[PostGIS] #6061: segmentation fault when loading geometries
trac at osgeo.org
Wed Mar 25 12:25:36 PDT 2026
Reporter: maxsynytsky1v | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.2
Component: postgis | Version: 3.6.x
Resolution: | Keywords:
Comment (by pramsey):
In the unlikely event you've discovered a WKT input that can crash
PostGIS, we will need at least one example of said input. Can you find a
single row that does the magic? If you would like to back-channel it, you
can email it to me directly.
More likely there's something awry in your environment. Mismatched
packages are one source of instability. But let's start with your input.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6061#comment:1>
