[SCM] PostGIS branch master updated. 3.6.0rc2-414-g5ee8a986d
git at osgeo.org
git at osgeo.org
Mon Mar 30 20:39:14 PDT 2026
the project "PostGIS".
via 5ee8a986d13858a64efddb0aaffefdf89071e19a (commit)
from dfc4c03e1e6b394bc1cb223852fdc13d0d7d85a3 (commit)
revisions in full, below.
commit 5ee8a986d13858a64efddb0aaffefdf89071e19a
Author: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>
Date: Tue Mar 31 03:02:41 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 99.7% (5529 of 5542 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 106ef3af5..7eb89045d 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2025-11-13 16:23+0000\n"
-"PO-Revision-Date: 2026-03-24 05:27+0000\n"
+"PO-Revision-Date: 2026-03-31 03:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -1145,6 +1145,11 @@ msgid ""
"(TIGER)</link> database. If you want to experiment with PostGIS topology and "
"need some data."
msgstr ""
+"トポロジーベースのGISデータベースの例に<link xlink:href=\"https://"
+"www.census.gov/geo/maps-data/data/tiger.html\">US Census Topologically "
+"Integrated Geographic Encoding and Referencing System (TIGER)</link>"
+"データベースがあります。PostGISトポロジーの実験でデータが必要となる場合に使っ"
+"て下さい。"
#. Tag: para
#, no-c-format
@@ -2666,7 +2671,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ", <xref linkend=\"ST_InitTopoGeo\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_InitTopoGeo\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -5688,6 +5693,13 @@ msgid ""
"www.graphicsmagick.org/ </link> and ImageMagick from <link "
"xlink:href=\"https://imagemagick.org/\"> https://imagemagick.org/ </link> ."
msgstr ""
+"GraphicsMagick (<filename>gm convert</filename>)は文書で使われる画像の生成に"
+"必要です。GraphicsMagickがない場合には、ImageMagick (<filename>convert</"
+"filename>または<filename>magick convert</filename>)で同じようなコマンドライン"
+"構文が使えます。GraphicsMagickは<link xlink:href=\"http://"
+"www.graphicsmagick.org/\"> http://www.graphicsmagick.org/ </link>にあり、"
+"ImageMagickは<link xlink:href=\"https://imagemagick.org/\"> https://"
+"imagemagick.org/ </link>にあります。"
#. Tag: title
#, no-c-format
@@ -6004,6 +6016,11 @@ msgid ""
"<filename>raster_cheatsheet.html</filename>, "
"<filename>postgis_cheatsheet.html</filename>"
msgstr ""
+"<command>make cheatsheets</command>ターゲットで、HTMLのチートシートが生成され"
+"ます。クイックリファレンスまたは学習用資料に適しています。これを作るには"
+"xsltprocが必要です。docフォルダーに <filename>topology_cheatsheet.html</"
+"filename>、<filename>raster_cheatsheet.html</filename>、 <filename>"
+"postgis_cheatsheet.html</filename>の4ファイルが生成されます。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 21 +++++++++++++++++++--
1 file changed, 19 insertions(+), 2 deletions(-)
hooks/post-receive
