent;
rt_raster rast;
double skew[2] = {0.25, 0.25};
diff --git a/raster/test/cunit/cu_raster_wkb.c b/raster/test/cunit/cu_raster_wkb.c
index fd36aa6f9..e1e6219e1 100644
--- a/raster/test/cunit/cu_raster_wkb.c
+++ b/raster/test/cunit/cu_raster_wkb.c
@@ -25,7 +25,7 @@
-static void test_raster_wkb() {
+static void test_raster_wkb(void) {
/* will use default allocators and message handlers */
const char *hexwkb = NULL;
diff --git a/raster/test/cunit/cu_spatial_relationship.c b/raster/test/cunit/cu_spatial_relationship.c
index f99e78b01..7438367e4 100644
--- a/raster/test/cunit/cu_spatial_relationship.c
+++ b/raster/test/cunit/cu_spatial_relationship.c
@@ -24,7 +24,7 @@
-static void test_raster_geos_overlaps() {
+static void test_raster_geos_overlaps(void) {
rt_raster rast1;
rt_raster rast2;
rt_band band1;
@@ -499,7 +499,7 @@ static void test_raster_geos_overlaps() {
-static void test_raster_geos_touches() {
+static void test_raster_geos_touches(void) {
rt_raster rast1;
rt_raster rast2;
rt_band band1;
@@ -1026,7 +1026,7 @@ static void test_raster_geos_touches() {
-static void test_raster_geos_contains() {
+static void test_raster_geos_contains(void) {
rt_raster rast1;
rt_raster rast2;
rt_band band1;
@@ -1553,7 +1553,7 @@ static void test_raster_geos_contains() {
-static void test_raster_geos_contains_properly() {
+static void test_raster_geos_contains_properly(void) {
rt_raster rast1;
rt_raster rast2;
rt_band band1;
@@ -2080,7 +2080,7 @@ static void test_raster_geos_contains_properly() {
-static void test_raster_geos_covers() {
+static void test_raster_geos_covers(void) {
rt_raster rast1;
rt_raster rast2;
rt_band band1;
@@ -2607,7 +2607,7 @@ static void test_raster_geos_covers() {
-static void test_raster_geos_covered_by() {
+static void test_raster_geos_covered_by(void) {
rt_raster rast1;
rt_raster rast2;
rt_band band1;
@@ -3134,7 +3134,7 @@ static void test_raster_geos_covered_by() {
-static void test_raster_within_distance() {
+static void test_raster_within_distance(void) {
rt_raster rast1;
rt_raster rast2;
rt_band band1;
@@ -3696,7 +3696,7 @@ static void test_raster_within_distance() {
-static void test_raster_fully_within_distance() {
+static void test_raster_fully_within_distance(void) {
rt_raster rast1;
rt_raster rast2;
rt_band band1;
@@ -4258,7 +4258,7 @@ static void test_raster_fully_within_distance() {
-static void test_raster_intersects() {
+static void test_raster_intersects(void) {
rt_raster rast1;
rt_raster rast2;
rt_band band1;
@@ -4725,7 +4725,7 @@ static void test_raster_intersects() {
-static void test_raster_same_alignment() {
+static void test_raster_same_alignment(void) {
rt_raster rast1;
rt_raster rast2;
int rtn;
commit acf474815d0c0bcf442ee5784050dcae5da68aef
Date: Mon Mar 23 10:27:29 2026 -0700
Remove warning on fallthrough
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index 055375099..ec8b3ca18 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2743,8 +2743,10 @@ Datum LWGEOM_angle(PG_FUNCTION_ARGS)
default: /*always executed*/
for (j = 0; j <= i; j++)
PG_FREE_IF_COPY(seri_geoms[j], j);
- FALLTHROUGH;
+ FALLTHROUGH;
case 1:
lwpgerror("Empty geometry");
Summary of changes:
liblwgeom/cunit/cu_ptarray.c | 14 +++++------
.../cunit/cu_remove_irrelevant_points_for_view.c | 1 -
liblwgeom/cunit/cu_tester.c | 12 +++++-----
liblwgeom/lwboundingcircle.c | 4 ++--
liblwgeom/lwgeom_api.c | 6 ++---
loader/cunit/cu_tester.c | 2 +-
postgis/lwgeom_functions_basic.c | 4 +++-
raster/rt_pg/rtpg_pixel.c | 4 ++--
raster/rt_pg/rtpg_statistics.c | 2 +-
raster/test/cunit/cu_band_basics.c | 28 +++++++++++-----------
raster/test/cunit/cu_band_misc.c | 6 ++---
raster/test/cunit/cu_band_stats.c | 4 ++--
raster/test/cunit/cu_gdal.c | 14 +++++------
raster/test/cunit/cu_mapalgebra.c | 6 ++---
raster/test/cunit/cu_misc.c | 6 ++---
raster/test/cunit/cu_pixtype.c | 12 +++++-----
raster/test/cunit/cu_raster_basics.c | 12 +++++-----
raster/test/cunit/cu_raster_geometry.c | 14 +++++------
raster/test/cunit/cu_raster_misc.c | 8 +++----
raster/test/cunit/cu_raster_wkb.c | 2 +-
raster/test/cunit/cu_spatial_relationship.c | 20 ++++++++--------
21 files changed, 91 insertions(+), 90 deletions(-)
hooks/post-receive
