[SCM] PostGIS branch master updated. 3.6.0rc2-409-g917961da3
git at osgeo.org
git at osgeo.org
Mon Mar 23 12:06:24 PDT 2026
the project "PostGIS".
via 917961da372c463decf044c366bb0515c4481fe5 (commit)
via c64beac5ac5f0243e9463f225285dd89ed1599ea (commit)
from bebe97d1abb3c2208f29533d40fe78a08c0cf0b6 (commit)
revisions in full, below.
commit 917961da372c463decf044c366bb0515c4481fe5
Merge: c64beac5a bebe97d1a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Mar 23 11:09:08 2026 -0700
Merge branch 'master' into master-buildclean
commit c64beac5ac5f0243e9463f225285dd89ed1599ea
Date: Mon Mar 23 11:09:04 2026 -0700
First cut at stripping AddToSearchPath from build, to reduce security surface area
diff --git a/extensions/Makefile.in b/extensions/Makefile.in
index 344418584..bb847bc91 100644
--- a/extensions/Makefile.in
+++ b/extensions/Makefile.in
@@ -47,8 +47,6 @@ distclean-local: clean-local
check check-unit check-regress:
@echo "Nothing to check"
-postgis_extension_helper.sql: ../libpgcommon/sql/AddToSearchPath.sql.inc
# Generate any .sql file from .sql.in files by running them through the SQL pre-processor
%.sql: %.sql.in
$(SQLPP) -I at top_builddir@/postgis -I at top_srcdir@ $< > $@.tmp
diff --git a/extensions/postgis_extension_helper.sql.in b/extensions/postgis_extension_helper.sql.in
index 4855ea882..096563c77 100644
--- a/extensions/postgis_extension_helper.sql.in
+++ b/extensions/postgis_extension_helper.sql.in
@@ -36,5 +36,3 @@ END;
LANGUAGE 'plpgsql' VOLATILE;
-CREATE FUNCTION postgis_extension_AddToSearchPath(a_schema_name text)
-#include "libpgcommon/sql/AddToSearchPath.sql.inc"
diff --git a/extensions/postgis_extension_helper_uninstall.sql b/extensions/postgis_extension_helper_uninstall.sql
index c582d3511..4cff3c7d0 100644
--- a/extensions/postgis_extension_helper_uninstall.sql
+++ b/extensions/postgis_extension_helper_uninstall.sql
@@ -14,5 +14,3 @@
-- This drops extension helper functions
-- and should be called at the end of the extension upgrade file
DROP FUNCTION IF EXISTS postgis_extension_drop_if_exists(text, text);
-DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(varchar);
-DROP FUNCTION IF EXISTS postgis_extension_AddToSearchPath(text);
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index e064d6f0b..2f8f02bc8 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -181,8 +181,7 @@ sql/tiger_geocoder.sql.in: sql_bits/norm_addy_create.sql.in \
../../extras/tiger_geocoder/geocode/reverse_geocode.sql \
../../extras/tiger_geocoder/geocode/census_tracts_functions.sql \
../../extras/tiger_geocoder/topology/tiger_topology_loader.sql \
- ../postgis_extension_helper.sql \
- sql/add_search_path.sql | sql
+ ../postgis_extension_helper.sql | sql
cat $^ > $@
echo "SELECT postgis_extension_drop_if_exists('${EXTENSION}', 'DROP SCHEMA tiger_data');" >> $@
cat @srcdir@/../postgis_extension_helper_uninstall.sql >> $@
@@ -191,9 +190,6 @@ sql/tiger_geocoder.sql: sql/tiger_geocoder.sql.in
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;' $< > $@
$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
-sql/add_search_path.sql: sql_bits/add_search_path.sql.in | sql
- cp $< $@
#hardcode for now
#TODO: generate via create_unpackaged.pl
sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/tiger_geocoder--unpackaged.sql.in | sql
diff --git a/extensions/postgis_tiger_geocoder/sql_bits/add_search_path.sql.in b/extensions/postgis_tiger_geocoder/sql_bits/add_search_path.sql.in
deleted file mode 100644
index e3d3d5833..000000000
--- a/extensions/postgis_tiger_geocoder/sql_bits/add_search_path.sql.in
+++ /dev/null
@@ -1,18 +0,0 @@
--- PostGIS - Spatial Types for PostgreSQL
--- http://postgis.net
--- Copyright (C) 2012 Regina Obe <lr at pcorp.us>
--- This is free software; you can redistribute and/or modify it under
--- the terms of the GNU General Public Licence. See the COPYING file.
