[SCM] PostGIS branch master updated. 3.6.0rc2-417-g67ff872e2
git at osgeo.org
git at osgeo.org
Tue Mar 31 03:39:11 PDT 2026
the project "PostGIS".
via 67ff872e2d4b8b46e6d412dae592e89480fc668c (commit)
from 7ec5606274655a330c0cd831d9a2dce3bcb046a9 (commit)
revisions in full, below.
commit 67ff872e2d4b8b46e6d412dae592e89480fc668c
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date: Tue Mar 31 09:30:00 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.9% (5538 of 5542 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index fb2963a81..8bba9f185 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2026-03-31 05:39+0000\n"
+"PO-Revision-Date: 2026-03-31 10:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -6581,6 +6581,8 @@ msgid ""
"documentation, alignment of PostGIS with PostgreSQL releases, X3D support, "
"management functions."
msgstr ""
+"CIとウェブサイトメンテナンス、Windows製品版と実験版のビルド、文書作成、"
+"PostGISとPostgreSQLとのリリース整合、X3D対応、管理関数。"
#. Tag: term
#, no-c-format
@@ -11381,6 +11383,9 @@ msgid ""
"clustering input geometries into connected sets using the relate pattern to "
"determine whether the geometries are connected."
msgstr ""
+"ジオメトリーが接続するかどうかを判定する空間関係パターンを使って、入力"
+"ジオメトリーを接続されたジオメトリ集合にクラスタリングして、クラスター識別子"
+"を返すウィンドウ関数です。"
#. Tag: para
#, no-c-format
@@ -11391,6 +11396,11 @@ msgid ""
"possible to build a cluster of all objects that touch at boundaries, but "
"exclude those that merely overlap."
msgstr ""
+"交差するジオメトリの接続されたクラスターを構築するウィンドウ関数です。"
+"ジオメトリーは、クラスターの他のメンバーとのDE9IM空間関係行列が対で合致する場"
+"合には、クラスターに追加されます。この関数によって、境界同士が接触するすべて"
+"のオブジェクトのクラスターを構築できますが、単にオーバーラップするものは除外"
+"されます。"
#. Tag: para
#, no-c-format
@@ -40362,6 +40372,14 @@ msgid ""
"tries to upgrade extensions postgis, postgis_raster, postgis_sfcgal, and "
"postgis_topology."
msgstr ""
+"指定されたバージョンまたは最新バージョンへのPostGISエクステンションの"
+"パッケージ化とアップグレードを行います。そのデータベースにインストールした"
+"エクステンションだけが必要に応じてパッケージ化とアップグレードとを実行されま"
+"す。完全なPostGISバージョンを報告し、その後、ビルドコンフィギュレーション情報"
+"を報告します。PostGISエクステンションごとに行う複数のCREATE EXTENSION .. "
+"FROM unpackagedおよびALTER EXTENSION .. UPDATEの短縮形です。現在は、postgis, "
+"postgis_raster, postgis_sfcgal, postgis_topologyの四つのエクステンションの"
+"アップグレードのみを試みます。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 20 +++++++++++++++++++-
1 file changed, 19 insertions(+), 1 deletion(-)
hooks/post-receive
