[SCM] PostGIS branch master updated. 3.6.0rc2-416-g7ec560627
git at osgeo.org
git at osgeo.org
Tue Mar 31 03:24:50 PDT 2026
the project "PostGIS".
via 7ec5606274655a330c0cd831d9a2dce3bcb046a9 (commit)
from bdbc1535eda9730a93f3a58edaef92fec49650d7 (commit)
revisions in full, below.
commit 7ec5606274655a330c0cd831d9a2dce3bcb046a9
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Mar 31 11:52:59 2026 +0200
Simplify tests for #3412 and #3838
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index c7ba53e90..2c1382048 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -326,16 +326,12 @@ SELECT 't3412.L1', TopoGeo_AddLinestring('bug3412',
599671.37 4889781.87
::geometry);
--- TODO: answers different on 3.8 from older geos so revised test
-/**SELECT 't3412.L2', TopoGeo_AddLinestring('bug3412',
-'0102000000020000003AB42BBFEE4C22410010C5A997A6524167BB5DBDEE4C224117FE3DA85FA75241'
-::geometry);**/
-SELECT 't3412.L2', COUNT(*)
+SELECT 't3412.L2', COUNT(*) > 0
FROM TopoGeo_AddLinestring('bug3412',
::geometry);
-SELECT 't3412.end', DropTopology('bug3412');
+SELECT 't3412.end.error', * FROM topology.ValidateTopology('bug3412');
+SELECT NULL FROM DropTopology('bug3412');
-- See http://trac.osgeo.org/postgis/ticket/3711
SELECT 't3371.start', topology.CreateTopology('bug3711', 0, 0, true) > 1;
@@ -358,16 +354,12 @@ SELECT 't3838.L1', topology.TopoGeo_addLinestring('bug3838',
622598.73 6554996.23,
622591.53 6554995.96)'
::geometry , 1);
--- TODO: answers in geos 3.8 different from older geos
--- So just doing count instead of full test
-/** SELECT 't3838.L2', topology.TopoGeo_addLinestring('bug3838',
-'LINESTRING(622608 6554988, 622596 6554984)'
-::geometry , 10);**/
-SELECT 't3838.L2', COUNT(*)
+SELECT 't3838.L2', COUNT(*) > 0
FROM topology.TopoGeo_addLinestring('bug3838',
::geometry , 10);
-SELECT 't3838.end', topology.DropTopology('bug3838');
+SELECT 't3838.end.error', * FROM topology.ValidateTopology('bug3838');
+SELECT NULL FROM topology.DropTopology('bug3838');
-- See https://trac.osgeo.org/postgis/ticket/1855
-- Simplified case 1
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index f80416f71..a9b3785f3 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -187,16 +187,14 @@ t3402.L2|3
t3402.end|Topology 'bug3402' dropped
t3412.start|t
t3412.L1|1
-t3412.L2|4
-t3412.end|Topology 'bug3412' dropped
+t3412.L2|t
t3371.start|t
t3371.L1|1
t3371.L2|2
t3371.end|Topology 'bug3711' dropped
t3838.start|t
t3838.L1|1
-t3838.L2|6
-t3838.end|Topology 'bug3838' dropped
+t3838.L2|t
t1855_1.start|t
t1855_1.0|1
t1855_1.end|Topology 'bug1855' dropped
Summary of changes:
topology/test/regress/topogeo_addlinestring.sql | 20 ++++++--------------
topology/test/regress/topogeo_addlinestring_expected | 6 ++----
2 files changed, 8 insertions(+), 18 deletions(-)
hooks/post-receive
