[SCM] PostGIS branch master updated. 3.6.0rc2-415-gbdbc1535e
git at osgeo.org
git at osgeo.org
Mon Mar 30 22:39:11 PDT 2026
the project "PostGIS".
via bdbc1535eda9730a93f3a58edaef92fec49650d7 (commit)
from 5ee8a986d13858a64efddb0aaffefdf89071e19a (commit)
revisions in full, below.
commit bdbc1535eda9730a93f3a58edaef92fec49650d7
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date: Tue Mar 31 05:14:22 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.8% (5534 of 5542 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 7eb89045d..fb2963a81 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2026-03-31 03:39+0000\n"
+"PO-Revision-Date: 2026-03-31 05:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -2404,6 +2404,10 @@ msgid ""
"This safeguards adjacent topological relationships by preventing precision "
"snapping from removing primitives altogether."
msgstr ""
+"最小エッジ範囲より大きい<varname>gridSize</varname>を使うと、エッジが空"
+"ジオメトリに縮退するのでなく例外が発生します。これにより、精密なスナップ処理"
+"の際にプリミティブを完全に削除しないようにすることで、隣接するトポロジー関係"
+"を保護します。"
#. Tag: para
#, no-c-format
@@ -11391,7 +11395,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Availability: 3.7.0"
-msgstr ""
+msgstr "Availability: 3.7.0"
#. Tag: para
#, no-c-format
@@ -11401,11 +11405,15 @@ msgid ""
"linkend=\"ST_ClusterRelateWin\"/> can be clustered into three groups that "
"connect only via their end points."
msgstr ""
+"このラインストリングのコレクションは <xref "
+"linkend=\"ST_ClusterIntersectingWin\"/>を使って単一のクラスターを形成しますが"
+"、 <xref linkend=\"ST_ClusterRelateWin\"/>を使うと、端点でのみ接続する三つの"
+"グループにクラスタリングできます。"
#. Tag: para
#, no-c-format
msgid "Connected and overlapping linestrings"
-msgstr ""
+msgstr "接続されオーバーラップしているラインストリング"
#. Tag: para
#, no-c-format
@@ -11413,6 +11421,8 @@ msgid ""
", <xref linkend=\"ST_ClusterIntersectingWin\"/>, <xref "
"linkend=\"ST_ClusterWithinWin\"/>"
msgstr ""
+", <xref linkend=\"ST_ClusterIntersectingWin\"/>, <xref "
+"linkend=\"ST_ClusterWithinWin\"/>"
#. Tag: refpurpose
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 16 +++++++++++++---
1 file changed, 13 insertions(+), 3 deletions(-)
hooks/post-receive
