[PostGIS] #6063: postgis_restore ignoring dchemaname when migrating database
PostGIS trac at osgeo.org
Tue Mar 31 03:38:15 PDT 2026
  Reporter:  robopost      |      Owner:  strk
      Type:  defect        |     Status:  reopened
  Priority:  medium        |  Milestone:  PostGIS 3.5.6
 Component:  upgrade/hard  |    Version:  3.5.x
Resolution:                |   Keywords:  postgis_restore
Changes (by strk):
 * resolution:  wontfix =>
 * status:  closed => reopened
Comment:
 It's still a bug if you're not using the extension based install, so re-
 opening.
 Component is properly set to upgrade/hard so I assume this is the case
 here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6063#comment:2>
