[SCM] PostGIS branch stable-3.5 updated. 3.5.5-11-gcb5334b7c
Tue Mar 31 14:17:15 PDT 2026
the project "PostGIS".
The branch, stable-3.5 has been updated
       via  cb5334b7c736f9edc1e6e124d4688300111ab397 (commit)
      from  6eed59846d005a297a0986a5aa20a1d108bfe231 (commit)
revisions in full, below.
commit cb5334b7c736f9edc1e6e124d4688300111ab397
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Mar 31 14:07:27 2026 -0700
    Ensure that functions called in upgrade script are fully qualified
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index f210096a8..5041271f4 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3274,7 +3274,7 @@ BEGIN
 	END;
 	BEGIN
-		SELECT postgis_raster_scripts_installed() INTO rast_scr_ver;
+		SELECT @extschema at .postgis_raster_scripts_installed() INTO rast_scr_ver;
 	EXCEPTION
 		WHEN undefined_function THEN
 			RAISE DEBUG 'Function postgis_raster_scripts_installed() not found. Is raster support enabled and rtpostgis.sql installed?';
@@ -3320,9 +3320,9 @@ BEGIN
 	IF  geosver IS NOT NULL THEN
 		fullver = fullver || ' GEOS="' || geosver || '"';
-		IF (string_to_array(geosver, '.'))[1:2] != (string_to_array(geosver_compiled, '.'))[1:2]
+		IF (pg_catalog.string_to_array(geosver, '.'))[1:2] != (pg_catalog.string_to_array(geosver_compiled, '.'))[1:2]
 		THEN
-			fullver = format('%s (compiled against GEOS %s)', fullver, geosver_compiled);
+			fullver = pg_catalog.format('%s (compiled against GEOS %s)', fullver, geosver_compiled);
 		END IF;
 	END IF;
@@ -3332,9 +3332,9 @@ BEGIN
 	IF  projver IS NOT NULL THEN
 		fullver = fullver || ' PROJ="' || projver || '"';
-		IF (string_to_array(projver, '.'))[1:3] != (string_to_array(projver_compiled, '.'))[1:3]
+		IF (pg_catalog.string_to_array(projver, '.'))[1:3] != (pg_catalog.string_to_array(projver_compiled, '.'))[1:3]
 		THEN
-			fullver = format('%s (compiled against PROJ %s)', fullver, projver_compiled);
+			fullver = pg_catalog.format('%s (compiled against PROJ %s)', fullver, projver_compiled);
 		END IF;
 	END IF;
Summary of changes:
 postgis/postgis.sql.in | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
