[PostGIS] #6062: More error XX000: SQL/MM Spatial exception - geometry
trac at osgeo.org
Mon Mar 30 23:09:27 PDT 2026
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.2
Component: topology | Version: 3.6.x
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
I’ve tested this with different tolerance values and it works in some
areas but fails in others.
On the master PostGIS we now have very few errors, and this week I
switched to minimum tolerance, since that seems both more stable and
faster.
As you also pointed out, using a TopoSnap function is a much safer
approach. The caller can decide when to trigger it, choose the parameters,
and do retry to add line.
This also lets me log problem geometries to a table, which makes it much
easier to check the results afterwards and not cover up problem lines.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6062#comment:13>
