[SCM] PostGIS branch stable-3.4 updated. 3.4.5-13-g9441c6b61
Tue Mar 31 14:20:31 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  9441c6b61df7799408119c3f2c912740a80405d6 (commit)
      from  082500dfb81518dd16746e34fba4c2ca81d4bac4 (commit)
revisions in full, below.
commit 9441c6b61df7799408119c3f2c912740a80405d6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Mar 31 14:20:25 2026 -0700
    Ensure that functions called in upgrade script are fully qualified
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 27656e07c..142421860 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3301,7 +3301,7 @@ BEGIN
 	END;
 	BEGIN
-		SELECT postgis_raster_scripts_installed() INTO rast_scr_ver;
+		SELECT @extschema at .postgis_raster_scripts_installed() INTO rast_scr_ver;
 	EXCEPTION
 		WHEN undefined_function THEN
 			RAISE DEBUG 'Function postgis_raster_scripts_installed() not found. Is raster support enabled and rtpostgis.sql installed?';
@@ -3347,9 +3347,9 @@ BEGIN
 	IF  geosver IS NOT NULL THEN
 		fullver = fullver || ' GEOS="' || geosver || '"';
-		IF (string_to_array(geosver, '.'))[1:2] != (string_to_array(geosver_compiled, '.'))[1:2]
+		IF (pg_catalog.string_to_array(geosver, '.'))[1:2] != (pg_catalog.string_to_array(geosver_compiled, '.'))[1:2]
 		THEN
-			fullver = format('%s (compiled against GEOS %s)', fullver, geosver_compiled);
+			fullver = pg_catalog.format('%s (compiled against GEOS %s)', fullver, geosver_compiled);
 		END IF;
 	END IF;
Summary of changes:
 postgis/postgis.sql.in | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