--- Author: Regina Obe <lr at pcorp.us>
--- This adds the tiger schema to search path
--- Functions in tiger are not schema qualified
--- so this is needed for them to work
-SELECT postgis_extension_AddToSearchPath('tiger');
diff --git a/libpgcommon/sql/AddToSearchPath.sql.inc b/libpgcommon/sql/AddToSearchPath.sql.inc
index ff313406c..000000000
--- a/libpgcommon/sql/AddToSearchPath.sql.inc
+++ /dev/null
@@ -1,70 +0,0 @@
- Common body for a function to add a schema to the search path
- Use as follows:
- CREATE OR REPLACE FUNCTION someName(someARg text)
- #include "libpgcommon/sql/AddToSearchPath.sql.inc"
-RETURNS text
-AS
-$BODY$
-DECLARE
- var_result text;
- var_cur_search_path text;
- a_schema_name text := $1;
-BEGIN
- WITH settings AS (
- SELECT unnest(setconfig) config
- FROM pg_catalog.pg_db_role_setting
- WHERE setdatabase = (
- SELECT oid
- FROM pg_catalog.pg_database
- WHERE datname = current_database()
- ) and setrole = 0
- SELECT regexp_replace(config, '^search_path=', '')
- FROM settings WHERE config like 'search_path=%'
- INTO var_cur_search_path;
- RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
- -- only run this test if person creating the extension is a super user
- IF var_cur_search_path IS NULL AND (SELECT rolsuper FROM pg_catalog.pg_roles where rolname = CURRENT_USER) THEN
- SELECT setting
- FROM pg_catalog.pg_file_settings
- WHERE name = 'search_path' AND applied;
- RAISE NOTICE 'cur_search_path from pg_file_settings is %', var_cur_search_path;
- END IF;
- IF var_cur_search_path IS NULL THEN
- SELECT boot_val
- FROM pg_catalog.pg_settings
- WHERE name = 'search_path';
- RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
- END IF;
- IF var_cur_search_path LIKE '%' || quote_ident(a_schema_name) || '%' THEN
- var_result := a_schema_name || ' already in database search_path';
- ELSE
- var_cur_search_path := var_cur_search_path || ', '
- || quote_ident(a_schema_name);
- EXECUTE 'ALTER DATABASE ' || quote_ident(current_database())
- || ' SET search_path = ' || var_cur_search_path;
- var_result := a_schema_name || ' has been added to end of database search_path ';
- END IF;
- EXECUTE 'SET search_path = ' || var_cur_search_path;
- RETURN var_result;
-END
-$BODY$
--- explicitly move pg_temp after pg_catalog in search path
-SET search_path = pg_catalog, pg_temp
-LANGUAGE 'plpgsql' VOLATILE STRICT
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 24f155599..25cae0bfa 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -159,7 +159,6 @@ topology.sql: \
sql/topogeometry/topogeom_edit.sql.in \
sql/topogeometry/simplify.sql.in \
sql/predicates.sql.in \
- ../libpgcommon/sql/AddToSearchPath.sql.inc \
../postgis/sqldefines.h \
../postgis_revision.h
diff --git a/topology/sql/manage/ManageHelper.sql.in b/topology/sql/manage/ManageHelper.sql.in
index 4c912317b..bfae596b6 100644
--- a/topology/sql/manage/ManageHelper.sql.in
+++ b/topology/sql/manage/ManageHelper.sql.in
@@ -17,6 +17,67 @@
-- if it is not already in the database search path
-- This is a helper function for upgrade/install
-- We may want to move this function as a generic helper
CREATE OR REPLACE FUNCTION topology.AddToSearchPath(a_schema_name varchar)
---} AddToSearchPath
+RETURNS text
+AS
+$BODY$
+DECLARE
+ var_result text;
+ var_cur_search_path text;
+ a_schema_name text := $1;
+BEGIN
+ WITH settings AS (
+ SELECT unnest(setconfig) config
+ FROM pg_catalog.pg_db_role_setting
+ WHERE setdatabase = (
+ SELECT oid
+ FROM pg_catalog.pg_database
+ WHERE datname = current_database()
+ ) and setrole = 0
+ SELECT regexp_replace(config, '^search_path=', '')
+ FROM settings WHERE config like 'search_path=%'
+ INTO var_cur_search_path;
+ RAISE NOTICE 'cur_search_path from pg_db_role_setting is %', var_cur_search_path;
+ -- only run this test if person creating the extension is a super user
+ IF var_cur_search_path IS NULL AND (SELECT rolsuper FROM pg_catalog.pg_roles where rolname = CURRENT_USER) THEN
+ SELECT setting
+ FROM pg_catalog.pg_file_settings
+ WHERE name = 'search_path' AND applied;
+ RAISE NOTICE 'cur_search_path from pg_file_settings is %', var_cur_search_path;
+ END IF;
+ IF var_cur_search_path IS NULL THEN
+ SELECT boot_val
+ FROM pg_catalog.pg_settings
+ WHERE name = 'search_path';
+ RAISE NOTICE 'cur_search_path from pg_settings is %', var_cur_search_path;
+ END IF;
+ IF var_cur_search_path LIKE '%' || quote_ident(a_schema_name) || '%' THEN
+ var_result := a_schema_name || ' already in database search_path';
+ ELSE
+ var_cur_search_path := var_cur_search_path || ', '
+ || quote_ident(a_schema_name);
+ EXECUTE 'ALTER DATABASE ' || quote_ident(current_database())
+ || ' SET search_path = ' || var_cur_search_path;
+ var_result := a_schema_name || ' has been added to end of database search_path ';
+ END IF;
+ EXECUTE 'SET search_path = ' || var_cur_search_path;
+ RETURN var_result;
+END
+$BODY$
+-- explicitly move pg_temp after pg_catalog in search path
+SET search_path = pg_catalog, pg_temp
+LANGUAGE 'plpgsql' VOLATILE STRICT
Summary of changes:
extensions/Makefile.in | 2 -
extensions/postgis_extension_helper.sql.in | 2 -
extensions/postgis_extension_helper_uninstall.sql | 2 -
extensions/postgis_tiger_geocoder/Makefile.in | 6 +-
.../sql_bits/add_search_path.sql.in | 18 ------
libpgcommon/sql/AddToSearchPath.sql.inc | 70 ----------------------
topology/Makefile.in | 1 -
topology/sql/manage/ManageHelper.sql.in | 65 +++++++++++++++++++-
8 files changed, 64 insertions(+), 102 deletions(-)
delete mode 100644 extensions/postgis_tiger_geocoder/sql_bits/add_search_path.sql.in
delete mode 100644 libpgcommon/sql/AddToSearchPath.sql.inc
hooks/post-receive
